11
Everything posted by mcbrat
New To USMB Today, Question about Brats
mcbrat replied to swamp truck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome! when you did the bearings, did you check the brake calipers and rotors to make sure they were funtioning properly.... usually a bad axle will present itself as a clicking, but you can get grinding noise from them as well.... -
The Boomerang (Mountain Grizzly) Returns....
mcbrat replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
okay. Garage Sale outta the way. Got Grizz back in the garage last night... swapped out one of the e-brake cables. all working fine now. "fixed" exhaust. no more hitting the hitch. the 4" lift up front shifted it a bit... fixed the sloppy shifter. found sheet metal that the LF tire was rubbing on tight right turns... bent it back to where it was supposed to be... I think I "misplaced" it while putting on the lift. still need to disable the right side torsion bar, look at a potential electrical issue, ad bring down the idle... maybe put my PiperCross race air filter on... -
yeah, the bushings deteriorate with age, and compress, making the rack loose... I didn't replace mine, but added some strapping to the bracket to make it tighter...
yeah, he (BlueBaru) moved to the far NE of the US, and he transferred it to someone he knew there to cover a debt, it was then sold to JessicaCB360 who joined the board, and I worked out a deal with her to get it back... looks like BlueBaru only put a few thousand miles on it.... and then it sat for a year and a half.... Here's the thread.... http://www.ultimatesubaru.org/forum/showthread.php?t=109662&highlight=daily
My owners manual states I should not use it unless it is 10% max, but even then, do not use it exclusively... And if I develop drivability problem to stop using it.... I occasionally get some, when that's all that available....
Regular. 87 or premium 91 no ethanol.
26.1 is the corrected value, but I'm happy with that for Iowa gas...
I had a GEn1 full skid plate modifiet to fit, but since it bolted in at the bottom of the core support on the shorter front end EA81, it wasn't quite sturdy enough. it protected the exhaust and oil pan great, but flexed "just enough" to snap my oil sending unit 2 times.... then I did this...
EA81 - I want to add Power Steering to my BRAT
mcbrat replied to dec0y13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good point on the t-stat housing... the ea81 power steering quipped vehicles had a differet t-stat cover to allow for clearance of the rear of the pump.... if you go here Subarus of the 80s to the "Some Helpful Diagrams" link in the middle column, at the very bottom of htat page, is a drawing of the diffferences.... -
be sure to put a good skid plate on, or do a remote oil sender set-up.....
nice!
Ignition barrel removal 85 brat.
mcbrat replied to jonas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
lets see if I can remember... I've done it before, but has also just swapped out entire columns... just to avoid this... remove all the plastic around the column. about 6 screws from the underside. remove steering wheel. an 85 will have 1 or 2 screws to remove from the back side for the horn button, then you sort of have to pry it off... use a deep well 17mm socket to remove the steering wheel nut. disconnect the plug for the multi-sw and caregully remove the multi-sw unit. remove the 2 screws holding the IGN electrical switch to the back of the tumbler... you should see a couple of tensioned cables with ball ends attached to the column, for the auto-spring of the tilt. you'll need to get ahold of the ball end without damaging it, and pull then free of the socket they sit in. there should be 2 or 4 bolts (8 or 10mm) holding the tumbler to the column. remove those, and you should be able to pull the tumbler assembly off the column... be carefull, and make sure the roller needle bearings inside are still there (not stuck on the column). inspect your replacement to make sure the needle bearing are intact, or you may need to transfer your old ones over.... install the replacement tumbler.... -
I've been using my '86 Brat as a commuter this week... getting 26.1 mpg! it's got a 3" lift, and running 205/70R14 all-seasons on soob alloy wheels. rear discs. other than that, it's completely stock brat with only 93k on the clock... even the radio/tape player is stock....
and I'm always looking for a couple of the 14" jackmans.... rare as hens teeth....
Its a shame.... what do I do...
mcbrat replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's
Enough with the threats against others or the "board". Stick to the facts. if you're not part of the deal. stay out. -
so what are you gonna do, have a swappable body with the Justy?
Date is set now. We still don't have the registration forms online, but will soon.... What: Timber Ridge Trail Ride Where: Timber Ridge Ranch, Castana, Iowa (Western Iowa) When: Sept 17-19, 2010 2500 Acres. 60+ miles of trails Great place. This is a members only place, and is only open to the public a couple of times per year... And night wheeling is allowed, which in many ORV parks is not... Dual Range needed and LSD preferred. Keep watching here for the sign-up sheet http://www.ci4wi.org Here's the Timber Ridge site too... http://www.timberridgeiowa.com/index.html and their old site.... http://www.peelout.net/ Do a search in this forum for Castana or Timber Ridge. Lots of threads on past years events...
I took it to castana last sept. that's where I smashed my door and pillar.... I've got a little 40" x 60" flatbed trailer I'll probably take out to the campout, with my camp gear and wood. I could fit it all into the bed of the Brat maybe, but I'd rather not... I must say, I do like having a 17 gallon tank on the Brat though....
