Rear Main Seal
idosubaru replied to WillKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdouble post
What all should I have done at 60k miles?
idosubaru replied to entidine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi agree, request OEM Subaru parts for timing belts, water pump and pulleys. that's what i always use on newer subaru motors i work on. if the OEM pulley lasts long, no point in trying an aftermarket one to see if it lasts equally as long. that's fine if he had bad experiences with independents, and he should mention it and be specific about details of the experience if he thinks it constructive for this guys' question or wants to start his own thread. but on the other hand there's no value added by equating 2 bad experiences (or was it bad choices?) with "the other 36,000 independents across the country can't work on newer subaru's". i'm an aerospace engineer, not a statistician but i'm pretty sure 2 isn't a large enough sample to start making assumptions like that. the thread is going from helping this guy get his soob tuned up to an emotional disagreement over independents vs. dealers, that topic has been covered enough in previous threads - do a search if you wish to persue/comment on that topic.
idosubaru replied to entidine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would listen more to those that have worked on these motors than someone who drops the car off at any shop, regardless of dealer or independent. the information is then at the whims of experiences and emotions. you need information specific to that motor to make the best decision possible and you can get that here on this group, just need to pay attention to whose writing it and why....some info is good, some not as good....just like shops or dealers...some are good, some are not as good. check into it, you should have a 105,000 mile timing belt installed on your car. in that case, changing it at 60,000 is not necessary but not a terrible idea either. that being said - i'd hold off on the timing belt until 90,000 miles unless you don't mind spending the money then just do it now. at 90,000 miles have the timing belt, water pump, oil pump seals, crank seal, cam seals and timing pulleys all replaced. another option is to ask them to inspect it, the covers can easily be removed in a matter of seconds to do a visual check for anything significant if you trust the mechanic. or just do that all now and be done with it. pay the dealer $1,500 or pay me half that to do it.
Rear Main Seal
idosubaru replied to WillKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe is right, it is highly unlikely that your rear main seal is leaking. other subaru leaks look like a rear main seal due to the engine layout. but they almost never leak. i've pulled a few 200,000 miles soob motors and have never seen one leaking a drop at the rear main seal. could be cam seals, crank seal, oil pump, head gaskets, cam carriers, valve covers. all of those are much more likely than a rear main seal and tend to drip toward the area under the rear main seal making a non-subby mechanic think it is the rear main seal. i would double check before going into all this work. with good equipment and tools and/or help, the transmission can be dropped faster than the engine pulled. but it is more annoying because you have to work under the car which ends up taking longer if you don't have good transmission jacks and equipment to pull/install from under the car. most people go with pulling the engine, it's an on your feet job and the engine lift does all the work. in those terms pulling the engine is easier.
Ignition problems
idosubaru replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdo not replace with regular wires, the 2.2 motor does not like aftermarket wires. there is an existing long thread about using aftermarket wires. use either Subaru OEM or magnecor wires. any others won't treat the 2.2 or 2.5 liter motors very well. some people swear by OEM only wires. i've had good luck with magnecor and know they've adjusted the design to compensate for the problems wires have on this motor.
Trans Cooler
idosubaru replied to jrbuckingham's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi say yes but i would add that you should install the transmission cooler no matter what. even if you don't tow, add the cooler. i just picked one up for my 1997 OBS and i'm not going to be doing any towing, but it's a well spent 30 bucks and couple minutes to install.
Growling rear end, 01 Forrester
idosubaru replied to Brick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can also drain your rear differential fluid, if the diff is causing the noise then there is likely parts or a gear tooth lying at the bottom of your diff which will come out if you change the oil (which should be done at 100,000 miles anyway), but if you're selling you probably won't want to. jack the rear up and check for wheel bearing play, very easy and quick to do. if it does it at slow speeds, get someone to stand on both sides of the car and see if it is louder on one side than the other. if it's louder on one side then it's obviously the wheel bearing. if it's the same on either side then it's the rear diff making the noise (centrally located).
