25
Everything posted by nipper
this is the best time to learn how to do one, as it goes under the heading, that you cant make things any worse, and have everything to gain. Just putting the timing belt on and cranking the engine you should be able to hear the starter working against engine compression to start. I'm going to modify my position a bit, go ahead and see if it starts, then you can replace everything, just dont drive it nipper
hey well it lasted a little over a week.
nipper replied to Tosh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes nipper -
AT Temp light
nipper replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
well its yesterday someplace else nipper -
AT Temp light
sure your just all screwing with my mind while im on pain meds.... your all out to get me thats it:lol: i know:brow: nipper PS its not a waste if you learn anything -
AT Temp light
yes coming on for two seconds then going off is normal. Coming on steady while driving is an over heated tranny. nipper PS did i loose track of this thread or did it shift gears on me? -
AT Temp light
Well i have documentation from you? that says 16 blinks mean that you have to play with the diagnostics connector to pull the codes. Once you get into the diagnostics then you have the blinky codes> it says it will blink 16 times 0.25 seconds apart after an initial 2 seconds on. i can send you the documentation i have. nipper -
AT Temp light
get the tranny looked at. This is NOT a light to ignore. you can ignore a cel if there is no drivability issue, or until inspection time, but ignoring that light, if its TB eventually the ar wont turn corners and you will have a 800.00 repair. Under the hood is a FWD fuse holder. Put a fuse in it. If the TB goes away your solenoid is fine, and you have a deeper i$$ue. If it has no effect it means your solenoid is fried and you get the cheaper repair. how long has this light been flashing? nipper -
AT Temp light
heheh have a seat grasshopper Do a search and there are pages and pages. I think im the resident expert on it, and today i got it (mumble) 3 days after the tranny light started flashing. If you feel a binding or sort of drag on tight Turns. It may be worse on one direction then others, but failry obvious backing out of a parking space. the car wont roll without you giving it gas, and then it feels like your pushing something. It can quickly destroy your awd clutch pack if it gets too bad. The normal way of fixing it 90% of the time is a tranny flush, but when the light is flashing you MUST have somone look at it if your not qualified, as you can make a 250.00 repair into an 800.00 repair. nipper -
AT Temp light
the 16 blinks tell you that there is a fault. then you have to play with the connectors to get the code, which is the grouping your talking about. Lets ask a basic question, how is the car driving, any signs of torque bind? nipper -
that should have nothing to do with it, as these engines go to readline at full throttle. Quick test is to remove one plug wire at a time and see if the noise changes. If its a connecting rod the sound will change. Main bearings are never an issue. The noise should be fairly steady and a knoc knock knock sound. If its not it may be a cracked flex plate. try this test then ill give you something else to try next. nipper
get an ignitor from a scrap yard, preferable a car that was totaled. i think bad ignitors amy be the reason some older cars get junked. Take the coil pack too, sometimes the coil will cure it. These are really hard to diagnose over the net nipper email me the zip i want to see it lthrpup@optonline.net
