Tiny Clark
Everything posted by Tiny Clark
This is what I did, after pulling the rear panel off, and removing the pull handle to clean and lube it up. You'll notice if you push the rod down toward the latch, it will allow the mechanism to work. So, I adjusted the arm nut two turns. The arm nut is at the handle end, and it pops out of the white plastic on the handle. Works fine now. I did grease up everything else while I was in there as well.
Drafting?
Tiny Clark replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you do it with a friend, so to speak, both autos benefit form the draft. -
If you have ABS, the brake system draws more current than just for the bulbs. "The anti-lock brake system tests itself every time the vehicle is started and every time the brakes are applied. The system evaluates its own signals. If a defect is detected, the system then turns off, leaving normal braking unaffected." My lights get dim at idle as well. Tap your RPM's up a bit to about 2 grand and see if you notice a difference. If so, you may have a problem.
After ripping it apart, snoutmeat is the winner. I tried to clean and lube the handle, but it still wouldn't always seat itself back to the original postion. So, I adjusted the arm nut two turns. The arm nut is at the handle end, and it pops out of the white plastic on the handle. Works fine now. I did grease up everything else while I was in there as well. Thanks, AND MERRY CHRISTMAS TO ALL!! SEASONS GREETINGS to those that may be offended by the word Christmas, not that I particularly give a crap if you were.
