idosubaru
339
There’s some craptastic I70 congested one lane action on Rt 70 around Wheeling WV. If possible avoid high traffic times there. I just drove it yesterday. If you come across RT 68 June 5th you can crash at my office on the floor, I’ve got an inflatable, and I’ll buy you breakfast and talk less than 11 minutes Mon Morning. Probably a little out of your way but 68 is commonly used by frequent travelers to avoid I76 tolls and less traffic through the beautiful mountains of western Maryland. You won’t be the first board member who’s stayed in my office. I’m the only person there during summers. It’s just a minute off the interstate. But I’m not in town June 3/4. My house is way off the beaten bath, no cable no TV reception no internet probably no cell service and its a long way from the interstate, curvy mountain gravel roads so it’s not a convenient over night stop.
No toss up: 2002 ATs have removable shafts, MTs do not. Do just like nvu said and pop them right out. I’ve gotten used and JDM trans with one or both missing before (including 2002 automatics). No, but this brings up a good point. The seals around them are directional. The shafts are not. If they beat it enough to yank one side out and not the other then replace that seal, or carefully inspect it and make sure it has its inner sealing spring. I’ve seen those come out on axle yank jobs. As he said it’s directional L/R so get the correct side.
Run your VIN or call Subaru and ask if all of your recalls and TSBs are up to date. Good grief. That’s terrible. What a wretched safety issue that is. I haven’t seen the auto stop/start feature but that’s unnerving if it’s inoperable. If someone doesn’t know and the sellers 6 month warranty is questionable or they don’t respond well I’d consider having Subaru diagnose it. I would bet they can diagnose this very quickly and probably know the one or two things it’s likely to be without even looking at it. I’m sure they’ve seen it before.
Ahhh - Looking at Subaru part numbers explains your confusion! Don't even look at ECU part numbers for Subaru! It's a hot mess - for some unknown reason Subaru has always changed ECU part numbers every 46 seconds even back to the 1980's vehicles, when those ECU's are identical, from the same vehicles, and interchange with no discernable difference at all. No immobilizer or canbus issues until 2005+ Use www.car-part.com and you should find some $20-$50 ECU's. their database is distorted by Subaru's part number systems as well, you just have to ignore it and work with the system a little. Buy from an automatic and tell the person you call it's for an automatic so they don't get confused. car-part is far superior to ebay - much more product options and better pricing usually. I've ordered probably a triple digit number of parts from various stores all over the US on car-part.com, they're all very accustomed to shipping parts. I have two boxes on my porch right now found through car-part.com. You can also order from preferable areas - like maybe buying an ECU from a less humid environment like Colorado or the SW is ideal for electrical components? Colorado is one of my favorites because they're usually very familiar with Subaru's, no rust, and almost never over priced.
Is it leaking? I can read your post two different ways….”I can’t fix this exhaust leak…” or “I thought it was an exhaust leak but maybe it’s something else ….” which one is it? Use hands or paper immediately after starting a cold engine and you have a short time to run hands or paper around the entire circumference of the exhaust and work front to back of the vehicle to look for leaks. Might have to try a couple times. Y pipe donut gaskets are troublesome. Grind the exhaust housing where the gasket sits down to remove rust and make smooth with die grinder. Use new bolt and spring hardware from Subaru. Heat shields vibrating? Axles. Inner joints are the typical source if it’s doing it under load. Often just repacking with fresh grease will fix it. The old grease may be gone or pour out of the boot like soup.
