Everything posted by nipper
Crazy overheating problem amongst other things
Ok. so the cams are timed. You cant get the disty to be properly set. i'm still wondering if there is an air bubble in the system. I dont remeber , does this have a water valve on the heater core? nipper
Underhood Oil Leak...Litterally!...Update
i was going to suggest the oil pump o ring. nipper
1997 Legacy Gt 2.5 Transmission problems
nipper replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi can see how it can be the diff. Drain the diff fluid and see what comes out. Run it through a filter of some kind. If there is metal in it, your done with that tranny. Its not the diff gears itself, but the pinion gear that drives the ring gear on the diff that may have failed. If it was inside the tranny you would have some issues going forward too as reverse uses some common parts with the drive gears. nipper
fuel smell and surging idle issue
nipper replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXil'd check all the fuel lines, especially the short ones, they can be sneaky. nipper
So about those cooling fans ...... nipper
Thats ok i dont remeber if you have one or two fans on this. If the fans arent working ...... your going to boil over. nipper
A easy test is to remove it and let it run without the thermo stat. It's easy to install it backwards in any car. Also when you remove it compare it to the old one, do they look exactly alike? Are your cooling fans coming on or functioning? nipper
YOu may have air bubbles, a T-stat installed backwards, or both. A clogged or decrepid radiator usually showd up under load, where as a sudden overheat would be from the other two. nipper
was there bubbles? Did you fill the cooling system with the car running, and continue after the T-stat opened up? What condition is the radiator in? nipper
1997 Legacy Gt 2.5 radio interference
nipper replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it change with engine rpm?
nipper replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBad Alt, chattering brushes in any electric motor in the car, a bad ground... nipper
Leaking heater core on '98 Legacy L Wagon
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure its not coming from under the hood. !st thing i would do is get a pressure test on the cooling system. If it fails that look for leaking hoses first before you put in a bottle of stop leak. nipper
rear brakes not lasting long?
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJOb may never have been fone. Other reasons are bad fron brakes, bad master cylinder. There really is not a lot to go wrong nipper
Motor is out what should I replace?
nipper replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is truly a crate engine (brand new/rebuilt out of the crate), why would you need to replace these parts? Or is this a used engine? nipper
storing SOHC 2.5 question
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://seqair.com/skunkworks/Engine/Storing/Storing.html http://answers.yahoo.com/question/index?qid=20070731123424AAmW14H nipper
Lost my AWD??
nipper replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt 242,000 miles on the transmission i would replace it with a used one. 200,000 miles is a long stretch for a subaru transmission, and would most likely keep going if you left it be (no broken AWD as stated). At 245,000 its like open heart surgery on a 95 year old. A much cheaper and wiser option is a good used transmission. nipper
Scan Gauge II
nipper replied to rlsimpso's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvelcro on top of the steering column.
No brakes/ hillholder fix?
Did you try a metric T block? Also what was wrong with the hillholder to begin with, not much to them to go wrong. nipper
New Jersey Pine Barrens early October?
i dont do "camp" anymore. i am sick as a dog right now from that "camp" thing, but i dont have anything planned for October so im interested nipper
NJ Pine Barrens Outing, Sunday August 31st!
It"s funny. Here I am at freinds in Jackson, Mi. Blu was all nice and shiney till I got on their street. The entire street it torn up so its serious 4 wheeling so now Blu dirty.
Blu did something odd
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell so far all good zigzag across PA and blue is behaving like he is brand new. I will have to replace the ps pump when I get home as the steering is heavy. I may not have net access next ten days so play nice. Nipper
Starting/electrical issue
nipper replied to gofargogo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStarter solenoid contacts like he said, but really first thing is first, have the batery tested. The car is old enough to need one. nipper
95 Legacy transmission troubles
nipper replied to pleiades1995's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould it have been they did not properly seat the torque converter? Yes don't go back to the same place find an other. And ther shop was correct, you can instantly kill a tranny by running low on fluid. I am surprised it lasted this long. JDM may have a diferent final drive gear ratio then a US transmission. Try to stay with one from the USA, they are available, why make life hard for yourself? nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems to be really short trip then park for 6 or more hours. nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlu did it again today after a really short trip the other night. I am going to put a better oil filter on him monday. I think the filter is the problem. If it was an injector there would be a cloud on startup I would think.
