What transmission fits 93 legacy?
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo it's not going to work without some complications. The 93 AT has a 3.90 final drive ratio. Pretty darn sure the 98's even overseas did not have that same ratio. If you decided to go with another final drive ratio, you need to swpa the rear diffs. Also, the electronics changed I believe in 97 or so with the Phase 2 4EAT. When this happened, they changed the connector, so you would have to modify that.....and while I think the 93 TCU would probably work, it may not work well.
Automatic Transmission...Manual Switch
Legacy777 replied to Rodney7286's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBecause the manual was designed to be confusing....haha
reverse lights don't work
Legacy777 replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo I don't believe there is a separate fuse, however it is tied into one of the fuse blocks. Do you notice any thing else that isn't working? Here's a diagram for the first gen legacies http://www.surrealmirage.com/subaru/files/swap/6-3_back-up_light.jpg BTW, what year and model subie do you have?
Legacy777 replied to Rodney7286's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.surrealmirage.com/subaru/trans.html#manualbutton
90 Legacy Auto shifting issues
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can pull the trans codes from the info on my site www.surrealmirage.com/subaru/trans.html The manual button doesn't do squat to make the trans shift "manually". More then likely it's just the age of the transmission. Maybe the brake band needs adjusting, but I don't think it's going to make things feel brand new again.
A. Transmission not working on 96 outback
Legacy777 replied to cmassad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like your transmission is on its way out.... Not sure exactly what the problem is, but the entire thing will probably have to be taken apart to fix it.
clutch specs
Legacy777 replied to ganjagti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know the specific torque specs. Just don't overtighten the pressure plate bolts. Other then that, every thing else is pretty straight forward if you've done a clutch job before.
14" alloy legacy rims on an '97 outback?
Legacy777 replied to Pascal Giasson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have ABS, the answer is no.
Spent some time in the garage...(PICS!!!)
Legacy777 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoohh.....someone with the same interior color as me
wrong cam caps
Legacy777 replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about the caps at the rear of the heads? There's a rubber plug on the driver's side. The passenger side has a metal cap that's bolted on.
Subaru shops in Phoenix AZ?
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmay want to post in the meet & greet forum, as well as on nasioc
WARNING 4wd switch installers!!
If you have things wired up properly it shouldn't matter one bit how you wire the switch up. It's simply a break in the circuit. Measure the resistance across the switch's pins. With the switch "ON" circuit closed, the resistance should be 0 ohms. If it's not, get a different switch. If that's the case, that's more then likely why you're having the tranny light blink. Other option is to use a relay with a switch.
new brake lines, but all different lenghts??
Legacy777 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre they specifically for a legacy?
93 2wd 4EAT Legacy skips gears...weird.
Legacy777 replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2nd & 4th gear utilize some of the same clutches. Doesn't sound overly promising.
Drive solenoid C & Torque bind.
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat kind of fluid are you putting in to cost over $100?????
Should the backup switch have oil on it?
Legacy777 replied to wondercow2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah there will be gear oil on it.
getting codes from ej22
You can take a look at the following wiring diagrams & ECU I/O, but what you need to do is ground pin B56 12, and hook a light bulb in series with pin F47 19, and then ground the other side coming off the light bulb. Connecting pin B56 12 to ground will be like connecting the black read memory connectors. If you have any questions, just holler. http://www.surrealmirage.com/subaru/files/swap/2-7_ECU_I-O_page1.jpg http://www.surrealmirage.com/subaru/files/swap/2-7_ECU_I-O_page2.jpg http://www.surrealmirage.com/subaru/files/swap/2-7_ECU_I-O_page3.jpg http://www.surrealmirage.com/subaru/files/swap/6-3_engine_electrical1.jpg http://www.surrealmirage.com/subaru/files/swap/6-3_engine_electrical2.jpg
The trans light shouldn't go on if you've done everything correctly. What type of switch are you using? Is it a lighted toggle type switch?
Onstar '03 OB sedan
Legacy777 replied to Joe719's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible GM modified things when Subaru & GM split....not really sure. You may want to ask them when they updated things.
You need to use the black connectors. You can read the procedure on my site www.surrealmirage.com/subaru/engine.html
help valves adjustments
Legacy777 replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplied to your PM. You have solid lifters, and they will need to be adjusted. Also, please only post once, no need to post multiple threads.
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChange the tranny fluid....that's the first thing I'd do.
valve adjustments help?
Legacy777 replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgoing to close this thread so all replies go in your other thread and make it easier to keep track of what's going on. http://www.ultimatesubaru.org/forum/showthread.php?t=51141
wipper motor problem
Legacy777 replied to edteach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible the part they have is just a generic motor. You might want to see if you can find a used motor in a junkyard. If you don't have any around you, I'd suggest calling up these places http://www.aaronsautowrecking.com/ http://www.superrupair.com/ http://www.4subarusuzukikiaparts.com/
Cel?help...
Legacy777 replied to slo93L's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out my site on how to pull the codes www.surrealmirage.com/subaru/engine.html
