25
Everything posted by nipper
You know i've been noticing over the last few months how snotty some of the posts are getting, first off i am trying to help you , and th no s**t sherlock comment was UNCALLED FOR. Now if YOU did do the reading on torque bind you WOULD have noticed that rebuilding the AWD unit on cars over 100,000, some close to 200,000 is perfectly justified. You would also see how to test the unit, and also find out that by putting the fuse in the holder and nothing happening that the solenoid is part of the issue. Its funny, you remind of the kind of person that drives with the oil light on for several thousand miles then wonders why they need an engine. For YOUR information i had this done on my car at 186,000 miles. If you had this taken care of when it first appeared you would most likely just need a solenoid. If you really loved the car you wouldnt have driven it this long with a MAJOR problem. Also in your original post there is nothing about you having flushed the tranny. I am more then happy to help anyone on this, since it seems on this board im the TB expert, but you just pissed me off. So go have a good time trying to get it fixed yourself. Good Day.
First off do a search on torque bind. Secondly you have a pre 1997 1/2 tranny which is succeptable to inernal wear, and requires the AWD unit to be rebuilt/replaced for a cost around 800-1000 dollars. There is more to the AWD besides the duty c solenoid. there are seals and a spool valve. SInce you have been driving for so long with TB it is possible that the tranny has been torn apart. The clutchpack is shot at this point, so replacing the solenoid is most likely a moot point. You can try to replace it but i think the damage is done. There is no tranny additive to fix this, the first thing that shold have been done was to make sure all the tires match and are properly inflated. Second thing done should have been a tranny flush. The flashing light tells you the last time you drove the car there was a fault. The fault can be a stuck, open or shorted duty c solenoid. You can try to put the fuse in the FWD holder and see what happens, but again, i wouldnt get my hopes up. Best bet may be to find a used tranny, rebuild the awd unit on the bench, then install it in the car. nipper
Well this may be a little late, but check with the local BBB to see the companies rep. if you get a good report may put you at ease. What they will do is take the engine apart to find the cause, which could be as simple as an assembly error (it happens). The one thing about the boxer design is that its much easier to replace the bearings with the case split, and once you get to that point, its only another hour to do it right. nipper
i was going to jump in this thread, but it seems like its taken an ugly turn. Automatic uses an clutch pack that is varied between 10/90 to 50/50 using the TCU computer getting information the ECU and a few other inputs. The MANUAL uses a center differential which can be locked electrically. There is also a viscous coupling to give you a fixed 0/100 (all wheels spinning at the same speed, no power transmission to a slipping wheel) or 50/50 split, no inbetween. For those of you who did not read the first thread and keep insisting on installing the fwd fuse THERE IS NO FUSE IN THE MANUAL, and in the newer automatics i think they did away with it too. The manual lock just means that you dont have to wait for the wheel to spin to engage the AWD. Subarus are biased towards the front wheel drive. The symetrical drive applies the brakes at each wheel to help transfer torque to the non spinning wheel, this is NOT done at the transaxle. i am bowing out of this insanity, so everyone play nice. nipper
Fuel tank is 15.9 gallons. If you feel adventurous run it down sometime, you will see. Another thing you need to look at is does your fuel tank have any dents in it? That will screw things up too. Do a search on gas gauge/fuel gauge you will see many threads and possible solutions The techron additive works well. nipper
Personally, i have learned here and in life, never to assume that anyone has a skill untill i am corrected. i will ALWAYS start with the very basics untill someone tells me otherwise. On any given thread, there may be somone here just learning his mechanical skills. Also it doesnt hurt to review basics, as its sometimes good to be refreshed on steps you may have forgotten, as well as a new way to doing something. It's more then a bit self centered and pompus to think just because you know the basics that everyone else should too. I'ld much rather help somone who knows nothing and wants to learn then help somone that thinks they know everything. nipper
You should see all the nasty things the BMW list says about UK dealers. I've noticed i this case its not so much the mfg, as they are just doing what they have to by law, and nothing else. If BMW isnt rising to the occasion, i doubt anyone else will. This is more a reflection of consumer law. At least hee in the US and the problem is documented, you at least have something to stand on. nipper
