Everything posted by 84SOOB
Need Brat help ! Runs like crap suddenly
The cat converter was clogged. Took out the plug where the oxygen sensor would go and just rodded the matrix out, problem solved.
The air filter is off and the timing was right on with both distys. I have always had the return line right before the regulator on a tee. Both of my webers have a blanked off boss opposite the fuel inlet where you would ordinarily put a fuel return. I have the Mr Gasket regulator, it's definitely possible the regulator is suddenly not doing it's job after so long.
Hi Jono, yeah all brand new plugs were sooty black from less than 10 min of run time. EGR has not been hooked up for years. I have not looked at PCV valve to see if stuck. Definitely running way rich suddenly is what I was thinking too. I don't know if it could be coil issue. A new wire set will include coil lead. I don't see corrosion issue between coil tower and inside coil lead as it is now.
Timing was spot on with both distys. I can try new wires.
I'm stumped at this point. 1984 Brat w/ weber carb with no issues with the carb the last 12 years. Have fuel pressure regulator for weber. With full tank of gas was running fine, drove to 1/2 tank and parked it and the next day runs like crap. Will idle but when you rev it, motor bogs down and sometimes will die. No power to even move it up and down driveway. Changed both fuel filters, cap/rotor. Discovered vac advance was not working so swapped out disty for spare one. Timing is set correctly. Still runs bad. Fuel pump pumps and fills fuel bowl. Pulled spark plugs all were absolutely black. Put new ones in and with brat running for all of 5-10 mins with me reving motor and it running like crap, pulled new plugs and they all were black. Was thinking problem with primary circuit of carb dumping in gas ?? Got weber rebuild kit in it and reset float height, didn't see anything blocked in any jets or anything weird, still acted the same way upon restart. I'm moving this next week and need the brat running so I panic and order a new weber. Put it on today and brat still runs the same. Will start and idle no problem but when I rev the throttle you can actually see gas droplets flying up through the primary barrel into the air. When you rev it also makes kinda a farting sound which it also did with old carb ?? Definitely not the normal sound. No vacuum leaks anywhere. I don't have a compression gauge. What am I overlooking ?? Thank you in advance !!!!---Brian
which tire will do me better in snow
Watch the WRC round when they do the Rally of Finland, all the cars have very skinny rubber, cutting through the snow is better than the wide footprint.
weber throttle linkage binding
Hey Hatchsub, is it pretty straightforward to replace the bushings or do you have to mess with resetting the throttle plates, etc.---Brian
Mountain Loop Highway Adventure? (east of Everirett Washington)
I'm in, the Brat needs a scenic drive----Brian
Need Brat opinions
I think mine looks way better without the canopy on it. I use to take it off for the summer months before I moved to place where I don't have anywhere to put it. Check out my photos in the above link, there some pics with and w/o--Brian
Need Horn wiring help
Thanks for the reply guys, I'll have time on Sun to mess with it more---Brian
I decided to replace my horns on my '84 BRAT, picked up a set from a big Chevy sedan at the PAP. The new horns only had one spade terminal on them but had a spot for them so I soldered on the spade terms so they looked exactly like the Soob horns that I was removing. I mounted them in the same spots and when I reattached the neg battery cable I get constant horn. So of the 2 wires going to the horns I unplug the green w/ blk stripe one from both horns and try again only to get constant horn. I'm confused, what am I overlooking oh wiring gurus?? Thanks, in advance.
Adding a Momo Steering Wheel to your Gen 2
I've been wanting to replace my futuristic el-strange-o steering wheel in my '84 Brat. I wanted a Momo because they are leather covered and are also flat with no dish to the wheel. Grant wheels are plastic covered and have a dish to them. I'm 6'2" and don't want the wheel any closer to me, the hub adapter is going to take up space so I want the wheel kept preferably in the stock location. I picked up the Momo wheel model (Race) I liked from Ebay for $70 (retails $220) in nearly perfect shape with the horn and horn retaining ring. Momo no longer makes hub adapters for us Gen 2 folks so you either have to wait for a used one to pop up or do what I did and go online and order a Grant hub adapter (model #6596 $37.99) and a Grant's Momo to Grant adapter plate(model #4009 $18.99) the kits contain 99.95% of the hardware you will need and follow the "two wire" instructions from Grant. I ordered from www.performancecenter.com for these prices. Some of the pics are a bit out of focus but you will get the idea. If the pics don't show, you may have to be registered and logged in with the USMB. I made sure my steering wheel was straight when I pulled into the garage, disconnect the neg terminal of your battery, pull your horn cover off and put a mark on the steering shaft to locate the top when the wheel is straight. Lock your steering wheel like you are parking the car and remove the 17mm nut, then wiggle the wheel off the steering shaft. Mine came off the shaft fairly easily. Here