Everything posted by nipper
Justy running too rich!
I had this and I had to get a rebuilt carb. The float was stuck. Mine sat for 3-4 years. Between the (vile) old gas and other stuff, it had to be rebuilt. I have a source if needed.
Valve Cover Gasket - oem or aftermarket?
nipper replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsee if thereis a OEM kit. You have to replace the spark plug bucket seals at the same time and they must be form subaru as aftermarket leak.
low rubbery squeak front right 2002 OBW VDC
nipper replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccident? One of those minor details people tend to leave out
Does this look like a blown head gasket???
nipper replied to fiber_tek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell i was right With all the data base errors i just been reading the lead posts since only God knows when it will go poof on me
Justy
Mine only gets 15 INhg on the vac gauge, so it needs to have the TB changed. I may farm that out as it is an easy job. The car sat too long I will wait someone else fight it.
help,loosing antifreeze along way from home
FYI Headgasket sealant is completly useless, unless your the MFG and find people who want to beleive it solves the invetable.
Odd Piston Slap Sound
nipper replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is what happend to Blu before a rather impressive and spectacular rod failure. nipper
nipper replied to fiber_tek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFlush the cooling system completly. There is way too much oil there for a blown HG. I think someone put oil in the coolant. nipper
Carrier Bearing
nipper replied to bison118's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust in case: http://www.driveshaftspecialist.com/
Flywheel
nipper replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not a big fan as cutting/resurfacing subaru flywheels. Make sure you replace the throwout bearing clips.
nipper replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLets see... NEVER EVER EVER go to a Midas for anything ...same for a chain transmission shop of any kind. 10,000 miles on brakes can be your driving habits, where you live, stuck or sticking calipers, collased brake line. A sticking barke rotor can make this noise. everything on that front end flexes a tiny bit in turns (really tiny) or else things would break. Making a turn can be enough flex to make something make noise. Is there a ally or parking garage you can drive in to hear if there is any noise at other times that you can not hear. When you drove in a circle was there any grabing in the drivetrain.
Justy
If I ever EVER talk about putting central locking in a small car ever again chop my hands off.....
White Smoke Occasionally Coming From Exhaust (1982 GL EA 81)
Maybe Keep an eye on your coolant level for a while, otherwise... Thats just condensation in the exhaust system burnig off. Depending upon the driving condtions humidity alignment of the planets and the gnome population in your area, it may happen.
Spark Plug ground is Greenish.. But why ??
Hpw old are the spark plug wires
- flasher
Confused ~ A reoccuring comment
nipper replied to plaidfro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFaulting an engine for blowing a head gasket after 150K is sort of silly. The more mialege a car gets on *the more thermal cycles and possibly unheard pinging) the more possible it is to blow a head gasket. It is akin to saying at the funeral of a 95 yo man that he died because he did not take care of himself. if you buy a used engine, you should reseal it, including replacing the head gaskets. you never know what you are getting with a used engine, so may as well do it all while it is out of the car. And you are correct. If a sooby engine overheats and the oil is not changed while the cause is fixed it does increase the likelyhood of thrown rod. Also extended oil change intervals do not help either. The older the used car, the more likely it is that you will have put money in it in the first year fro maint and hidden repairs.
Noise During Acceleration?
nipper replied to BrightonFuture's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFront diffs whine. Tis may the begings of wheel bearing failure, allowing just enough play to rub something or sideload the bearing. Jack up that tired and check for play. SPin the tire and listen for grinding noise
nipper replied to plaidfro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne other mantra on awd ALL TIRES MUST MATCH!
nipper replied to plaidfro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think dodge Neons along with quite a few others are far more effecient at overheating then subarus are. You NEVER keep driving in an overheat unless you are in a dangerous place to pull over, then you keep going. A car is cheaper then a human...though i know a few who may not be worth that much
nipper replied to plaidfro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNO. I know quite a few 2.5 that are just running fine with the original HG thank you. you do not pverheat aluminum engines as a rule. you may get away with it once, but if you cook the engine you will warp the heads and cook the oil. Running low on oil on modern engines is a bad idea as they do not have large pans anymore. SUbarus tend to get very unhappy if down more then 1 qt and even 1 qt is pushing it. nipper
Brake Clunk
nipper replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeized caliper is letting your pads thunk.
CV replacement messed up alignment?
nipper replied to Lanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat kind of axle was used?
nipper replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your brakes again, it could be a rubbing backing plate. Spray rubber parts with wd 40 and see if the noise goes away to rule out bushings.
Justy
Really need to get him finished the next two weeks Check list Finish power door locks Finish alarm (yes an insurance break and operates doors) finish cruise control (low priority) May do timing belt myself, may be more effecient to farm it out then set the carb and timing Have an exhaust system built Tires Low priority Fuel sender, it works but full is 1/4 of tank Roof paint Window Tint (no ac) Would LOVE a subaru weatherband cd player, just watching ebay for it. He is getting close, better be with 4.15 gas.
Subaru Imprezza 2012
http://www.autoblog.com/2011/04/28/subaru-predicts-50-sales-hike-for-2012-impreza/ Photos http://www.autoblog.com/photos/2012-subaru-impreza-new-york-2011/full/#4074495 Larger and more main stream