Sorry you're on a road trip. Brus offfered to help me on a 1,500 mile road trip 2 years ago and here he is again! Did it randomly start happening or has it been getting progressively louder? If it starts getting worse quickly then that's a bad sign. I would guess it's the tire or the wheel bearing is aftermarket and noisy. The good news is that it'll come apart very easily if it was just done recently. I would replace with a Subaru unit. I'm not recommending anything since I can't see or experience it or know it's history but I'll drive failing OEM bearings thousands of miles until I can combine replacement with brakes or tire rotation/swap. In my experience if the noise isn't getting worse quickly and I don't have any *actual drivability symptoms* I'm not worried about OEM bearings. Symptoms - If the car has momentary walking (feels like a really brief slide on ice/snow in the rear) or loose steering feel, or the ABS light comes on (reduced clearances on the internal ABS parts will trigger the ABS light - those are signs the wheel bearing is actually failing verses just making noise. I've seen and driven Subarus with all of those symptoms before. Check for noise/feel, temp, or play - but they don't always exhibit symptoms at all. Noise/feel you can try to do by just rotating the tire by hand but works best with tire and brake pads removed - rotate and listen for noise or feel for a lumpy/lagging/dragging part of the rotation. Subaru's exhibit play so rarely, or the symptoms are so bad by the time they do exhibit play that this is the least effective test).
Okay. That works too. But there's no need to guess or research. I have swapped MT and AT ECU's, and done engine/trans swaps. There's one pin on the car side connector that determines automatic or manual: *without* that pin the ECU expects and runs as an automatic ECU *with* the pin, it runs manual All ECU's are the same, with no automatic or manual distinction, and the ECU adjusts accordingly based on that pin/wiring. The manual trans ECU you buy will be the same ECU as an automatic. The *only* difference is your body side ECU connector has one extra pin "telling" the ECU what it is. So when you convert an automatic transmission subaru to manual - you swap the transmission and then just address that one pinout, by grounding that one pin - to "tell" the ECU it's now a manual. It's that simple. And so is buying a manual trans ECU!
That cars future issues will be if the headgaskets weren’t done well and having the original or aftermarket timing belt and pulleys. All of which are far more problematic than Subaru 4EAT auto transmissions. I’d install new subaru/AISIN timing kit. $300-$400 in parts. If you don’t want to put the money in it, install a new Subaru belt and Subaru lower cogged idler. inspect the tensioner and other pulleys (just spin them and see how much grease is still in them). If you can DIY small things you can do those two items in an hour. they cost $100 and are the most likely items to fail due to being aftermarket or never replaced which that low idler rarely is.
Use AISINs online catalog to look up the kit number you need. edit - I just did and they only listed one for turbo-charged?! Odd. Ive never tried but maybe you can contact them and ask? I’ve heard of people getting responses from them about timing belts before That’s wild 2006 has a one year water pump. Still an EJ so it must be the same with a minor difference .
No surprise - “Recently acquired” often means prior owner sold at the sign of ominous repairs. Correct MLS Subaru gaskets. Resurface the heads. Clean and lube bolt and threads. “Checking” to see if they’re warped is a waste of time. You don’t need the full valve job many machine shops say you need for a warranty. I tell them I don’t need the machine shop head warranty on a Subaru. Id install a complete Subaru or AISIN timing kit while it’s apart. They’re likely original or aftermarket pulleys both of which are failure prone and lead to bent valves which means redoing the headgaskets again to repair. The timing belts have to come off to replace the HGs anyway so it’s essentially no labor. Water pump, reseal oil pump, tighten the oil pump backing plate screws, cam seals and reseal rear separator would cover most other major items easily accessible with the engine out and engine apart. Although timing belt oil pump and water pump are not hard to do in the vehicle either if you want to DIY that later The oil pressure switches Leak all the time too and are only like $15 or something cheap. I sometimes replace those preventively if I expect a lot of miles/years/long trips out of the car.
What he said - check timing belt. pull the front cover and check the belt, tensioner and all idlers. Install new subaru or AISIN timing kit only. The original pulleys probably still in there are in poor condition gauranteed. list *all* codes that were present. What brand wires and plugs? Subaru/NGK plugs and wires only. Though if there are additional issues (other codes and both misfires on the same side this probably isn’t the issue.