Handling woes - wandering over the road
idosubaru replied to destey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes your steering feel sloppy at all, when you turn it takes a little extra time/effort to end up going the direction you want? if so - then check your steering rack bushings, i think that's what they are called. the steering rack is held in place by some brackets that have rubber between the rack and the brackets. these brackets can be loose and the bushings go bad, i've heard of both of these problems on http://www.xt6.net, a few people replaced the steering rack bushings and had great results with "drifting" for the lack of a better term. i can't imainge the struts would cause random drifting like this, but i'm no suspension expert either.
Ambitious XT6 project
oh...and what am i DOING? someone just did this swap and even converted FWD to AWD in the process at ww.xt6.net (see my sig). he went from auto FWD to manual AWD and i don't believe he swapped instrument panels, but he may have. do a search there. and i appologize, but we added an email process to sign up to prevent advertisers/spammers/bogus sign ups. if you have any problems with it, email me.
shouldn't be anything different off the top of my head. swapping the entire instrument panel would definitely be straight forward, plug and play. you could probably get the auto panel to work just fine though....you'd just have the P,R,D,3,2,1 whatever things on there, but they'd never light up. and you might not have the DIFF LOCK light if you were going to install that option as well. but the auto MAY have the DIFF LOCK light, you just can't see it cause it's never lit. now i'm curious, hopefully i'll remember when i leave work to look.
99 Forester - Wires & Plug questions
idosubaru replied to tabe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey do nothing to enhance performance, magnecor will state the same on their website unlike most bogus aftermarket companies. stock wires fail as well, but there's no way to verify installer or product is to fault. i know for a fact that installers are often (usually) to blame but have yet to verify bad product (OEM or magnecor). actually i have had failed stock wires on an XT6....but you're talking a vehicle 10+ years old and 100,000+ miles. after 200,000 miles a magnecor wire will stand a better chance at being in service than a stock OEM wire. OEM wires are excellent but i wouldn't want one with 200,000 or more miles and lots of years on my car. but i don't conclude the OEM wires are crap because of that. magnecor wires will indeed last that long and offer out of the box reliability at that age. (been there, done that). i have yet to see a problem with magnecor wires. that being said, they (and other manufacturers) did enounter problems at first with the 2.2 and 2.5 liter motors due to the motor design. the design and lay out turns a spark plug job into the likes of picking cotton. the wires are extremly difficult to remove, difficult to install and a bad design for ease of maintenance. if you don't agree then maybe maryland has something in the air that makes them particuarlly stubborn with sticking, ripping and falling apart. i've seen screwed up stock wires, not because the wires are bad but because the motor tends to do a number on the boots and the remover can't get them out. they stick, they won't come out, i've seen half of boots still down in the hole attached to the plug (on stock wires) on low mileage motors. i would blame the installer or uninstaller before the wires. and i've seen stock boots also detached from the plug - i don't blame the wire, the boot or the contact but probalby the installation for the cause. they probably were not seated properly.....and that's almost always because of the layout of the motor and the deep spark plug wells. there's zero access to the spark plug, you have to be observant and care about what you're doing to be sure it is seated since there's no access to the plug. i also drive a bunch of old school 80's subaru's with up to 220,000 miles on them and don't ever see ignition wire problems on them. there's no problem properly seating a spark plug when you can touch it with all your fingers. i'm also moderator at xt6.net and ignition wire issues are nearly unheard of in the older subaru's. magnecor has made adjustments to the design to make installation and reliability improvements based on these considerations. subaru has great OEM wires and i feel magnecors are good for those that plan to keep a car a very long time and never want to buy a set of wires again. that's my situation. there are other car manufacturers that magnecors make a huge improvement in longetivity for in terms of ignition life due to poor OEM wires, but no need to mention those lesser makes here (cough *jeep* cough). i'm not in this for argument but it seems your oppinions of magnecor wires may be due to old information or bad installation more than the actual quality of the currently available product. i definitely don't want to argue, heck i want to order some OEM parts at good prices, i plan on talking to you soon! but i also want members to know i've had good experiences (as well as others that i've installed these wires for) with these wires in terms of longetivity. i drive 30,000-50,000 miles a year, the longer i can go without replacing the better. i'd like to offer the same opportunity to others who have the unfortunate task of spending that much time in a vehicle.
