Everything posted by nipper
AC Compressor Cycles ON and OFF every 10secs
nipper replied to JimmyJam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup. nipper
no reverse
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are not many things that go wrong on an auto tranny that can be easily fixed. Loosing a gear is impending doom. You can try chainging the fluid, a can of tranny fix, but usually no reverse means you need a tranny. The reverse clutch/band is shot. nipper
two 4EAT ?'s
nipper replied to mountaingoatgruff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFoaming is caused from too much fluid. The Hyd system is like your heart, as it is not made to pump air. This can also damage your clutches as they need to be 100% wet evenly, Air can cause hot spots. Why didnt you just use tranny fluid for assembly? The jelly is like pre-gumming up the tranny. It may not even be compatable with the materials inside the transmission. Check the simple things first on the code, like the electrical connectors. nipper
CV axle not fitting correctly
nipper replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk im going to stick my nose in here. i want some pics. i would like to see a pic of the engine under the hood with the hood open. A side shot of the right side (or whatever side that is the problem) with the tire off. I would like to see pics of the underside of the contol arm and hub at full left and right lock. Is there any frame rot on this car? I had an 88 GL that would pull axles apart. It tracked correctly, it would hold an alignment, but the subframe was rotted out that it would pull cv joints apart. nipper
named subarus
nipper replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's funny. My 1998 Legacy had no personality, so it never got a name. It never even got a gender. My past cars had at the very least genders. Blu has tons of personailty. He got his name on a 4 week 12,000 mile road trip nipper
named subarus
nipper replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet regular plates, drive it for a few months. Feel it out, then you'll figure out if it's a male or female, then you'll just know when the right name comes up. nipper
300,000
nipper replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX30,000 and your to the moon, then you can turn around and start coming back home. nipper
Shift resistor 4eat
nipper replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell who moved it to the passenger side without telling me hrmm? HRMM? (thats what i get for reading Ozzie SVX sites) nipper
Bad Thermostat?
nipper replied to Rich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat he said. nipper
Shift resistor 4eat
nipper replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSoobys have such wierd shift charecteristics. The Resistor (under the battery i do believe) is to soften i think the 1-2 shift. People have unplugged it and noticed no differnce. Right now Blu has a hard 1-2 shift when making a turn (not torque bind) i dont even think it still works. Other times the shift is as smooth as silk. I think its more noticable in a SVX transmission, where people unplug it for firmer shifts. You would probably do better by just chainging the fluid nipper
Shift resistor 4eat
nipper replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI still have one i think i shook my O2 sensor apart wheelin the other week. It will wait till spring to get fixed i think. nipper
EJ Swap - Different approach - Need your expertise
The 10.00 question http://www.pa.msu.edu/sciencet/ask_st/122591.html nipper
1997 Legacy Gt 2.5 Transmission problems
nipper replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHuh? Exploding? I just think JDM trannies are a waste of money unless you can't find a used one in the USA. And any tranny will shift hard with dirty old fluid. Any AWD tranny will have AWD issues if the tires don't match, JDM or otherwise. We drive alot more and further then is custom for japan. Thats the only reason why wear issues show up here more often. nipper
Snorkel/intake idea for 2000 Outback - help!
nipper replied to thatswhatshesaid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure you have drains on any hood type scoop, otherwise your engine may drown. The fresh air intake at the cowl actually gets more air then a hood scoop will. The sooby scoop is in the slip stream to some degree, but the base of the windshield is a high pressure spot, and will function better. nipper
New Jersey Pine Barrens Nov. 23rd ??
SO are we meeting at the rangers station or the diner? nipper
nipper replied to thatswhatshesaid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do you filter the air? nipper
Oil stop leak?
nipper replied to deks69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEspecially big leaks it wont fix. He has gone from "oil leak" to "subaru automatic anti-rust system"
Oil stop leak?
nipper replied to deks69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStop leak for oil leaks works by swelling the old seals or gaskets. It's not horrible, but since most oil leaks in engines come from rotational seals, it may make things worse. I bet you need to be sealed, which means cam seals, front main seal, re-seal the oil pump. The rear main seal doesnt go bad too often. The seperator plate is plastic and should be replaced with a metal one. Don't srive the car like this for the reasons stated above. nipper
Lookie!!!!!!!!!!!!
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno idea ... just scoffed it off the outback board nipper
1998 Legacy L Wagon - Rattle While Turning
nipper replied to jreb10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe TSB has to do with the universal flex joint in the steering column. I am betting you have a bad cv joint. nipper
Lookie!!!!!!!!!!!!
Subaru parts catalog http://opposedforces.com/parts/
Ever used a split cv boot repair kit?
nipper replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWinter is almots here. Road salt sand and snow will quickly end your experiment. Its always fun chainging an axle in the dead of winter. nipper
nipper replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used one, it was ok. The car went another year before it was scrapped. I forget the car i used it on. Unless your stuck for time or something, i would recomend replacing the axle. nipper
i am going, are we doing brekfest? Do i need to pack a lunch? nipper
dash light problem 95 legacy
nipper replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs a side note, there are instructions on how to replace those other burned out bulbs her eon the site. nipper
