Everything posted by ericem
legacy turbo.
ericem replied to jrcrum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Kind of disagree with the cooling system comment. Seems like the cooling system's on these cars are extremely stout. The nipples on the water tank only crack if you stick your hand in there to replace that knock senor and hit the nipple, they don't just crack. The hoses seem very good too, but if you touch them they can create problems. -
ABS died?!?
ericem replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Do you hear the pump still running after you shut off the car? Check your battery voltage too! -
ABS died?!?
Did you try restarting the car? -
bad svx trans
ericem replied to TN svx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I am sure it can make it if you change your fluids often, coast down hills alot etc. -
ok, doesn't seem like its leaking any other seals that I can replace on the pump? I am thinking ill order the main seal, there is one between the block on the pump, and how about those oil plugs that are all wet with oil must be o rings in there, and the part aiming at a 45? Then RTV seal it back in place I guess?
Hey guys need to drop this motor in ASAP like hopefully this friday! Want to get the few oil leaks sorted out. I will be replacing valve covers seals, rear cam support gaskets, and oil drain hose, TD04 turbo etc. All hoses seem nice and soft! Water pump and belt and idlers appear to be new for a EJ22T out of a 92 legacy wagon. Oil pump leak...
