idosubaru
344
Since Subadoom is too busy....
idosubaru replied to SakoTGrimes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oh my monkey nuts! i was staring at that motor and couldn't figure out what that was until i read your reply! BAH HHHHAAAAHAHAHH!!!! HA HA!!!! is that really legal? no side marker lights? -
1990 LOYALE Timing Belt Broke, low on oil
idosubaru replied to mmcclain's topic in Old Gen.: 80's GL/DL/XT/Loyales...
4 hours sounds normal for first time and going to get the parts too. the cover typically are a PITA to remove that's why we leave them off. awesome yours didn't have any problems. -
there's one way to find out tim, get to it! given similar displacement and what we've seen from will, kevin and the other guys on here i would expect similar numbers (roughly).
a picture of the oil leakage marks may help visualize possibilities.
this thread was back on topic..... doesn't have to be an argument. comments like "learn basic math" don't help us discuss. that's irrelevant and a cheap shot. kind of like if i replied "18 minus 16 is 2"...you're still in highschool. and "16-16 = 0", how many timing belts have you replaced on the side of the road?" meant to be funny, but you get the point, you don't have to discuss and make jabs at the same time. that turns discussions into debates or arguments. discussion is good, everyone trying to prove everyone else wrong is bad. all the question marks and wording of the question suggests others don't know what they are talking about. expect some sort of reply when that happens. this is really an argument over semantics and not the engines or anything else (most arguments are!). it's a circular discussion because both 'sides' are talking about something different. noone here is saying "EA82's and timing belts are unreliable". most familiar with the soob lines know the EA series motors are great, reliable engines. the fact is that "EA82's are less reliable than EA81's". the differences, numbers and stats are small in the automotive realm, but in the flying arena minor differences matter much. i've seen numerous frozen, shattered and broken timing pulley bearings...no biggie on a car, i would not want to be on a prop plane when that happened.
good point, i have a block and head that were driven a couple months with failing head gaskets. the localized overheating destroyed them. right where the breech was in the head gasket it ate away the aluminum, creating a gouge exactly where the leak was. with some stellar welding they could be repaired but i'd suspect some serious warpage due to that long term localized heating as shawn mentioned.
correct, his 95 legacy 2.2 is a non-interference engine. screw the timing belts up all day and you won't hurt the engine (figure of speech of course!) you'll know right away if it's right or not, and the EJ timing belts come with handy dandy marks on the belt to make it nearly fool-proof. look up the endwrench (subaru based info) articles on EJ timing belt replacement, tells you everything you need to know for the job.
lots of online places carry them, search around for the best deals. there are others, but i bought my last set from: http://www.ultrarev.com/home.php?cat=0 i believe they have 24 hour ordering and customer service. for the same magnecor wires: XT6 8mm wires - ultrarev = $45. magnecor direct = $77. 8.5mm wires - ultrarev = $78. magnecor = $130. EJ22 wires - ultrarev was $16 cheaper.
i suggest a leak down test as head work is much easier than block work. can you do a leak down test? i've seen blown headgasket engines show good compression and also higher than normal compression (+10%). i guess that added fluid (coolant) in the combustion chamber somehow makes up for the losses in those cases. either way, that you're seeing good compression doen't completely surprise me. if it were valve stem seals...they'd be closed during the compression stroke but i would not have guessed they would leak that much oil. removing the venting, PCV stuff may pose issues that i'm not aware of.
don't know when you got yours or when they updated their wires, but they made changes at some point to simplify and decrease the number of issues with EJ series engines. any set of wires can easily cause issue on the EJ series engine, they are not forgiving at all, which is why there are so many "cylinder # blank misfire codes" posted in the new generation forum. that's also why there is only one size available for the EJ series, but all the sizes are availabe for the older generation stuff. OEM Subaru is the way to go on EJ stuff, although i like magnecor and install them on EJ stuff as well.
my 97 impreza OBS sucks worse at higher speeds than my XT6 (which gets better highway mileage and has two more cylinders!!!! - both automatic awd). in other words my XT6 won't loose nearly as many mpg at say 70 mph highway speeds as my OBS does. i've only owned one OBS so i don't know if that's model difference or just mine.
get the 7mm wires, they will fit nicer in your stock wire holders and the larger wires won't give you any added value at all. unless of course you like the colors of the bigger ones. there's no performance gain to be had with ignition wires, any that claim to improve performance are really stretching the truth. they may improve performance because your other ones were 10 years old and arcing! but any new ignition wire would solve that problem. i like magnecors because they will last as long as the vehicle, then you can put them on your next one (nice for people like me that own dozens of the same exact car!). the "performance" gain is really that these wires will not degrade over time and will likely perform better at 100,000 miles than other ignition wires. in high performance, high output systems there are other factors to consider but there isn't really any horsepower to be "found" or gained on a stock subaru engine in the ignition department. the stock wires are perfectly capable of delivering the spark necessary to develop the huge horsepower of any EA/ER series engine (ha ha!). i'll never replace the wires in my soobs, i like that for a variety of reasons. if you never want to touch your wires and plugs again guy magnecor wires and torquemaster spark plugs. i've used both and they are excellent. the plugs are very expensive though, but will last 100,000's of miles without degrading. (been there, done that)
there already is one, just no CCR entries. unfortunately CCR is a three letter acronym and the search function doesn't like those (it won't return any results on 3 letter words). you could search for "rebuild" and probably come up with some info on them. lots of threads mention them. Colorado Component Rebuilders is the full name, may want to search on part or all of that. when looking, be sure to keep an eye on the bottom left corner of the webpage, it lists similar threads and often has very helpful information based on what you're searching for or the thread you're currently on.
