25
Everything posted by nipper
ABS is a flow through mechanisim, meaning brakes work without it. An early abs like this would bleed off pressure, not impeed it. Smoking brakes, frozen caliper and you boiled the brake fluid.
Wont start after jacking drivers rear wheel?
nipper replied to Norcalbratcap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Choke, or a stuck float by a little dirt. Or gnomes. -
lso be a bad electrical connection -
Is it possible, long shot here, a fuel line is rusted or near pinched and the sheer act of DARING to remove a flat tire (the other 80% is perfectly round, a waste) and something is pinching a line? -
Wow so many places to start This car needs a proper tuneup. Plugs Subaru wires fuel filter air filter. I et you have some bad plugs. PCV valve too. Next your due for a timing belt, like it of not, with a water pump cam seals idler and tensioner. Then trace down the FRONT O2 sensor. Hell at this poin replace one then the other. Normally not my suggestion but the car hasnt been maintained all that well and thats coming home to roost.
To be honest when my unit went bad I had the dealer rebuild it to get it right. Transmission shops are shady at best. Its not hard to rebuild yourself I just dont have a garage, nor at the time a paved driveway. If the tranny works, I would just replace the unit. Since it sort of hangs on the tail of the tranny, it can always be used on another tranny.
