8
Is the green connector a T shaped connector....same/similar as the one in this pic? http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg If so, those are the diagnostic connectors, leave them disconnected. As for your problem with the gauge. It's possible the float is stuck or something is screwed up with the electrical connections. I'd start with the electrical. There's a connector under the passenger side rear seat. That's the fuel pump connector. You should be able to manipulate the low fuel light as well as gauge by grounding a pin with the key in the "ON" position. Same goes for the gauge. While I'm not sure if this diagram is the same for your car, it should at least give you an idea of what's going on. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/fuel_sender_scan.jpg
Yeah, definitely do some more looking around. Post in the meet & greet forum to see if anyone is in your area that might be able to recommend a good shop, or help you out. You may want to also check out these other boards to look for subaru people in your area. http://forums.nasioc.com/forums www.bbs.legacycentral.org
I really hate the chiltons & haynes manuals. They are absolutely horrible. There's no need to drop the oil pan. Basically, changing the water pump is like changing the timing belt, and involves the exact same steps except for that you need to drain the coolant first and loosen the bolts holding the water pump on. Here's scans for the timing belt job for the 90-94 legacies. Should be similar/same for the 95. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
You may run into issues with the pedal travel. I know I didn't really care for how things felt when I swapped things over. If you have ABS, you should be fine because the MC is larger. If you don't have ABS, you may want to look at a 4-port 1-1/16" MC if you don't like how things feel. I'd only do that if you don't like how things feel. I wouldn't mess with the prop valve until you get everything in, and see how you like it. It may be perfectly fine. The 13.25 percentage increase with the wagon prop valve is only seen when above the split point of the wagon prop valve. The percentage increase tapers down as pressure increases. If you look on the split point data sheet, and the far right column, there is a percentage number. That's the percentage increase from the sedan valve.
I may have posted this before, but I've had some time to go through the spreadsheet and clean things up, and make quite a bit of improvements. The biggest being a 'Brake Torque Calculator'. Let's say you want to swap some WRX brakes onto your 90 Legacy. Choose your car from the drop down menu, and the WRX as what you want to go to, and the calculator will spit out the percent change in brake torque and whether the shift is frontward or rearward. If you don't see your vehicle in there and have information on your car, please let me know and I will add it. Likewise, if you see anything that looks incorrect or suspect, please let me know. http://www.main.experiencetherave.com:8080/subaru/techinfo/brakemath.xls
