Everything posted by MDW25gt
Code PO440 Help needed
MDW25gt replied to pulloff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere are the three valves located?
Clutch replacement - newbie job or no?
MDW25gt replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1000-1200 to do a cluch at the dealer. 700-800 for a reliable indi mechanic. What is it that gives you the idea that it needs a clutch? I'm thinking if its not slipping I would hold off. But there are always details to consider. Mike
Frt Brakes
MDW25gt replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKumho is Korean
Help!--did my mechanic screw up my car?
MDW25gt replied to lewdog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suggest looking at both sides. The lowest level is correct. I would confirm if the oil is high. Three inchs is pretty high! If high, drain some to proper level. Dont mess with the mechanic. Just dont go back! Its a stretch to call someone a mechanic if they can't change the oil correctly. The brakes. Try the bed in procedure. Check the www.Stoptech.com site for the procedure.
Frt Brakes
MDW25gt replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got the brembo oem's and also put on the Hawk HPS pad. I like! Hang in there!
Po 440 Cel ??
I am getting a PO 440 CEL EVAP emission control system malfuntion. What do I need to do to fix? Thanks in advance, Mike
Replacing the power steering oil
MDW25gt replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurkey baster would work. This sounds like an easy way to do it.
Engine Braking
MDW25gt replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree!
signs of bad front axle 99 legacy
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, here is what I needed. Center diff replaced, both front wheel bearings This took care of all of the symptoms I was having. Binding in turns, (center diff) roar when turning to the right on the highway above 40 mph. This also cured the whining I was getting in the tranny. I believe that the center diff was putting everything into a bind. i.e. causing the whine I was getting while rolling. Hats of to the great service I received from the service manager at Beechmont Subaru in Cincinnati. Scott Snyder and his technician took good care of me. I put 1700 miles on the car last week with no problems! Mike
Overheating
MDW25gt replied to [HTi]Johnson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI fill through the air bleed hole while running.
2002 WRX engine= $2,300
MDW25gt replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen more surprising things. If the engine is in good shape, thats not bad. I agree with what Emily said! Check the parts price to rebuild and then play around with the labor hours at 30- 50 dollars per hour.
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt would provide valuable info if I had pulled the axles. Like ruling out the axles as a cause of the noise. the old 20:20 hind sight. Can the bearing be examined with out replacement? In other words, pull, clean, inspect relube and re assemble?
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis noise was there before the diff work. I thought it was to the right side at first, but after replacing the right bearings we check both sides and nothing from the right, then loaded the left side with the sensors. I could hear the noise from the left bearing hub, strut tower and tie rod sensors, but not at the level I would expect. The car is still in the shop. Monday morning I will go back and have them check the nut on the right side. We did have one sensor on the left ball joint and did not hear anything signficant. Guess I could check the right. Thanks
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Gary, I have not replaced the tranny. They did replace the center diff. This is not a problem now. They also replaced the right side wheel bearing, and the noise is still there. After this, I drove the car with listening sensors at the left tie rod, bearing hub, and strut tower. (The sensors allow you to listen while driving, to the noise output at each location.) I never hear from the head phones the level of noise I would expect from the bearing. This is why I am thinking axles? But I guess it could still be the left bearings. Mike
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe noise is not clicking. It is a roar above 40mph and only when when turning the wheel to the right. As soon as the wheel is straightened the noise goes away. Turning to the left there is no noise.
I am having trouble determining what is causing a noise in the front of my car. What type of symptoms have people had when there is a bad front axle? Thanks in advance, Mike
Viscous Coupler failing?
MDW25gt replied to wilco's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine is at the dealer now getting this done. I got a call yesterday from the service mgr asking what type of fluid I had in the tranny, because he said a little would leaked out when the drive shaft/viscous coupler was removed. I hope to be able to report that I got my first good shake from a dealer service by the end of the week. Keeping fingers crossed.
Pulling to the right
MDW25gt replied to Suby Skier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked the tire pressure?
'98 Outback overheating
MDW25gt replied to MrDundee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the Fix is done right it will likely last a long time. Not knowing the history is the problem you have. The only way to know is to get into it. (the motor) at that point you might discover you would be better to do the different motor route rather than fix. Lots more money. If you can get the dealer to refund and take the car back that would be best option in my opinion. My first head gasket went at 133K. I have 45k on the new motor with no problems. Knock on wood. My engine is strong and runs well because the guy that did it , did it right. The other key piece to this is knowing the watch outs for this problem. You can chase that by a search after you get your current problem solved.
99 Legacy with whine when rolling
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTires are all 205/55/16 fresh Dunlop Sport Maxx. 36psi front 35psi rear. Tires have been the same all around for the last 80,000 miles. OK glad to hear you second the wheel bearing. I have an appointment to take to the dealer on Monday. For center diff and check wheel bearings. If I get good work done it will be a first at a Subaru dealer. I will be posting the details when I get the car back. Thanks again guys! Mike
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rear lube was changed in the last month with castrol 75w 90 full synthetic gear lube. up to level The trans fluid was changed last weekend with castrol hypo c gear oil 80w 90. up to level All of the following symptoms were there before the lube changes above. First thing, I am pretty sure I need to replace he center dif. Because it binds when warm and turn in to parking place. not sure if this is causing any of the noise. Second thing, I would call it a whine, and it does change when the speed changes. whether in neutral or in gear, under power or braking. This noise gets louder when it gets hotter. Third thing, is more like a roar when making a slight turn to the right. turning to the left the roar is gone. I can actually feel the roar in the steering wheel. This also seems to get louder when it get hotter. Thanks in advance for the help! Mike
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure I understand your question on engine or vehical speed? This does not happen when the car is not moving. It does slow if I am in neutral or gear and apply the brakes. Is there anything inside the tranny that could do this? Would the tranny make a noise like this if not in gear?
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it does. but is they even in neutral and coasting.
I have a 99 Legacy with 5sp, 176k miles. When rolling down the road there is a whine coming from the front of the car. I can't tell if it is wheel bearings, transmission, or what? If I put it in neutral and coast, the whine is still there. When I turn to the right there is additional whining noise whether under power or coasting. Any ideas what could be causing this? Ways to trouble shoot? Thanks in advance, Mike
What does a certified Subaru mean to me?
MDW25gt replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes not mean anything to me. Pay a mechanic, and look it over for your self.
