New 06 WRX; Shudders at idle?
Legacy777 replied to OmahaScooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible you got some crappy gas. You could dump some octane booster in for that tank, and from here on out make sure to run premium gas. Other thing you could do is ask to drive another new one around for a test drive and see if you notice the same thing, or whether the issues are isolated to your car. Resetting the ECU may also be something you may want to do to clear any previous drive cylces with oddities.
something is Slipping....!
Legacy777 replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to confirm, your liberty is MT correct? If so, it's probably a clutch issue or possibly some oil or what not has gotten on the flywheel/clutch and creating the problem you're describing.
'93 Legecy, won't start
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe green connectors are for the D-check mode. You want to use the black connectors. You can read the instructions from my site www.surrealmirage.com/subaru/engine.html Note the pictures on my site have the TCU mislabeled.
speedo died.. but an 'easy' fix
Legacy777 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah the car does some funky stuff without the VSS working properly. So yeah I'd recommend trying to fix the wiring as soon as you can. The two things on the driver's side of the MT are the neutral switch & reverse switch.
How much would you pay for my 2000 Subaru Legacy! TAKE A LOOK PLEASE! MANY UPGRADES!
Legacy777 replied to Subyguy522's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok....this thread is done. There's no more useful information being presented.
Catalytic Converter ECL 96 obw????
If it's the second O2 sensor code, it won't do anything to affect drivability. That second O2 sensor is there to tell you whether the cat is working properly. So as you mentioned, the problem is either the O2 sensor or catalytic converter. If your cat was bad, you'd probably be experiencing other issues. Can you elaborate on your "a/c doesn't do anything"
Pulling engine with minimal disassembly
Legacy777 replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome people have just moved the a/c compressor off to the side where the battery sits, and not disconnected the lines. That may be an option. You've pretty much got all the stuff you need to disconnect. You'll need to take the starter out, and drop the exhaust manifold. The lift points, at least on the earlier legacies was through an eyelet at the alternator point, and spot at the back of the engine where it mounts to the tranny. You can replace the rear main without messing with the front of the engine. Make sure to not install the rear main too far, or it will definitely leak. You can take a look at some of my engine pics from my rebuild. They should give you a little better idea of where the lift points, etc http://www.main.experiencetherave.com:8080/subaru/images/ej22t/
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpic of the ECU & TCU under the dash http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg
A/C experts
Legacy777 replied to anastij's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom the pressures, it doesn't look like the compressor is even on. When you looked at the compressor, was the clutch engaged, and spinning?
96 legacy a/c short cycles
Legacy777 replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat were the pressures you were seeing, and what was the ambient temperature when you took those readings?
06 Impreza Performance Problem
Legacy777 replied to MickW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell....if you add some extra grounds, and find that the problem goes away, let us know.
Blower resistor solder
Legacy777 replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you take a picture of it?
Uni O2s the same as factory?
Legacy777 replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only differences from the 4-wire & 3-wire O2 sensor is that the 4-wire sensor has a sensor ground as well as a heater ground, rather then grounding the sensor through the chassis. If you use a universal one, you need to make sure you solder the wiring good and seal it up so water doesn't get in.
Legacy777 replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're sitting there idle, does the compressor cycle on and off? Or does it only do it when you're driving?
Legacy777 replied to Subyguy522's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're looking to sell it, I'd recommend trying to sell it to a subaru enthusiast. You may want to also check out the Legacy forums on NASIOC http://forums.nasioc.com/forums
Legacy777 replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe coil is a heat sink to help cool the resistors.
thinking about an ethanol conversion...looking for input
Legacy777 replied to v8volvo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to check out the Engine Management / Tuning forum on NASIOC http://forums.nasioc.com/forums There's an E85 thread in there. I'm not sure what's all in it, but it's probably worth checking out.
Do I need this stuff???
Legacy777 replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a resonator box. A lot of people do remove it, which gives the car an agressive intake growl. The main issues with removing it is the air intake is a little lower, and could cause water ingestion if driving in high water. Also, all the piping can be tuned to help reduce a bogging feel when the accelerator is floored. However most people don't really notice it. If you've removed it, and you like the way the car feels, you'll be good.
Legacy777 replied to MickW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust curious....what level is your gas tank when this occurs? Does it mainly happen when you're at half a tank or less? Or does it also happen when the tank is full? I've heard of issues like yours with low fuel.
low fuel light went kaputz
Crud.....I can't seem to find the diagram that shows which pin to ground to check the light. Anybody else have the info?
There's a way to test the light. What year and model car do you have?
Legacy cooling question
Legacy777 replied to Groundworx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt varies.....I've read manuals that the main fan is supposed to come on, and the sub fan to come on when the AC is used. However pretty much all the subarus I've seen have both fans coming on at the same time.
RHD 91 Legacy Auto to 5-speed Man swap
Legacy777 replied to bigmicah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should work just fine. You can see what I did with my swap, and it'll be very similar if not the same. www.surrealmirage.com/subaru/swap
Use OEM roof rack for bike?
Legacy777 replied to mtmra70's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow sturdy are the cross-bars? Do they feel pretty stout? If so, yeah I think it'd probably work. I'd probably use a wide base washer to spread the bolt's load out. The bars are more then likely hollow, so be careful when tighten the bolts.
Question about de-yellowing headlights (in the process now)
Legacy777 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stock headlights do NOT have any sort of clear coat protection on them. You can use all the polishing crap you want. They will turn yellow again. The ONLY way to keep the yellow from coming back is to clear coat them. If you use the 2000 grit, you may have to polish the clear coat with a rubbing compound, or possibly recoat. That's why in my write up on the BBS, I get all the yellow off with acetone, continually use a finer and finer sand paper, and then the clear coat fills in the fine scratches....makes the lens clear again, and protects the plastic.
