Everything posted by brus brother
Airbag light on: two codes for seat belt and control module
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes this by any chance have the overhead map light/warning module. My 05 OB had a similar problem and it turned out to be some electrical gremlin in there giving false readings. Replaced unit, 2 screws 2 connectors $85(IIRC) out of pocket, and problem solved.
deer 1 01 outback 0
brus brother replied to 01 Outback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPhew. At least you didn't end up lap dancing with the deer. Wishing a speedy recovery for the OB.
Just bought my son a 2001 Forester. What should I ask my mechanic to look at?
brus brother replied to nitroman58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRear diff unaffected by TB or HG work. Honestly I am ashamed to say I haven't done my diff fluid in ... well never. Note to self... If you just do the timing belt, the oil/coolant won't drain out. If you decide to do the TB and HG together, the coolant will be drained out and can be changed at that time. Once they open up the engine to do a HG job, changing the TB and idlers is right there. In other words, they have to remove the TB to do the HGs. 200 miles isn't that far BUT as I said earlier, not knowing the history, you can't predict when the tb or idlers will give out. If the TB snaps or idlers give out and the engine jumps timing, you will smash the valves and cause serious damage . Search "interference engine". After you do some noodling of the car's history, if the TB needs to be done, have the car inspected for any seepage around the area of the HGs. Even oil seeping will be a nuisance once it starts dripping on the exhaust. If finances are limited at this time, just do the TB/idler but if seepage, consider that you are halfway through the engine labor wise and should do the HGs. Once done, you will have 105K miles of worry free driving. You can then post something like "Nothing wrong with my car, just lonely so I thought I would visit the USMB" Best of luck to you and your son. There are Subie mechanics at my local dealership that work after hours so I would ask around if you can't find a reputable indie with Subaru experience.
brus brother replied to nitroman58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA mechanic familiar with Subarus (independent or dealer) would be best able to diagnose if there is a budding head gasket issue. Are there any maintenance records that would indicate if the timing belt/water pump were done? Subaru of America may be able to access these records for you based on VIN#. Common wisdom on the site is to do the HGs when you do the TB and replace the stock HG with the version designed for the turbo model. Definitely adds to the expense but also adds to the peace of mind. There are many discussions on the issue here at USMB. It may never leak, it may leak next week. This site gets reports and discusses problems. I am sure there are people driving around blissfully unaware and may never have the issue OR never think to report the issue when it occurs. I have never seen any threads here from people who were seeking advice for a car that was running perfectly with no issues. Don't mean to be an alarmist. Just mean to inform you here. Sincerely hope your purchase is worry free but for expert advice (mine not necessarily in this category) the members here are extremely helpful and generous with their expertise.
brus brother replied to nitroman58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board. Did a mechanic knowledgeable with Subarus check the car before you bought it? This era needs a conditioner added to the coolant system to forestall external head gasket leaks. Check to see if this was done as I seem to remember it was part of a recall initially. Subsequent coolant system changes would need it added again. The common area for this leak is at the rear of the engine on the drivers side, though there can be seepage elsewhere. Check the CV boots to make sure they aren't torn. Small fix now before the joint gets all gritted up. Check all fluids. Rear diff as well. When as the timing belt done on this car. While they are scheduled at 105K miles, a 2001 would be overdue considering the years. Good luck with the car. It has some serious storage room for your son to haul crap back and forth to college.
click click from rear on tighter turns
2005 Outback AT It's a little too cold to be climbing under the car right now, but would appreciate some tips on where to look. Sounds like when front cv joints are going bad... thought the rears were indestructible. I guess the grease wouldn't cook on the engine back there so there hasn't been any of that tell tale smell.
Mouse in vehicle
brus brother replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSnap traps. Peanut butter.
cabin air filter missing
brus brother replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/19317-diy-2005-outback-cabin-air-filter-replacement.html You might want to combine the two posts you started or delete one. As I mentioned, the early 05s had a design flaw that hindered installation of the tray that holds the filter. The above link (googled subaru cabin filter replacement) describes taking apart a great deal of the interior as well as someone who just cut a hole and slid it in.
brus brother replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI went through this exercise with my 05 OB. There was an engineering flaw in the original 05's that prevented the installation/retrieval of the cabin filter, so they just left it out! I will look later if I still have the invoice for the parts. At the time SOA paid a portion of the bill for their tech to do the job. As I recall, there is a retrofit apparatus that allows the installation of the filter. It was a real pita to do the job and I haven't changed the filter since...
Losing brake fluid without obvious leaks
brus brother replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad you can't use pex like tubing where the lines are within the car and then slip a braided metal protector over the exposed areas. Easy connection and routing. Now that would be simple AND be impermeable to the effects of salt.
brus brother replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.nbcnews.com/business/autos/subaru-recalls-660-000-autos-brake-line-rust-n147361 The above recall affects 2005+ cars but I would certainly call SOA and cry them a river... how you've been a loyal customer blah blah blah and ask them if you should contact NHTSA on their behalf since their cars are meant to stay on the road for many years and how many other owners are unaware of this serious condition.
