jp98
Everything posted by jp98
Axles, MWE vs OEM
jp98 replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
MWE is a separate company from CCR. CCR just has a link to MWE's web site for the price. I believe that the $75.00 is for a rebuilt CV joint's on the axle and for a new CV joint it is $95.00. At least that is what I remember from when I did one of my axles a year ago. If you give them a call they will explain all that you need to know about the axle. -
I have had it also on my Outback for 6 years and no problem at all and for the first 5 years I was changing the oil every 2 months. As far as one leaking I don't see how it would since it is a ball valve witch are not prone to leaking. All I do to it is wipe it clean before and after an oil change, it couldn't be any slicker.
Depending on how many miles you put on last winter I would believe that you should be ok by just replacing that one tire. I would however have the tire shop check the diameter of the new tire vers the old ones and then make the decision. With tires going 50,000+ miles now there might not be that much of a difference. Jim
I had the frozen brakes for a couple of years. My problem was after driving 40 miles to work on the freeway and then getting off and trying to stop. That is when the peddle felt rock solid until I stopped and broke it loose with some pressure. I took the vacuum line off of the booster and sprayed some WD40 into the booster and didn't have any more problems. It wasn't to bad if you knew that what was happening when if first happened but the first couple of times that it did it to my Outback I was looking for a way out. Jim
My bad info then on the O2 sensor material, but it would make sence to have two different hardness of materials. It is possibly a lot like your oil drail plug and the bung on the oil pan althoe they are both made of steel. The bolt/plug is made of a softer material so that you strip the bolt/plug instead of the bung on the pan. Jim
What ever you end up doing is going to cost. Here is the THREAD CHASER that you will need to clean up the bung if that is the problem. Now if the threads are beyound repair you will need to buy a HELICOIL KIT witch isn't cheap. All O2 sensors threads are aluminum so unless the manifold is aluminum also you should be ok with the thread chaser. The best way to actually work on it would be to get it off the car and onto a bench where you can see what you are actually doing. Jim
What a lot of people don't realize when they buy a trailer, pop up, or regular travel trailer is that the posted weight on the trailer is dry weight. Add your camping gear, food, water, and what ever else you load into it and the weight go up a lot. Just a few more things that need to be figured in. Jim
Frount Axle Boots
jp98 replied to jp98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, it is the passenger side inner one. I haven't crawled under the car yet to check the divers side one so I'm not sure how that one looks. As far as the joint itself I don't think that I'll risk it lasting. My daily commute this last year was through a lot of snow and ice not to mention the magcloride that they spray on the roads here so I'll proably go with the rebuilt axle. Jim
