Everything posted by nipper
New "turbo-Acura" Outback rip off!!!!!
nipper replied to williamhilow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno but when they do break, it $$$$ nipper
Tranny?
nipper replied to Danbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXheat sheilds? nipper
Power Shift
nipper replied to jsaudy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpowershift BAD! that said its not a bad thing to know how to do. This goes along with double clutching. Power shifting has gotten me home on a broken clutch cable. Dad was a professional driver and taught me how. Now i am not responsible for you screwing up your transmission. when you shift normally, watch your tach. you want to keep your road speed steady and see how far the rpms drop. To powershift you must be able to do the same thing. If the rpms drop by 500, then you have to drop them by 500 using your right foot, and not let the road speed drop too much. Sometimes its easier to do it on a down shift then an upshift (only this time your raising engine rpm) . There is a sweet spot where you can put the car in gear. Do not force it, but you have guide it in. Grinding is bad. After a few attempts at this, if you cant do it, give up. Its not worth screwing up your gears. nipper
Torque Wrench use: converting foot pounds to inch pounds
nipper replied to jmickelct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi may hate math, but i am an engineer get yourself an inch/lb torque wrench also. i cant help much with this one as my arm is calibrated after pulling a wrench since i was 5 (god that will be forty years this 29th... eeeekkk) nipper
Hi- Need Some Help for My Dad
nipper replied to 85-325e's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe can also rent a reader from autozone and see things in real time. Then he can check the code when the light is on. i am pretty sure the gas cap does not apply to a 1998, as my 98 legacy would never throw a light with cap off. I think that hs to do with 2001 or newer. My gut feeling is a lazy 02 sensor is throwing a code. nipper
Torque bind--a couple of general questions, plus who to fix it in the Boston Area
nipper replied to mildbill.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdiff/vc is about 1000.00. Nothing else there to make the nois except a broken tranny mount to add insult to injury. nipper
nipper replied to jmickelct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's really very simple. Divide 1 lb by the surface value of gravity of the earth (32.174 ft/sec^2) to get mass in slugs. Then multiply mass in slugs by surface value of gravity of any other body of consideration (such as Mars) to know the weight there. And of course, it works the other way around too. For your specific question, divide 1 lb by Mars surface gravity and multiply by Earth surface gravity nipper aka mad sciencetest
nipper replied to jmickelct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEWWWW no one told me there would be math teachers here... thats it im leaving (hehehehehe) nipper
??? about the ej18
nipper replied to crazy D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso one enigine is a bigger bore then the other? HEY someone had to say it nipper
Vibration increasing during cornering and with higher speeds?
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand why not the front too? i did all mine when i had it flushed. nipper
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsolenoids seem to last for a long time that way, so a few weeks wont kill it, unless its already tired. nipper
??? about the ej18
nipper replied to crazy D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.cars101.com should have the specs. nipper
Removing Headlight Protectors
nipper replied to Benno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcall 3m and ask them, but usually heat will melt any glue. (heat = heat gun not torch) nipper
Anyone seen these valve covers?
nipper replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX96 required premium, after that they didnt. nipper
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn a way this is good thing. It means electrically your awd unit is working. Get the tranny flushed, leave the fuse in untill the new tires are on the car. Get it flushed after the new tires are on and cross your fingers.... nipper
trans cooler lrg or medium
nipper replied to 99subrew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot a link? mipper
Info on 2003 Legacy
nipper replied to briang@wybron.com's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif they had mismatched tires or drove on a flat, the AWD clutches will get very hot and burn the fluid. It will also turn the fluid brown. nipper
Quick clutch type question
nipper replied to Skid542's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles are on this car. All throwout bearings clip ont to the fork. The noise can be confusing, but subarus usually die by synchro failure, not a bearing failure. If you have a long hill, get the car rolling down the hill where you can hear the noise. Engage the clutch, and shut off the engine. Leave the tranny in gear. If its the tranny the noise will still be there. If its the hrowout bearing it wont. nipper nipper
Belt Tensioner Lock Nut
nipper replied to cannonball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah ok. The lock bolt, 20ft lbs on the torque wrench is fine, also using your built in torque wrench works well too. nipper
nipper replied to Skid542's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcable actuated pull style clutch. Look under your hood and see if you have a cable or not. Also since your going through all this work i hope your replacing the clutch too. nipper
Replaacing the Duty C
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXahh thats AIM
nipper replied to mildbill.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBad news, once Torque bind shows up in a manual, its already too late. Once you have torque bind in a manual, you cant make it any worse by driving the car, as its already fried. You need a new vscous coupling along with other parts (maybe a center diff). It is CRITICAL on a manual that all the tires are inflated the same. A automatic is much more forgiving, a manual is not. Driving on a low tire or a flat will burn the VC quickly. nipper
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell considering im not nipper on yahoo .. besides i was at the doctors all afternoon nipper
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi paid 950 including a transmission mount, so yes thats a good prive. Dont be surprised if they tell you you need a tranny mount. Its not uncommon for them to fall apart when the tranny is serviced like this. nipper
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno no not you, actually somone else who tried several things and variations. hehehe you i gave up on since you seemed heelbent for burning out your tranny nipper
