Everything posted by starkiller
				Ok, what's the deal????
starkiller replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bump -
	have emailed and pm'ed ya
	well, check engine light with a 32 code is still blinking at me but now my mileage has gone from 31 to 33!!!! i would think if the 02 sensor was bad the car would run rich, right? shall i not worry about it then or find someone with the electrical test stuff to test it? also, have noticed a little bit of pinging...am running 87 octance....just the regular stuff...
	well, finally found the time(no work, sent home early )....to check this brake light problem, and yep, found on the right brake light bulb that the big element only was coming on with the lights on..also found out that there is an aftermarket bulb holder with wiring there...hmm, switch wires maybe? swapped red with green and voila!! everything be fine..thanx again to all that posted heres the deal..right rear tailight brake light is brighter with the lights on then the left one...when you press the brake, the left ones gets brighter like it should and the right one stays the same...all lights in the rear are on, nothing is burned out including the 3rd stoplight...i thought one light would get brighter if another one was burned out but not this time... thoughts??
				Good SOA Parts Ref. manual on eBay cheap
starkiller replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
naaaa naaa naaaa! beat ya to it! -
	okay, since it looks like i wont be scoring any pug alloys any time soon, i guess i will use my 13" tires to replace the bald ones i am currently running, so, recommendations please..... 1. set of toyo zradial 705 snow radials, all four fully studded...300 miles on them 2. set of toyo observe snow tires, no studs...about 75% tread left... what should i use until i can score some pugs? these will probably be run of course without the benefit of snow
				Destudding studded tires?
off road maybe but we get a fair amount of rain here(well, we use to anyway ), and studs suck in the rain..... -
	was wondering if the gl's are prewired for the options that the gl10's have..specifically the trip computer...would like to have that on my gl and i can get the trip computer from a gl10 but dont know if the wiring is there to plug into and if all the other geegaws are there also...for instance, the outside temp sensor, where is that located on the gl10? alan
hmm, not a set of needle-nosed pliers then? -
	was wondering if you can destud studded tires? got a set of four, brand new toyo's for FREEEE!! thanx craigslist! and all four have studs...and was curious if i could do this or have it done at a reasonable cost.. thanx
	its an 89 spi wgn....and i just replaced the o2 sensor a couple of months ago with a bosch so it would pass emissions....car is getting good mileage, around 31 mpg so its not running rich yet has some stumbling and hesitation though at accleration and going up hills...see previous post about this problem
				Factory service manual thread...
starkiller replied to tailgatewagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
moosens, hmm, willing to sell your one for 89?? -
				Code 32 and other issues..help!!
hmm, guess i could do that couldnt i 1989 spi wgn, 5sp d/r 205k -
				interior parts from my 87
starkiller replied to dragonwingsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
does it happen to have the high rise console? -
nobody?? -
bump -
	hi all driving home today from the tacoma pap, filled up with gas and about halfway back the check engine light came on...pulled over and checked the code and it was a 32...now, i just changed the o2 sensor about two months ago in order to pass emissions...could it be bad again already? its a bosch o2...car runs fine...around 27-32 mpg...a little bit of hesitation or stumble when accelerating or going up hills and a little bit of a rough idle...new plugs/wires/rotor/cap...fuel filter....any ideas????
				EA82 custom air cleaner pics here!
starkiller replied to incognito's topic in Old Gen.: 80's GL/DL/XT/Loyales...
see my pics in the photo gallery -
	and me!
