Everything posted by nipper
How did you break your first Subie??
My 1981 GL coupe died of cancer. It was a slow peacful death. nipper
how reliable is the boxer engine?
nipper replied to sjbien's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat failure almost never happens in modenr engines, let alone subaru. Ring failure can come from cooking the engine, ping, running too lean in that one cylinder. Boxer engines as a whole are extreemly reliable. I wouldnt even consider a HG a hard engine failure (after all its just a gasket). Sounds like your car did not have a happy previous life, or you were just the unlucky one.Typically 200,000 miles or more on a wel maintained engine is not unusual. nipper
Check engine light with depending where I fill-up
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, it depends upon the sensor. The O2 sensor will use its default (ie open loop) settings. The pressure transducer your talking about has no effect on anything except the ozone layer. Some sensors there are no default parmieters, like the cam crank psotion sesnors, hence why the car wont run if they go bad. nipper
New Car Questions
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://auto.howstuffworks.com/question508.htm Yes nipper
95 Legacy fuel pump dead??
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm taking your lump of coal back to the mine
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI want him to buy the Haynes book first show off nipper
EJ25 missing on 2 and 4
nipper replied to e4620's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hate to state the obvious, but has the ignition wires been replaced? If not they are due to be replaced. Just a thought. nipper
New Car Questions
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSaftey glass just means when the windows shatter, they shatter in a million little pieces, so that your arteries dont get ripped open. The windsheild is laminated so thats an entirely different beast. Dont know about the radio questions.
Soft brake question
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are several methods around to adjust rear drums. One is a manual adjustment. Another is the backup and stomp on the pedal, and the third is the hand brake. The hand brake method is the one that is least used in people with automatics. Thats why its still a good idea to use the hand brake even in an automatic. nipper
Sometimes ABS sucks
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just want to clarify, that the fuse sends a signal to the TCU to fully power the Duty C to disconnect the RWD. To get on demand 50/50 split you have to cut off the signal to the solenoid from the TCU. Now what would be a good trick, is to use this idea to power a disconnect for the ABS That i like. nipper
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is sounding like either a CTS problem or a cam/crank position issue. Get the haynes book and it will tell you how to test each item. I would test them after the car stalls. If you have no spark (easy pull a plug wire) then its the crank sensor. nipper
Sometimes ABS sucks
nipper replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought we addressed this a few times. Yes put the car in neutral. Read the entire post, i think someplace in here (or the other snow thread) is an article and myself explaining why. Also another PS if you lock all 4 wheels, the ABS is going to think you are stopped, so it isnt going to do a thing. Even if the car itself is still moving. nipper
Soft brake question
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats how they work. pull up about 3 clicks they grab, push button to release. nipper
Head Gasket?
nipper replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX*chime* have you done anything to the cooling system recently? Replace your radiator cap just in case. nipper
96 OB Bad missfire after running a few minutes
nipper replied to xrturbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour not giving me a break are you? hehehe nipper
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGte yourself the haynes manual first, lets not start blindly replacing parts
nipper replied to xrturbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot the answer i wanted. hehehe swap wires and see what happens. a bad CTS may be making the car run too rich and that can make a converter glow red too
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you met my stalker that always has pictures? :-p nipper
nipper replied to xrturbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou cant test wires with just a meter. How about a new set of OE wires and a new set of plugs? nipper
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXto throw a CEL the car has to run x number of seconds, which yours is not doing. The regulator is under the hood and a very simple thing. Its a couple of fuel lines and a vacume line. Pokearound www.endwrench.com in the archives, there is good info. nipper
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone else will show you. I am on my laptop and dont have that info here. The CTS tells the car that its really cold, so it needs to run richer then usual to start up. Then once the car starts to warm up it adjusts acordingly. If you have a dead spot in your CTS range, the car wont start. The crank and cam postion sensors will kepp the car from starting at all, so they are ruled out since yours fires and stalls (for now). nipper
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo late for gasline antifreeze. If you have 10% ethanol in the gas its not needed. Fuel pump is accessed from the top of the car under a floor plate. Do not replace the fuel pump unless you have confirmed no flow. A coolant temp sensor can keep the car from starting, as well as a bad fuel pressure regulator. You may need to put a fuel pressure gauge on the fuel line to check the pressure. WIth the cover off of the access plate, you can have someone turn the car on and try to start it, and you should be able to feel the pump run. nipper
nipper replied to littlegto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats why i was curious if it would run at air temp nipper
Need a little backup on the off-road ability of roos
I agree (thats with stock tires) nipper
Strange sound when downshifting
nipper replied to mckay's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSadly this is true, when did GM first buy into subaru? maybe its related nipper
