25
Everything posted by nipper
If it is an automatic change the tranny fluid asap, if it is a manual cross your fingers and hope. Also see about getting a spare that matches all the other tires. I'ld be more worried about the AWD unit slowly chewing itself up. Rear diff it it starts to devlop a whine or a roar you know youve done damage, as a drastic tire size differnce could do a lot of damage in the driveline, period. nipper
what model year and mileage is this? Did the donut have the same circumfrance of the other tires. I'ld be more worried about frying the AWD unit then the diff, unless the diff was a viscous rear and the tires didnt match. Diffs tend to roar when they die, and irs a slow painful process. You will want to have the diff lube changed if you honestly think thats what was smoking. WHat did it smell like, as gear oil ha s a rather unique smell. nipper
http://www.cars.com/carsapp/boston/?srv=parser&act=display&tf=/features/mvp/vpedia/viscous_clutch_popup.tmpl A limited-slip device that uses heat-activated viscous fluid to transfer power between two driveshafts Serving the same duty as a limited-slip differential, viscous couplings are most often used in all-wheel-drive systems in place of a conventional center differential: The viscous coupling connects the front and rear driveshafts and allows them to rotate at slightly different speeds during turns. But when the rotational difference between the axles increases, as when the pair of primary drive wheels slip, the viscous coupling then binds the axles together and transfers power to the opposite axle and wheels. “Viscous” refers to the fluid encased in the device, a silicone gel so sensitive to heat that it thickens and expands in fractions of a second. Metal discs on the opposing driveshafts rotate in this fluid, more or less at the same rate. When one set of discs spins significantly faster than the opposing set, it “shears,” or churns, the fluid. The resulting friction generates heat that causes the fluid to thicken and expand, which transfers the rotational force of one axle to the other, even though neither shaft is ever directly in contact with the other. The viscous fluid thickens and thins so quickly based on incremental temperature changes that a well-designed coupling can vary the amount of power it transfers to match the demand. Viscous couplings are simple but effective devices that require no sensors or computer control.
no upper balljoints, and ball joints cause the car to wander. 1- Check the torque of the lugnuts, over tighten them and you can warp the rotors 2- are you sure the new rotors were flat 3- inspect and rotate the tires, look for cupping or broken belts 6- check your cv joints 7- inspect wheel bearings nipper
heheh look up torque converter on the net, its 2:1 and they have gone as high as 3:1,2;1 thats the number its been for since the things have been invented. Thats the reason VW semiautomatics didnt really have 1st gear, and powerglides only had two gears, the torque converter is so good at multiplying torque its not needed http://auto.howstuffworks.com/torque-converter1.htm http://www.drive.subaru.com/Fall02_TorqueConvert.htm http://www.tciauto.com/tech_info/torque_converters_explained.htm nipper
Man do we know what they cost, they range from 800-1200 depneding upon location. I've heard some rediculous prices for VC from some bad dealers. My awd unit was 950 at 185,000 miles so im not complaining, thats a good run. Service life for the wuoto seems to be anything over 180K (educated guess) but can go far beyond that. On the manual till you drive on your first flat. The auto as long as the fluid is changed regularly they seem to last. nipper
