Everything posted by Tiny Clark
Life of stock exhaust on '98 Subaru
Tiny Clark replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShell gasoline? Hmmmm, do they use water as an additive? Mufflers usually go first due to condensation. I just out a new one on my 92 beemer, which is the first replacment.
Tire rotation
Tiny Clark replied to David Peters's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rotors can warp from stress, if the wheel nuts are too tight when they get hot, for one thing.
Tiny Clark replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got a 96 that is still good. IT was in Alaska and now in Germany, where they love to use deicing substances.
Trying to get to drain plug on tranny with car on ground!
Tiny Clark replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMan, I'm glad I don't have to wear a suit...
Tire rotation
Tiny Clark replied to David Peters's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've heard both rotation theories zooma. The never-crossed one came out with the influx of the radial tire. But I've also heard it doesn't matter. I have two sets of tires and don't mark them at all. I've never had any problems, and I'm not sure if they get run the other direction or not. I also don't buy the most expensive tire either. As far as plugging, I've been doing this for nail holes for at least 10 years, and never had a plug fail, no matter the position, and I usually run at 85-90 on the autobahn.
Stuck wheel
Tiny Clark replied to Tom Dunn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would shy away from copper grease, especially with aluminum wheels, because of corrosion problems from dissimilar metals. High temp grease is just fine.
Brake (not parking) lights wont turn off!
Tiny Clark replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure on subies, but some brake light switches are adjustable. If not, sounds like the shaft nut came loose on the switch. Poke you head under there and take a look. Someone else may know it there are two switches, one for brake lights and one for cruise control, I certainly don't.
Stuck wheel
Tiny Clark replied to Tom Dunn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have done this with much success, both for the axle and for just getting a stubborn wheel off to swap tires. Put the axle nut back on and leave it about a thread loose. Then take a short jaunt down the road doing a NASCAR warm-up-the-tires-zig-zag-move. It should pop loose with the weight of the car moving against it, a hell of a lot more that any whacker you could hit it with. Same holds true for the lug nuts if the wheel is stuck to the outside of the hub. I'm not saying drive to the supermarket or anything; of course, if you do need beer and pizza...
Which motor?
Tiny Clark replied to COB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost Volvo mechanics have boat payments to make!
Tire rotation
Tiny Clark replied to David Peters's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoing it yourself would be the novel approach.
Outdoor air temperature gauge doesn't work
Tiny Clark replied to ajosefick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlthough 48 degrees year 'round would be OK.
NAPA Belden Spark Plug Wires?
Tiny Clark replied to shimonmor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could always swap two plug wires around before you go spending more money. Just curious, do any other misfire codes come up besides 4? It seems to be a very popular number. Given that the engine uses one coil pack, I have a hard time believing the ECU can tell if one particular cylinder is misfiring, but stranger things have happened. I still miss setting the dwell for the points gap... :-\
Tiny Clark replied to shimonmor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's running good, leave 'em alone. I don't think the resistance is that far off to cause a problem. The variance in resistance readings is directly related to the length of the cable. Usually, resistance of a wire will not decrease, only increase.
Strong waxy odor
Tiny Clark replied to lazarus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't post this in jest... Is the heat on when you smell this, I have to assume so, since it's winter time. Do you have kids? Is it possible some crayons were deposited into the heat/defrost vent holes? They are always trying to fit the round peg in the square hole...
Tiny Clark replied to shimonmor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe the resistance is to keep EMI in check. The most that could happen is that you'll hear stratic on your AM radio...
1996 subaru impreza brighton AWD help ^^
Tiny Clark replied to benjig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was my question, how did you arrive at the rear end?
Overheating Engine on Highway
Tiny Clark replied to jcase321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne more thing to check, but it should be OK... Make sure your bottom hose is firm. If it is soft, the vacuum caused by the water pump at highway speed can cause the hose to collapse, preventing proper flow.
95 Legacy 4sp Auto Question
Sorry, but I consider it overdrive with less than a 1:1 ratio. The fact that it doesn't have a button for O/D like my son's Camry is irrelevant, IMO.
99 Legacy Won't go into D and Speedo
Tiny Clark replied to jbausano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it work OK if you put it in third?
I shift mine into third while going DOWN into the small towns here in hilly Germany. Otherwise, it'd take riding the breaks all the way in. I also feel no reason to allow the car to shift into and out of overdrive (4th) unnecessarily when I'm driving under 40 or so.
What does AWP mean?
Tiny Clark replied to SubieNubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe use it in the Air Force for AWaiting Parts.
Throwout bearing a problem?
Tiny Clark replied to boscoe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe throw out bearing only spins when it is actuated by the clutch lever. Ususally, if the bearing is bad, it will make noise when the clutch depressed. If the cluth is depressed, you may try to give it some Prozac, but I digress... If the noise goes away with slight pedal pressure, you have another problem. Maybe the installation of the bearing wasn't done right, or as others have pointed out, the pilot bearing.
Drive Belt/Timing Belt same or different?
Tiny Clark replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belts are also called camshaft drive belts. You need to find out what belt was replaced.
vote for best spark plugs
Tiny Clark replied to bishop087's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the ceramic is the same shape, regardless of being iridium or platinum, the plugs are in the correct temp range. http://www.sarehkala.net/Spark%20Plug%20Hot%20&%20Cold.htm Iridium and platinum are used for the electrode surfaces, which have little or nothing to do with heat range.
Struts and springs
Tiny Clark replied to Jason1976's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless you are doing a performance mod, I'd keep the same springs. No sense in wasting needless money.