Overheating, water leaking out...help!
idosubaru replied to greenmachine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need to run the RPM's up while in park/neutral. just pull the throttle cable by hand under the hood and hold it while you looking for leaks. or get someone else to press the gas pedal to keep them up. be sure it doesn't overheat while you're looking. no point in trying to guess, that's a terrible method of diagnosis. better to remove all the hoses and clamps and check them or replace instead of guessing which of the many possibilities it could be. weep hole of water pump water pump water outlet o-ring of the water pum two radaitor hoses small coolant bypass hose by the thermostat smaller hose coming from the water pump heater core hoses thermostat gasket drain cock cracked if it's leaking bad then running it then looking should show signs of wetness somewhere. if not, then intake manifold, head gasket are possibilities....
Running EJ22 without timing belt cover
idosubaru replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpick up used covers for next to nothing. i'd expect 20 bucks from someone/somewhere decent. keep your eyes out. i run with covers no problems on mine for years, no problems. i drive off road, snow, mud, corn fields, etc, no problems.
idosubaru replied to tabe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe only aftermarket wires i'd recommend are magnecor (www.magnecor.com),excellent wires and you'll never need to replace them again. otherwise get OEM wires, don't buy anything from a parts store for these things. i replace mine, but the ignition wires are usually fine to leave another 60,000 if you didn't want to replace them for some reason. on the other hand the spark plugs should definitely be replaced with the OEM brand NGK (that can be found at any auto parts store for like $2 each or less) at 60,000 miles or sooner. if the wires are damaged at all during the spark plug install then they will need to be replaced. best to use anti-seize compounds on the plug threads and proper grease on the wire boots, these steps will aide in removal later and protect things. although alot of people don't use thosem, any auto parts store person would be able to show you those items.
a 5 speed will bolt right in. if you use an XT6 5 speed you'll need: 5 speed trans mount (i think) 5 speed drive shaft (different length than the auto's, you'll only need the front half) 5 speed flywheel in place of the flexplate you'll need a 5 speed brake master cylinder with the gadgets on it if you want the hill-holder system to work (not necessary for the trans though) center console parts - trim up front with the stick shift and DIFF LOCk button in center console clutch linkages under the stick pedal assembly (pain the rump roast to remove, remove the steering column for better access) clutch cable vacuum lines are slightly different - easiest to just pull a set from a manual trans XT6 and look at the sticker on the underside of the hood for routing. the DIFF LOCK button works via vacuum and a solenoid that is usually left connected to the trans, so if you see the big dish shaped thing on the drivers side of the trans, that's the solenoid you'll need for the diff lock actuator to work. and finally you'll need a new rear differential assembly that's a 3.9 gear ratio as the 5 speed trans is a 3.9 gear ratio and the auto is a 3.7. you'll need to play with the wiring to get the rear reverse lights to work. if you use a different trans then certain points are different, like if you use a 3.7 manual trans then you wouldn't need a new rear differential.
K&N drop in filter
idosubaru replied to Roostman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyah, i have 100's of thousands of miles on K&N filters...100's of thousands on the same one in fact with no issues. they last forever.
Delta cams for the XT6?
i have a delta cam set on my XT6 as well. (i posted at http://www.xt6.net so you can read/ask more there if you'd like). i have the very aggressive set, i have the numbers posted over at xt6.net as well, compared to the mild grind.
Oil Pickup tube
http://www.thepartsbin.com has the correct oil pump o-ring listed for the EA82 and ER27. they are always very difficult to remove. just keep trying. i ended up getting mine out and reusing it....and mechanic beware, don't plan on reusing that old o-ring. mine was brittle and in horrible shape and fell apart. but i'm thinking that thing is in there so tight i don't know that it could ever leak. it's a tough call, mine was in terrible shape but it was so damn hard to get out i can't imagine it leaking so i still can't decide if i'll replace it next time i have to do one. next time i would install the oring and possibly use some anaerobic sealant in a strategic position as well.
