montana tom
    12
Everything posted by montana tom
  1. Make sure the large connectors at rear pass side are snapped together well. Then check crank and cam sensors are connected.
  2. I have been asked if my 00 2.5 obw has a turbo because of the whistle like noise under hard acceleration. No noise at all while parked. Sound file appears but says it is not supported.
  3. Could something (nut,bolt) have fallen in the head while reassembling ? Hot cat sounds like its dumping fuel in # 3 for some reason. Check compression I bet #3 is low. Maybe you bent an intake valve ?
  4. Booki; The overflow tank is not the place to check coolant level... You must look in the radiator .
  5. Mike if you haven't already bought them , you want NGK plugs and NGK wires. No need to tell us about your salad ...
  6. Yes ,i'm wondering about the head gasket... overheating gets them more times than not. oil and water do not mix on this motor when the head gasket is shot. Car will run cool until you lose enough coolant. I'm also still thinking valves . Compare all the plugs to see if any are different. By the By, remove and clean your grounds , both ends ... clean and tight. Not just the battery but the smaller grounds as well. .. could help with your scanner and if bad enough could cause your miss ... but I doubt it. I still think there is a compression check coming in the near future.
  7. Bad deal , that overheat... how hot? Good to confirm your scanner is OK. Spark plugs will show you something and while they are all out I would do a compression test if you can.
  8. Not sure why the scanner isn't working... but with the backfires, I would look at the timing belt, if that is in time then , I would swap out the cam and or crank sensor with known working ones. Then check compression ,it could be valve lash... anybody checked the valve adjustment EVER ? Common on this motor for the exhaust valves to go tight and burn the valve seat. That shouldn't keep it from starting though, just run like shxt. Have you tried that scanner on another car ?
  9. Head gasket. Turbo would blow a cloud of white if it was leaking. Bright light , inspect the bottom side of the heads where they meet the block, chances are you will spot a very small drip. If you don't see one look on your exhaust system for stains. That engine if the head gaskets leak it will be external.They drip on the exhaust burn off and leave the slight smell of anti freeze.
  10. Why they reproduce of course! Darn my photo didn't attach. Edit) tried again ... must be considered over 18 adult content... LOL or may be its too big.
  11. Check coolant, if full, I would get a new subaru thermostat for it. Weird it has only done it by the factory's... Maybe secret government facility. Beware !
  12. Heater not working well means you need more coolant. Filling from the radiator is a very slow process. I fill the engine from the upper rad hose, then fill the rad and it still takes time to get coolant thru the whole system. There is a sensor plug in on the coolant crossover pipe you may have forgotten too plug in. Located under intake manifold on the pass side , near the main electrical connectors .The fuel gauge ?? who knows... you could have fried something by shorting... its possible but I doubt it.
  13. From your description , I would have to say your trans is shot. Triple check the throwout fork for cracking / bending but.... I'm thinking its DOA
  14. Amsoil makes awesome products! Is the Wix considered an acceptable replacement over the factory screw on filter ? I was under the impression that none of the replacement filters were even close to the quality of stock.
  15. Double check your connections are tight. Passive bleeding procedure. Fill master cly. Open the bleeder on the rt rear . Pour a cup of coffee ... sit down and wait. Fluid should start to flow ... close bleeder , let the same thing happen on the left rear. Check pedal . If necessary do the same in front. If you get fluid gravity flow at all wheels and still have no pedal and no leaks , suspect your master.
  16. The last place I install the belt is the pass. side upper idler . start the bolt well but leave it loose. This allows some slack, also the rt side cam is unloaded .I start with it just off from in time and allow it to roll the that last little bit into time as the belt slips over. Some folks leave the pass side lower idler off completely until they have the belt in place ... never helped me but may help you. Be sure to tighten all idlers before releasing tensioner, roll crank around two complete revolutions by hand to check timing marks and your good to go.
  17. My guess... Ice buildup at the selector switch keeping it from traveling all the way into park.
  18. Run an add in craigs list under auto parts and another under subarus for sale by owner. Offer the whole car for a good price. Depending on how fast you want to move it ,realistically if clean with gd tires and a clean free title it should be worth 1500.00 but you may ask to get 2000.000 , you also may only get offered $500.00. On a C.L. sale only take cash .
  19. 95 has no obd 2 , makes things a little harder to work out. Your knock sensor is a likely suspect for sudden poor fuel economy. Easy to change , other than getting that darn connector unsnapped. No need for OE hit ebay or rock auto for one. Low fuel light should have no bearing on poor performance. If it seems to run smooth ,no shakes then try changing the knock sensor.
  20. I always prefer oe ,available on line around 75 bucks. The 2.2 is more forgiving than the 2.5's and the felpro should work fine.But personal choice for me would still be oe.
