Everything posted by nipper
ah yes, tuneups
nipper replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOE. Slotted rotors are good. Drilled are bad unlkess your 100% sure where they are coming from (same for slots), which ebay your not. They crack easily. nipper
CEL, symptoms...please help me decide what to do next
nipper replied to skizix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRarely fuel pump. You need a pressure gauge on the fuel line to see whats going on there, i bet its one of the sensors. Fuel pumps seem to run forever. Knock sensor? This is where my expertise gets a little thin. Have you cleared the puter and reset it? Just because the CEL isnt triggered doesnt mean there arent any stored codes. nipper
Just purchasad a Legacy and I have a few questions...
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be the flexplate then. There sint alot there to make that noise, starter drive, flex plate, heat sheild. Never take a sensor with a hole in it:) I think they mean the red light on the ecu. nipper
2000 Legacy developed rapid clanking sound
nipper replied to larrymc2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXconnecting rods (no push roads on an OHC engine) is a deep hollow knock. This can be a heat sheild, can be the starter drive, can be any number of things. Bad bearings dont sound tinny. How many miles on this. Does it change with the clutch or eingine rpm nipper
new Igniter with coil install?
nipper replied to brice k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIgnitor wont do this. Knock sensor can do this. You can fry an ingitor by leaving the car "on" and not running for a long time. The ignitor will make the car buck and kick stall or not run, it would be like running on 2 cylinders. This sounds more like your timing is changing. nipper
Fantastic mpg!
nipper replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin my 98 leagcy if i drove like a sane man i would sy 30-38 mpg. Too bad im crazy:banana: nipper
Security system TOO sensitive - any help?
nipper replied to luk631's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdissconnect it? I find glass sensors are far more easyier to live with then shock sensors. Odds are if they tow the car away, you arent going to catch it. nipper
Duty Solenoid - Help Needed
nipper replied to uletek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are a six solenoids in the tranny. He is talking about the solenoid that operates the lock up torque converter, the duty b solenoid. nipper
Help-Bought a Code Reader-Pulled a Few Codes to Fix
nipper replied to delli50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on this thing, and i dont recall the puter reading the oil pressure switch? How is your charging circuit voltage? Im suspecting a supply voltage probelm as there are some really odd ball codes on there. Didnt know the system read the ac pressure either Somethig doesnt sound right, i cant even find where those things intersect with the ECU on the wiring diagram I know the ecu could care less about the air conditionining. It never reads that. I know it reads the AC relay and the AC diodes. nipper
ah yes, tuneups
nipper replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIve installed the tweeters, it makes a big difference in sound. odd how my car had the premium sound system but no tweeters, its an easy install. Spark plug wires are OE, Plugs are OE (but not from subaru). Oil filters OE can be competativly priced with aftermarket, just dont go cheap. Use a brand name. Oil can be anyones, same with antifreeze tranny oil etc. Pads and rotors, unless your upgrading the rotors, use OE. Pads can be either, but never by the cheap ones, and go with name brand. DOnt turn the rotors as they dont always like it. Dums can be turned (but it rarely is needed) Anitfreeze every 2 years, tranny fluid every three (your tranny will love you). Do not use tap water in the cooling system, use deminerilized water, or pre mix. Timing belt, pcv and thermostat OE. Never use chemical flushes. General rule of thumb when replacing a part, if the original part lasted over 100,000 miles, replace it with OE (as they must be doing something right) Timing belt, for your car every other one replace cam seals, main seal, water pump tensioner and oil pump seals. At 200K (or near it) by your car a gift of a new oil pump. Watch your temp gauge, dont let the car over heat, and it will run forever. If it does overheat, change the oil when you repair it. if you see your temo gauge go 3/4 up, the ac cut out, then go down, you have a clogged raditor or the fins have fell off. All 4 tires should match and be within 1/4 inch of wear around the circumfrence. Keep them inflated the same. Thats all i can think of. Im sure somone will chime in and say im wrong (that never happens hehehehe). nipper
Wind Noise
nipper replied to excal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa lot of convertables do that now nipper
nipper replied to skizix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to subarus and the forum. TPS is a throttle position sensor It is a variable rehostat that tells the car and the transmission throttle position. nipper
Drive solenoid C & Torque bind.
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is the FWD Fuse. When you put a spare fuse in that holder the FWD light will come on on the dash. You use this fuse when you have the spare tire on thr car, or the car is going to be towed by the rear wheels (which is no longer revomended, a flat bed is). The fuse energizes the Duty C solenoid, which in turn kills the AWD completly. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXare you talking the individual fuse holder on the passenger side of the car towards the firewall? nipper
What's the advantage to "Manual" mode?
nipper replied to Vez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes they now put rev limiters in the puters so the forced upshift is no longer needed nipper
Get out your decoder rings ... (tranny)
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks ill read it later. I have zero torque bind and the car is shifting fine, so i am a bit puzzled. nipper
After Water Blasting The Carbon... Less Slap.
nipper replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust the last time i did it on a non cat car i smoked out the neighborhood nipper
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be vent hoses Pulling it out it may seat properly but when activated electrically it may not. Does the starter look new? nipper
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX97obw 184K just 16 straight flashes nipper
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1- chewed up start teeth means the drive is rubbing against the flywheel. It can be a tired or worn drive or tired solenoid not allowing the drive to come all the way back in. Fuel pump is in the tank, but it is SO easy to get at. I would look at the fuel pump relay first (hrmmmmm). The pumps are fairly bullit proof, and you cant tell anything without a pressure gauge. nipper
@@@ !!!Subaru Justy!!! need recruits @@@
In the US they stoped making the justy as we know it in the early 90's (94?). it was a unique US spec. The justy is alive and well in europe but its a suzuki metro rebadged. http://en.wikipedia.org/wiki/Subaru_Justy nipper
Alas i think i have to the blue to the sooby doctor. This just started todaym, and doesnt do it all the time. Start the car, the tranny light flashes 16 times then goes out. Duty C Solenoid? I have no torque bind at all and still under doctors orders not to do anything (and the 1 year mark is coming up oh joy). So do i have to take out the plastic or what? nipper
Tons of manuals and parts sheets, you may want to sticky...
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif not a sticky, post it in the conversion section under conversion help i am sure they will apreciate it nipper
Umm,interesting...
sounds liike a modern marvelous mystery oil nipper
mechanic recommendations
nipper replied to chilyb56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlakeside shell (trenton/hamilton) used to work on my car all time when i lived in that area i liked thier work nipper
