5
Everything posted by Scott in Bellingham
this is what I did along those lines, it only has a 2" suspension lift with 27" tires
WCSS10 Location and Date Set!
Scott in Bellingham replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
what will it be like?? -
OK Zap what would you suggest?? , Im looking for a tire thats good for everyday on the road but preforms well ocasionally offroad, I dont want a real agresive tire thats heavy wears quick and gets bad gas mileage
whose running BFGs all-terrains, ? what do you think ? also where a good place to buy them ? what size ya running? Pictures? thinking this might be the route to go on my daily driver
how many Watts on that CB??
on the 4" EA82 lift you can go 3" at the engine crossmember, and 2" at the radius rod, on my white car I have a 3-1/2" lift at the struts, 2" at the engine and zero at the radius rod with a spacer on the rod to bring the tire forward, , now on the radius rod go 2" and it will be fine ,. If you want just the strut mount peices and weld in your own pipe we can do that
this guy made what your talkin about, you might consider a Dual Range transmision for lower gears
Sideways Action! (always use a spotter)
Scott in Bellingham replied to The Beast I Drive's topic in Off Road
excelent clearance modifications :banana: I have a few of those -
I wondered about that ABS unit if there was a way to use it backwards sortof
wow I totaly forgot about this thread, heres a cutter brake used on sand rails they work awesome for turning and braking . if there was a way to get more leverage out of this it should work, I had one in my first subaru but couldnt get enough force to keep that wheel in the air from spinning, since then have found that a welded rear diff is the way to go
carb on mpfi intake?
Scott in Bellingham replied to Jub Nub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here it is, machine work done, now for the welding, will ship out mid next week -
wheres the offroad modification sticky gone?
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
here it is http://www.ultimatesubaru.org/forum/showthread.php?t=24980 -
OK for a carbed setup.been years since I had a car with a carb, Electronic fuel injection is superior , I like it for offroad has alot of lowend power , the plus is simplicity -
What axles for a Dual Range into a Legacy
Scott in Bellingham replied to Scott in Bellingham's topic in Subaru Retrofitting
now thats what I needed to know thank you wheres the best place to buy and what brand?? -
installing a EA82 D/R into a 90 legacy, what axles do you use up front and what driveline ?
EA82 dual range 3.9 non turbo into legacy what axles do you use??? :cool:
cast alloy might break