2004 H6 Outback - In shop now, need quick help
idosubaru replied to 1Adam12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's under warranty right? make them replace the trans. they admitted low line pressure? that's amazing they admitted it. are the coolant lines blocked or pinched? check the transmission pan for dents. a severe dent up into the pan will restrict flow to the ATF sump, there isn't much clearance between the oil pan and the bottom of the sump..which is really the bottom of the ATF filter on older 4EAT's. this is a hard to diagnose issue, have a look at the pan. a quick visual, just look under the car, look at the pan and make sure it's good. if the CE light came on, they can retrieve that code from a read memory state. AUTOZONE and other parts places will retrieve the code for free...but the dealer may have already cleared it. i'd let AUTOZONE see what they come up with on their OBDII scanner. if they say they can't retrieve the code then i would suspect them to be full of $#^&@...actually i'd suspect that before i entered the shop (which i would never do).
"Clutch Pack" - where is it, and what does it look like?
idosubaru replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm not familiar with the torque bind, but the clutch packs shouldn't be that bad to replace, i know of a handful of people that have replaced them on the older model 4EAT's in the XT6. it's at the very rear of the transmission, the tailhousing holds all the clutch pack parts. it's the rear of the trans that the drive shaft conects too. shouldn't be that bad if i recall and it might even be possible with the trans in the car??
bad torque converter?
idosubaru replied to lazylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell if it does it while you're sitting motionless (but in drive) then it's likely the flexplate like someone mentioned. pull the access plug and keep turning it over by hand and maybe you'll see a crack in it. if someone has worked on this car....anything that would require removing the crank, like timing belts, water pump, oil pump, seals...then maybe they cracked the flex plate while holding it still to remove the crank pulley. even if something is wrong with it, there's no garauntee you'll be able to see it through that hole though, you can only see a percentage of the entire plate. check underneath the car, there's a small opening on most auto's that you can actually see the teeth of the torque converter through. maybe something is wedged in there and hitting the teeth on the torque converter. have you listened to it whine as you switch from drive (making the noise) to park (not making the noise)? does it gradually fade away? can you hear it better from the bottom or top of the TC housing? i had a horribly cracked flexplate and it didn't seem to make much noise, but my car is loud so even a substantial noise to someone else might be a drop in the bucket for me.
Official Lift Kit Group Buy
i've never needed a puller to remove XT6 steering columns. haven't had too much trouble getting them off. keep wiggling/pushing/pulling it and it'll come out in short order.
Tire pressure/normal air loss?
idosubaru replied to serotta50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the rims were'nt cleaned/dressed properly before installing the new tires then it is possible to have a small leak that will only be fixed by remounting the rims properly. if the tires are that new then it should still be under some kind of warranty. temperature dropping can account for some, but usually won't continute happening and should be fairly even across all tires. 1. check for a puncture in the tire (nail or some other object). these can be very slow leaks and sometimes never leak at all. i've pulled plenty of tires/wheels that had nails but never leaked. 2. check valve stem. splash some soapy water around a fullly inflated tire valve stem (leave the cap on the valve stem), look for bubbles. splash soapy water inside the valve stem and see if it bubbles. 3. have the tires remounted and ask them to clean the wheels off really good before mounting. only need to have the one remounted if it's the only one leaking. i've had to have this done before.
idosubaru replied to lazylegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck your front differential fluid level. if that is fine, i would guess the front diff has some bad gears or spots somewhere. have you ever drained the front diff oil? do that and have a look at the differential oil that comes out. have it pass through a small screen or in a bucket of some sort so you can have a look to see if there are any pieces in the fluid. don't forget to refill the fluid. you say it only makes the noise when in drive, does it make the noise when you're in drive but at a stop? in other words does the vehicle moving make a difference? say you're at a stop and hit the gas with the brake pedal on, will it make the noise?
Subaru XT Coupe
follow the air intake hose to where it bolts to the intake manifold...rubber/plastic tube bolts to the metal engine intake. here you'll find the throttle position sensor.