Remote entry 08 OB
My local subie dealer's parts department scrounged up an old key like mine from their junk draw and said I was welcome to the circuit board. Now that's service! Ooops. Went to pick it up... wrong key case. Just bought one on eBay for $18 shipped. It is a used key but I only need the innards and not a blank key to be cut.
Remote entry 08 OB
Keyless remote was not working on my 08 Outback. It's the square key with the 4 buttons pictured below. Battery was weak so I changed it. Followed the instructions in the manual. Tried syncing it using the press unlock or lock six times but still didn't work. Tried reprogramming the system using the owner's manual procedure and it accepted the code but still doesn't work. Key works to lock car/start engine. Any other suggestions? I see there is a circuit board internal that can be changed out but haven't been able to source this. Any suggestions or one for sale?
Noticed PS front/rear floor carpet was wet, just checking if this could be something more serious than...
I seriously doubt the few drops driven in a car wash are indicative of the source of your problem. I get that on my car on the rare occasion that it goes through the wringer at the dealership (free washes with my lifetime free oil changes deal). One problem at a time now. If you are talking about wind noise from the windows, the likely culprit is the triangular piece in the corner of the window. On some cars there is a tweeter installed in this triangle. Anyways, this piece gets deformed from people closing the door using the window or pressing against the window when getting out of the car in tight spaces. My 2005 Outback had this problem and after a tech replaced this piece under warranty, he showed me how to pinch the piece back into shape. Result was no more wind noise. I posted the technique at the following link with pictures. http://www.ultimatesubaru.org/forum/topic/4377-drivers-window-wind-noise-fix/
Did you make sure the drain hole at the cowling isn't clogged? Pour water into the area where the little hole is. If it drains beneath the car, look elsewhere for problems. If your passenger side floor gets wet...
See post #3 in this thread for clarification/suggestions.
Did you try pouring water in the hole in the lower corner of the cowling below the windshield? It should drain out behind the fron wheel.
2010 Legacy low beams unsafe
brus brother replied to snakedoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://static-forums.fatwallet.com/static/attachments/439521_scan_pic0001.jpg The above link has coupons to a variety of somewhat useful stuff from Harbor Freight Tools. Coupons are valid until 2/15 The coupons are for FREE items and some require no purchase. Walk right in take coupon or scan from smart phone to cashier and you're on your way. There is a multimeter in the mix that you should have in your kit and learn its applications. Free with no purchase required. It's good enough for what you are looking for here. I wouldn't trust their torque wrench if you were doing HG's but a free wire brush or pick set or a tarp, count me in.
2005 Legacy head gaskets
brus brother replied to farmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the 05 OB. The HG leak on these cars is external. Adding Subaru's coolant additive should cover you there. You will get some oil seepage though. After doing the 105 mile TB service, I developed an external HG oil leak that drips onto the exhaust. When it's time for the TB service (105,000 miles OR 8 years) have them do the head gaskets, using the turbo gaskets as described on USMB for added assurance. BTW, I bought that same car for my daughter when she was in high school. It is one zippy little car compared to the OB. When I sold it, there was signs of the oil seepage beginning on the car.
does anyone happen to know what tools (wrenchs sizes, etc) I need to remove the battery cables on a 91 legacy?
Your question was what was left "open"... to interpretation. Below from The Pink Panther Strikes Again: Clouseau: [sees dog in hotel lobby and directs question to clerk] Does your dog bite? Hotel Clerk: No. Clouseau: [bowing down to pet the dog] Nice doggie. [Dog barks and bites Clouseau on the hand] Clouseau: I thought you said your dog did not bite! Hotel Clerk: That is not my dog.
Brakes Squeal
brus brother replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was exactly what I experienced when my pads were binding in the brackets. Not sure what was rubbing but once I adjusted the tabs to allow the pads to float free the noise disappeared. Initially, I was checking around to see if the dust shield was rubbing as this had been mentioned somewhere in my reading but it did turn out to be the pad fit. Check to make sure you don't have any rust lodged in the bracket area.
Brakes Squeal
brus brother replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a similar problem. Turns out the pads were too tight in the brackets. Check to make sure the tabs aren't binding. I had to take a file to remove some of the excess paint and the squealing stopped.
ooops exploding airbag recall
And here all along I thought this was a Subaru site?! I haven't owned anything but Subarus since 1984 so I wasn't much interested in those "others".
Subaru: 17,516 total number of potentially affected vehicles 2003 – 2005 Baja 2003 – 2005 Legacy 2003 – 2005 Outback 2003 – 2005 Baja 2004 – 2005 Impreza http://www.nbcnews.com/business/autos/list-recalled-vehicles-potentially-faulty-air-bags-n230741Check your VIN here : http://www.subaru.com/vehicle-recalls.html
Exhaust repair 08 OB
Well, since it was impossible to access and super clean the area for JB or anything for that matter (hindsight I guess I could have sandblasted the area) I am counting on the tenacity of the silicone to bond to the adjacent rusty exhaust pipe and seal the crack. I extended the silicone beyond the thin crack and am hoping that the flexibility of the silicone might work to my advantage. If the bandage fails, I will arrange for a buddy with a lift to cut open the bottom brace enough to get rid of the silicone and weld the crack. Likely, this methodology will not make it to the Subaru Repair Manual section of the site. I was just glad that there was a high temp silicone to try out.
