Everything posted by ericem
Sounded like a fork in the In-Sink-Erator
ericem replied to Sagebum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is very possible there is a flying cover that is usually missing on the bottom of the trans bell housing an the flywheel is exposed. So if I rock is thrown in the area will shoot up and land in various area's till it drops out somehow! I would give it a few WOT runs then some normal hilly driving. See if it does it again. If not have no worries!
Top speed on 94 legacy sport
ericem replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if you will actually find the car any faster with the DP. My friend bought a DP for his SS. I will tell you if the car feels any better. It should though as our cat's are pretty old and I am sure they are partially deteriorated.
ericem replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso has alot more rotating mass in the torque converter probably with auto.
ericem replied to martimus919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould pull nicely when running with no vacuum leaks, on my car I have the same setup except 440's, and I am running completely stock exhaust and both resonators in place. The power is intermitent doesn't always pull perfectly. although I was told i might have low compression in my motor so doing a motor swap Regardless for the while it was working good, it pulled like hell on the highway was very good too. I think the IC has a speed rating though. After so much speed it is like hitting a brick wall if I understand correctly.
93' legacy dash light are out........
ericem replied to Sparkystours59's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow your fast!! Good choice. Nothing like drinking coffee while some other guy does your bulbs. How many Subaru guys does it take to replace a dash bulb. 2 one with the cash in hand one with the interest in replacing them in 20mins.
ericem replied to Sparkystours59's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPretty good price at a dealer right?! Id do it real pain in the rump roast. On my last car got the dealer to do it, they did a awesome job. On my turbo sedan tried it. I have no clue how I even got out the whole plastic cover around the cluster. I must have bent it so far it was crazy. Also try hitting the dash board they usually start working for a while.
thumping when driving from stop
ericem replied to Suby Skier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust find a used shaft thats all!!!!
Can't figure it out!!
ericem replied to Jmiller1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting. My old 93 legacy N/A had 330k + and it was overheated many times when the waterpump was leaking like hit H and engine started bogging. For a good week drove like that. Then put stop leak in that car, clogged up the entire system and still kept driving overheating. Then eventually got the pump, and belt replaced, and just flushed everything else. 3+years driving 250 to the 330k NO issues with overheating never touched anything had original rad cap, thermostat etc. I would suspect a bad rad though with your car. The cores could clog and when a couple cores clog I don't think it is that easy to unclog. I would just get a used rad to test things.
ericem replied to Suby Skier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just bought a 92 legacy wagon turbo and it has a similar issue and I went under the car to shake the shaft. Has noticeable side to side play. Interesting how at speed it is very smooth though.
"steel seal" anyone try this on a phase I HG problem yet??
ericem replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWouldn't you feel better just doing the HG's and getting on with life?!
High Idle Problems
ericem replied to hustle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno EGR on a 1st gen OBD1
traction control and snow.....
ericem replied to obk25xt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou know what I think I am wrong you only have traction control which will do nothing you can't do by simply letting off the throttle. http://www.cars101.com/subaru/outback/outback2008.html Traction control just makes sure the wheels don't spin but you can still roll and spin out LOL VDC does it all though!
ericem replied to obk25xt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell your car has VDC I believe. Which will prevent the car from sliding sideways for example or spinning out. It does this by applying brakes to certain wheels. It does work and will save your rump roast. Try playing around with it in a parking lot. Although are you saying with it off it is still operating? Or you are just asking in general whether to leave it on because it sounds like you should leave it on the way you drive. It won't hurt saving your life and possibly others really.
Heat Shield Rattle
ericem replied to andrewmiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlol search there is probably trillions of threads about heatshields. and there rattling. It is the story of a car owner and his subaru really. Basically heatshields and headgaskets xD
svx in outback
ericem replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will fit just the rad needs to go closer to the front.
oil leak from timing belt cover
ericem replied to legacysubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably the cam seals or oil pump O ring not sure about the oil flow issue though.
The tally thus far..... '96 Legacy FROM HELL
ericem replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA VF11 can blow?? lol
How to store a Subaru
ericem replied to dcbpe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso wash the car really well especially the fenders and underbody, then get some rust spray and go nuts on w/e seemed possible to rust or is rusting. Some ideas, fuel tank components, gaps, fenders, etc.
YABHG (Yet Another Blown Head Gasket)
ericem replied to theidealist's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe might as well open a whole category just for New gen headgasket issues. There is sooooooo many damn headgasket threads it is just unbelievable!!
2006 Legacy hot air on driver side, cold air on passenger side.
ericem replied to Pinegrovesubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does bars stop leak look? Is it milky or like antifreeze but a additive??
ericem replied to Pinegrovesubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ same question LOL thats insane your car will need insane amounts of flushing to get it all out. It was difficult to get mine out with just ONE bottle eek!!! Why on a new car anyway?!!
ECU fan relay location?
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYa but I am using my computer to read the temperature coming from the engine and I can see the temperature of the engine is not coming down sometimes. Sometimes fans come on and stay at 200F and wont drop to 190F like it should. Unless that is how it tells the fans to run and it inputs the tranny and engine temp together?! If it matters tranny is slipping noticeably in some gears on and off, no awd, and winning. Tranny will be changed ASAP though.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need a new ecu coolant temp sensor.
Thermostat install
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm well i guess ill try flushing the overflow lines and clean the tank.
Thermostat install
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXat 1800rpm with everything on its 13.5v. at idle with everything off it can do around 13v. Today fans didn't cycle at all temps stay in the 200's. Today it was from a freezing cold start. Is it possible the headgasket leaks EVER so slightly when cold?? Also the rad cap sort of has suction when you open it what does that tell me?