is a pic with the horn cover off: The Grant hub adapter has the top arrow marking as well so slide it over the splines of the steering shaft as near to your mark on the shaft, you may have to try couple of different splines to get it to match up as good as possible and then reinstall your 17mm nut. Here is the pic of the Grant adapter mounted: Here is a hub comparison pic, on the one on the left they are trying to prevent you from drilling and tapping your own pattern. But on the Grant hub I could drill and tap it for the Momo wheel and not use Grant's Momo to Grant adapter plate if I wanted. Here is a pic of the adapter plate mounted on the hub, it also has the top arrow to line up: Slide the provided plastic boot over the hub assembly,then put your horn button into the horn retaining ring and put it into your Momo wheel. Attach the white horn wire to the center spade on the back of the horn button. Then you must supply a short length of wire with a spade terminal on one end to attach to the outer terminal on the horn button and then I just stripped a short bit of the insulation off the other end, so when I put the wheel on the hub assembly the bare bit of exposed wire would get sandwiched between them. Mount the wheel with supplied allen head screws and the tranformation is done. Connect your battery and test your horn. If your wheel is a bit off from dead center an alignment shop can adjust the tie rods to correct it. Finished look from my eye level and normal driving position: The adapter plate makes the steering wheel 1/2" closer than normal, still easy to reach the turn signal stalk but it is noticeable. I don't know if I'll keep it this way or I will take it apart and drill and tap the Grant hub so I can delete the adapter plate. The Momo wheel is thick and very sporty feeling. Steering is a bit heavier parking since I don't have power steering, this Momo wheel is a smaller diameter than the stock wheel. It doesn't block my view of the tach and speedo in my normal driving position either. Two words for you "leather gooooood". For a few more pics of the install see my album in the PHOTOS section---84SOOB
Stolen Car alert, Bothell, WA area--Recovered
Holy Cow Ed, I keep my eyes peeled. It also makes me want to install a hidden ignition kill switch on the Brat.--Brian
EA81 Rear Swaybar - Which to Use?
I got mine from Addco (swaybars.com) based in N.C. - was about $175 (incl. shipping)with poly-urethane bushings rather than the rubber ones. The bad part, I had to wait a year to get it. For this old of a Soob they don't stock it so I had to wait for their research & development dept. to get around to making one. This was before I found out about Ken's retrofit of the EA82 bars--I would have gone with this method, way cheaper and no wait.---Brian
Webber 32/36 V 34/34
Take a look at the Weber post at the top of the "subaru Offroad section" of the board, it should answer all your questions, yes you would need a adaptor plate. The 34/34 would give you better low end response but worse gas mileage than the 32/36.
EA82 Dizzy re-curve a success
What do they charge for the recurve?--Thanks, Brian.
Sighted: Northgate Mall, Seattle... Rally Brat Racing
Yes, that was me last night. It's funny when you drive around Seattle and see someone with their Subaru and you say to yourself that's got to be someone from the board. That's how I met Samo and his wagon one time when we both pulled into the QFC parking lot at the same time.---Brian
who grabbed the LSD @ lynnwood PAP on FRI or SAT??
That punch never leaves my toolbox, had to use it 2 weeks ago when I grabbed a dual range from the silver 3-door w/ only 97K at the same PAP. I have to give a shout out to Matt (SuperRallyRoo) who just happened to be there too, helped me pull it. Thank you for saving me much cursing and sweating pulling that tranny away from the motor, it would have been a pain to do by myself.--Brian
5spd conversion trim package?
Both edrach and I have Jerry's linkage kit for our 5-sp conversions and it works very slick, it will allow you to retain your original console pieces. Big thumbs up to Jerry for coming up with the kit.--Brian
Annual Xmas tree run-this Saturday! WHO'S IN?
I'm in, I just need a confirmed day ASAP so I can switch shifts if I need to. Best days for me are the 4th or 5th. I won't need a permit.--Brian
WCSS6 headcount
I should be showing up Fri. afternoon--Brian
How to tell if Steering Rack is worn??
How do you tell if your non-power steering rack is worn?? I remember Ed telling me he replaced his a couple of years ago on his Brat when the tire shop wouldn't align his front end. Any telltale signs/symtoms to look for?--thanks, Brian.
Carfax wanted
Hey Ed, I've got an active account for another couple weeks, shoot me the VIN--Brian
Hey Washington St. Weber carb owners
WooHoo!!! I passed emissions on Friday with flying colors. Didn't bother to hook up the EGR. Just a new cap and rotor, air filter, reset the Weber to "lean best idle" by ear like you're supposed to.--Brian
Hey Ken, thanks for the quick response. Ed told me about that guy down on 4th Ave S when I ran into him at the PAP a couple of weeks ago. I kinda plan on going down there with some vacuum line and some spare sizes of idle and main jets that I have and keep my fingers crossed. I chucked my old Hitachi crap after I got through emmissions 2 yrs ago, with some tweaking I should be fine--Brian
