Everything posted by njdrsubaru
Pine Barrens Trail Run ***THIS SATURDAY Oct. 14th**** NY/NJ/PA/CT Northeast
its cool with me Neo
I hit a deer.
njdrsubaru replied to Tbird Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot to joke about it, but now u can have that Deer Sticker you always wanted on your door!!!
How did subaru increas the ground clearance on the new outbacks
njdrsubaru replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgave it some Roids???
Alrighty... when?!?!?!?!?!?!? I'm in Joisey and not far from the Barens.
H6 Swap...
njdrsubaru replied to BruceyWV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXValve cover gaskets and Spark Plugs while the engine is out!!!!!!!! will save you lots of twist moments under the engine bay since the H6 sits very close to the frame. Good Luck and keep us posted Neo
Moving to the next generation--95 Legacy
njdrsubaru replied to ogiesdad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats, you've just bought a car for the rest of your life!!!!!!! hahahahah, i got an 2.2 95 legacy wagon and they are great, lots of cool things you can do to it. Good luck! Neo
Outback struts on a Legacy? YES!!! Thanks.
njdrsubaru replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah i had a spider bite on the neck, ended in the hospital almost causing my life, not too long ago. its nasty! ANTIBIOTICS ALL THE WAY!
njdrsubaru replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk ok i did a swap myself http://www.ultimatesubaru.org/forum/showthread.php?t=62911 all u have to do to get the strut to line up with the hub is to have someone push the hub down with their feet while you are down there you are trying to align the strut and put the bolt in. Fairly easy when there is 2 people working on it, i did my swap in 3 hrs tops, i think it was less than that but on well, make sure you mark the bolts up top before removing the old strut (front) so when u put the OB struts in, you can try to line up the bolts to the original location and therefore not needing an alignment. also in the front be carefull with the CV axle, DO NOT pull on it too hard or it will pop out of the diferential, it happened to me. large Pry bars are a very helpfull tool on this swap and PB blaster too. good luck and let us know how it goes Cheers Neo
i'm IN with my outbacktified legacy!
Dammit! i got a water leak!
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok I found our problem!!! for most of you that had your windshield replaced or have worked around the wiper linkages.... when they replaced my windshield they had to get the cowl cover out of the way to remove and install the windshield, so.... the clips at the ends that holds the cowl in place must be resealed once removed or you'll have water leaking right into the HVAC air intake, so i sealed that hole and the other ones under the plastic cover and it worked!! Also make sure to remove your FAN behind the glove box and stick your hand in there and pull the leaves and crap that is in the a/c condenser, i had alot of crap in there and it was smelly, yuk!! then put everything back together and enjoy a leak free car. :-p
ok ok sorry for cursing, but i cant find the origin of the leak, i've checked the sunroof drains, the HVAC drain, the firewall for wetness and the ruber grommets around the doors and all the cables in and out of the car. SO I HAVE WET CARPETS ON DRIVERS AND PASSENGER SIDE!!!!!!!!!! back in July i had my windshield replaced because of a branch that fell. i checked everywehere for a leak on the windshield seal and nothing. Does anyone have an Idea where that water is coming from? its the second time its happened and everytime right after a rain storm. Plllllleeeaassseeeee HELP! i hate wet carpet smell cheers Neo
Need some help! EMERGENCY! car in- need tommorow!!
njdrsubaru replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe opening by the belhouse on top of the engine you'll seea square window leading to the flywheel, it is on the right side of the throtle body
njdrsubaru replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have done many timing belts on subs and i have always jamed the flywheel with a prybar and tighten it untill you cant. it did work for me all the times. the opening by the belhouse on top of the engine you'll seea square window leading to the flywheel cheers Neo
She's So clean! Few More Pics added
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah opppsss i forget that i had to write something up and get some pics of the install
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlol i did get to paint them but the paint match was sooooo bad and i decided to keep them black so i striped all the paint and reinstalled it
ok well i've added the headlight washers, jdm belt cover and auto dimming mirror, and off course you have seen the gauge pack. Oh and I decided to wax her today so here it is. enjoy!!
"Whirring" noise under the hood?
njdrsubaru replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalt or PS pump for sure
trans issue legacy ss
njdrsubaru replied to xrturbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've had problems like that because of the TPS sensor, i've had many SS and almost all of then had that problem except the last one
new toy
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi john Yes you have to run the supplied harness through the firewall for the sensor that goes by the grile. all you need to do is to pop the ruber plug right above the brake pedal on the firewall and that will be right under the brake booster, so just shove the wire throught there and you'll see it in the engine compartment then pull it carefully untill enought is needed to route and reach the center part of the wood latch. More info is here. this guy did it with his WRX and it works the same for us, just the unit placement for the legacies is right uner the radio. http://www.scoobymods.com/forums/archive/index.php/t-1203.html BTW it is not a major mod. to do, if you can swap radios you can do this. :-p good luck and let me know how it goes, i'll post pics of the installed harness soon cheers Neo
new toy
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits not hard at all do install it comes with the harness to connect between the radio and the car, and that harness is a "plug and play", the only "difficult part" is the cable for the temp sensor in front of the car by the grill, which wasnt hard for me but it may be for some people
new toy
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits about $81 at subaru-parts-dealer.com
new toy
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcompass, outside temp and barometer
new toy
ok i got a new toy and it fits perfectly, the connections that comes with it, plugs right into the harness of the car radio, while sharing the same harness you cancontroll the brightness of the light too, oh yeah its the gauge pack for the forester, part number H5010FC001. take a look and gime your comments, also i have included my red lighting gauges EDIT: of course it is installed on my legacy wagon cheers Neo
Something I did NOT need to know
njdrsubaru replied to Hotshot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso what people, subarus are great cars, gays not only drive subarus but they drive volkswagens and Audi, and pontiacs and so on. I am Gay and I drive a Subaru But i dont only drive it because the company supports the gay community, i drive it because they are great and reliable cars and easy to work on. and above all i love it. PS: gays and lesbians are humans too. cheers Neo
Outbacktification Process STATUS: In progress, now with pics
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell talking about tires, i went to get my tires balanced today, also i asked them to check if any alignment needed, so they got the car on the aligment ramp and sensor on the wheels, and guess what.... NO ALIGNMENT needed. yay!! well i swaped the struts i marked the 3 bolts up top with a sharpie so when i put it back together i put exactly where it was and i guess it worked.