Do some have a policy that they warranty DIY installs? I’ve never seen a JDM engine supplier that, as an official policy, will warranty a DIY install. If an employee says it via email or phone that they will, that adhoc comment for expediency to make the sale may not stand in the event a warranty claim if it’s counter to policy. And if you have a some kind of repoire with them, you may get warranty replacement without proof of their requirements. But usually their *official policy* (though it’s not always followed) is no warranty for DIY install. Ive seen various damaged connectors due to their exposure during shipping. Newer engines are worse with all their oil solenoids, vacuum pumps, etc. I just splice in from engine being replaced. Easy. I’d look for it like you said but I wouldnt rule every engine out without a compression test. Def worth doing but statistically it’s a low enough chance I would still buy it if there’s other compelling reasons to do so.
You’re right - not likely axles and outer joint symptoms are more common amd typically noisy. But inner joints are more symptomatically varied than outers and can exhibit symptoms without noise and before outers. It happens. I’ve seen it. And If they’re after market - they don’t need wear to be garbage they just need to be installed !! lol bad inner joints, or inners with old liquified or low grease (one common issue with new aftermarket axles) can cause shaking at specific speeds, driving straight, and no noise. “steering wheel shaking” can be ambiguous in terms of being more the drivers experience or the axle/wheel or vehicle chassis. not a bad idea to consider given they’ve been chasing this already and our incomplete history/feeedback about the car.
1.added 6 ounces to the overflow or the radiator? 2. Did any spray out and how low was the radiator (not the overflow tank) after the overheating event? 3. Was it bubbling or boiling and do you know the difference? 4. what brand headgaskets and were the heads resurfaced? 5. Does it have a new Subaru thermostat and radiator cap? This is unlikely but you indicate “no issues” and then experience overheating 9 miles after working on the cooling system. The only thing you did was (maybe - see question #1) remove the radiator cap. So maybe the radiator cap is suspect. Though I’ve found Subaru radiator caps fairly robust even when they’ve deteriorated and they’re symptoms usually obvious but when all we have is text to go on…. Heres the two diagnosis's you’re looking at: A: It was low due to a slow external leak, tstat, or rad cap failure. Pressure test is the next step. It overheated due to being low and you saw boiling, not “bubbling” in the EJ25 exhaust gas sense. B. head gaskets. A liquid test was used for hydrocarbons and those are notoriously inaccurate. If he used a $$$$$$$$ exhaust gas analyzer then he should test it again The bubbles are very damning evidence but pressure testing for leaks is excellent move on the mechanics part due to the ambiguity of “bubbles and boiling” and unknowns about how quickly it’s loosing coolant or not and wether that is a causation or correlation to Overheating. 6 ounces low isn’t enough to overheat but again answer question #1.
If you see FB25 then it's an FB25. US market 2012 Outbacks have EJ25, 2013 is the first year for FB25 outbacks. If you see a belt visually - it's just the serpentine belt - for the A/C and power steering. That's not a timing belt. The timing belt itself is not visible by looking at engines for sale or popping the hood. Early FB25's have oil consumption issues which is a much larger/more expensive repair than headgaskets/timing belts. (EJ25's have never had water pump issues). You also can't diagnose wether a new to you FB25 is consuming oil or not. You'll know after a few months of driving. Looking up engines for 2012's is confusing for a variety of reasons: 1. 2012 US is timing belt, 2013 is timing chains 2. Juggling different markets: Japanese engines and availability across model years varies from US market. The JDM suppliers generally keep track of which JDM engines fit which US market, so I assume that'll be the case for you as well. 3. A 2012 Outback with 6 cylinder engine does have a timing chain. 4. model year and manufacturer year can sometimes cause confusion too.
Get a new Subaru short block with 36,000 mile warranty for $2k: https://www.subarupartwholesale.com/p/Subaru_2009_Outback/Engine-Short-Block/49223018/10103AB820.html Or rebuild the heads with new headgaskets. If you do that you shouldn't have head gasket worries and end up with a warranty. But yes JDM engines and transmissions are used all the time, I've bought a few as well as many other folks. That's why there's multiple sellers of them around the US selling a bunch of them. No particular supplier has any secret sources for "better" JDM's - they're all sourced similarly from Japan, so focus on which supplier is easiest to work with regarding distance/potential returns/etc.
