25
Everything posted by nipper
	Why waver just because people do not take care of thier cars. Sooby waterpumps never leak that early, more like 140 or more if not replaced with the timing belt. I would go on to the next car. The only other car as bullit proof for a 17yo is a volvo. There are affordable BMW and MB in that year but they can be pricey to repair.
	http://www.autoblog.com/2011/03/28/video-subaru-wrx-flips-end-over-end-at-global-rallycross-champi/#continued
	[quote name=dmorrow;1005823 I mentioned in an earlier post that my tires have always been matched up. I forgot to mention that the tires had been put on after a tire rotation with the tread the wrong direction' date=' ie with the rotation arrow pointing in the wrong direction. I noticed this, but didn't think it was important. It was recently remedied. Is there any possibility that the tires with the tread in the wrong direction could over time (1 year) cause this? I did just check the tires and they are all spot on accurate with respect to diameter. Tx! D[/quote] Were all 4 backwards? Yes it is inportant as tires pump water out from the tire to prevent hydroplaning.
	Just an FYI this is the bad part http://www.subaruforester.org/vbulletin/f89/center-diffs-how-replace-them-46979/ "replacing Viscous Coupling Differential" (that was done just for searchability) What sucks is that sunaru seems to have changed their on line ordering system from dealers, so little info there now.
	1- No, as it used for pulling a load or adding breaking fdorce down hill. 2- no you will lug the engine. The torque converter multiplies torque at a 2:1 ratio ( I think it is actually higher) and needs to be unlocked to multiply power for hills. Keep the car in D3 for hilly areas. Last one, change the tranny fluid and lest see if that goes away.
	So then neweer to you is an auto from the late 1970's or newer http://auto.howstuffworks.com/automatic-transmission.htm http://www.edmunds.com/car-technology/automatic-transmissions-what-makes-them-work.html Then after that in another 15 uyears we can explain (and by then we will all know) how manu-matics/multiple clutch manuals work and which tend to blow themselves up the quickest. I am taking bets on that last one BTW.
	Soobys seem to be picky about that. Tht is how Justy CVT's got destroyed.
	it is a 1976 Subaru GF (?) Google. Don't discount ads as they can information in them as well. Between those two I don't know what else you are looking for or it does not exist on the net.
YOU by any chance wouldnt have a 1/2 inh hole punch would ya?
and how the heck are you..
