Everything posted by xdeadeye1
You might try checking the cam bolts. Make sure you seated the cams in the correct position, and that you torqued down your cam bolts. I would also check the crank sprocket. check that you are indeed using the timing mark on the very back of the sprocket and not the one up front of the sprocket. Did you have the intake off the top of the engine? Check the "crank sensor" that it is connected.
had no other problems of this type. I THINK I remember a woosh when I take the gas cap off. Ill look at the seal on the cap.. Its stock plastic one. Don't know about the filler tube. but no this is a brand new thing,, out of no where. Any idea where this fuel tank pressure control solenoid is? ,, I thought I might check that somehow. with a mulitmeter ? Ill see if I can find it in the Haynes manual.
96 legacy wagon, 2.2, Automatic . hi guys,, driving down the highway.. listening for a bearing in my front wheels.. felt like a tire was low. Pulled over looked at them,, maybe a bit low.. no biggie. Jump back in ,, on down the round and the CEL light came on. Temp was ok.. So I went 5 miles to auto zone,, had them pull the code,,, it came back with P1401. Fuel tank pressure control system function problem 1. open or short circuit condition 2. poor electrical connection. 3. Failed fuel tank pressure control solenoid. Any advice ? Just fishing from you guys because well,, lets face it,, most of the time you all know the deal already. Thanks!
96, 2.2, automatic Mine was doing the same thing. 175k miles. I put new head gasket in. No more problems The water pushing out into the overflow due to gas bubbles escaping into your coolant via the bad Head Gasket. As fast as yours is doing this.. start the car let it run for 2 min. Then have someone step on the gas and look inside your overflow tank.. If you see bubbles ,,,its head gasket.
Got it started and drove it. (I stole 2 bolts out of my parts car I forgot about) Anyway a couple of questions. 1. I think my valves are ticking awful loud.. Sounds a bit like a diesel. Will this go away,, Is there something I should do? 2. My Fans are not turning on. My Freon apparently leaked out and I have no AC.. But I thought the other fan ran all the time. ? I just put in new stant T stat and Water pump . 3. The Temp gauge in the car stays at normal exact spot. Never gets hot. Had it idle for a good while then drove 3 miles into town, got gas,, came back.. No change. Coolant is near capacity, bottom hose and top hose are warm/hot. 4. Should I check my fans somehow? I checked fuses , all good. Thanks for input!!
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
everything done,, get down to bolting on the throttle cables. not sure if I have the right two bolts... I try em,, one bolt falls on top of the block somewhere.. cant get a wratchet or a nut driver on them,, other bolt wont go in,, seems cross threaded.. tried to use a dye on the bolt,, I think I got the wrong pitch ,, I tired a 6 mm 1.0 pitch, and it seems worse. SO Fail sauce. Everything,, I mean everything Is done but that... Now I gotta suck it up and call Subaru and pay 5 bucks a bolt or something for repleacements.. otherwise happy 4th.. I live to try another day.
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
Been putting this back together a little at a time and re building the front axles too. Going to swap sides with them.. I am actually just rebooting them with a kit from R.A. So once I get those in today, Put back the air tube and all the vac hoses off of it, Fill with oil and coolant.. Its D DAY..!
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