what i would say has already been mentioned. there are only two typical possibilities - rings or valve stem seals. i'd guess rings. i assume you checked to make sure oil isn't getting into the coolant? i'd do a leak down test next. were the block and heads known to be good when you got them?
here's his thread: http://www.ultimatesubaru.org/forum/showthread.php?t=67248&highlight=bucket best to post a link to your thread too.
planned obsolescence. the best consumer is an unhappy one..they don't want to do it all perfect now! they have been doing subaru's for decades, they aren't hurting in terms of competition or customer base. last i was there talking to them they were thinking about playing with megasquirt. at the time they had their own dyno and computer set up to control any motor they wanted to dyno.
awesome. i've bought a number of sets and they are fantastic. you can get them cheaper if you look around the internet. i can't recall where i bought my last set but revolution something or another was in the name, just found it plugging around the internet. i beleive they were in NY, i called and ordered over the phone. check their website, they make sets for just about every subaru. a friend was replacing his jeep wires every 15,000 - 30,000 miles. i suggested switching to magnecor and he's never replaced them since...has about 240,000 on his jeep now. another friend i installed them for had some stupid freaking mechanic throw them away and install junk $11 cheapies in their place. so if you do buy them....make sure someone else doesn't throw them away!
do not pull the engine to do a timing belt, that is way overkill. a timing belt can be replaced in 30 minutes, not worth pulling the motor at all. it's a little tight, but remove the fans and there's plenty of room. the EA82's are even easier, i'm usually doing the ER27 XT6's. headgaskets - leave the engine in too, very easy. but that's for another thread another day. if you had any oil on the dipstick you did not ruin your engine at all, there would have been plenty of oil in there to prevent damage. sure, i'd change it right away. you could always add two quarts and see how far it comes up and the difference is what was left in the engine....if you're worried. but even if the oil doesn't read at all on the dipstick, there can still be enough oil in there to prevent engine damage. very risky, very bad idea, but i'm just saying....you probably didn't ruin your engine at all. here's how to repack the pulley bearings: http://www.ultimatesubaru.org/forum/showthread.php?t=50430 this is easier to do on the XT6 than the EA82 though, the bearing seals are a little trickier to access on the EA82. very easy on the XT6 though. if you don't know what a brand new pulley feels like you should stop by the store and grab one off the shelf just to see, they are very tight and smooth. it is doubtful that any of your existing pulleys feel like a new one. old bearings with no grease generate more heat and are more likely to seize or fail - this will significantly shorten your timing belt life. i run without covers as well, it's the way to go for sure. -
with air tools there's little difference between pulling the motor and leaving it. with hand tools pulling the motor is super nice. only letting you know that the 2.2 is an option. i'm not saying you should, or that i would, or that it's the best option. in order to be as helpful as possible i try to suggest your options and let you decide based on your own $, time, space, ability, and access to parts. the 2.2 swap can be a cheaper alternative for some. it's a direct swap with no electrical issues. put engine in, plug connectors together and done. the exhaust is easy to address. grab a 2.2 manifold and it all bolts up or get a 1995 2.2 and there's no issue since it has the same dual port head set up as a 2.5. if i were looking for a new motor today, i wouldn't even look around, i'd buy one from CCR. you bring up a good point, i wonder if there should be a thread in the Product Review forum for everyone that has purchased a CCR engine.
i wouldn't want a 2.5 with that many miles on it unless it had the head gaskets replaced. this thread doesn't need to turn into another head gasket discussion, just do a search on "head gasket" in this forum and do a little reading. subaru's don't have a "transfer case" so make sure you're not getting hosed. if it's binding, do a search on "torque bind" on this forum and read up on it a little. sometimes changing the ATF can alleviate that. but if it's been driven awhile like that the rear clutches probably need replaced. installing the FWD fuse in the FWD fuse holder will disable the rear transfer clutches and allow you to drive the vehicle around in FWD with no problems. if there aren't many subarus around and you need a car right now then you don't have much choice, but that's high in this area for a vehicle with problems and particularly problems that bad. you have to go with local supply and demand and you're present need.
slap on new belts, fill the oil up and you're golden. be advised there are two belts, not just one. check all the timing belt pulleys, if they are seized they need replaced. at this age it's best to regrease or replace them all. i've seen very few that are still in good condition (actually none even close to what a stock well greased pulley should be). there's no possibility of damage to this engine (EA82). all engines your year and before are non-interference variety. as for the low oil....fill it back up. as long as there was something in there the engine shouldn't be damaged. if it's *really* low like you're adding 3 or 4 quarts, then you should go ahead and change it. what was in there is likely used and abused. now...like he said..if the engine seized and broke a belt due to bad oil then your engine is hosed...so depends what you mean but "low oil".
