Cold starting problem
Legacy777 replied to BigDTX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, it's probably the starter solenoid contacts. You can read over this thread http://www.ultimatesubaru.org/forum/showthread.php?t=2447&page=9&pp=10&highlight=super+secret+starting It's long...the last two pages have links to a place where you can buy the contacts, and a little word document. here's some additional pics http://www.surrealmirage.com/subaru/images/swap/13
94 Legacy Auto Transmission/Speedometer Problem
Legacy777 replied to jetboy12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe's blown smoke up your arse. Where in texas are you?
Neutral Safety Switch Location
Legacy777 replied to krazymatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe inhibitor switch by itself doesn't keep the car from starting. I can jumper two pins on the car side of the AT connector and start the car, regardless of what gear it's in because I've tricked the other systems in thinking the trans is in Neutral or Park. Yes the inhibitor switch is tied into the other electronics. The other electronics/systems are what keep the car from starting. Anyway....I think it's the old potAtoe vs Patatoe thing....
1990 Legacy Won't start cold....
Legacy777 replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, replace the coolant temp sensor.
1997 2.5L legacy outback
Legacy777 replied to jesusfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou probably do have a headgasket issue. The 97's were known for it. Just as a check....you did bleed the air out of the cooling system correctly right? Did you use an OEM thermostat or aftermarket? Do you get heat from the HVAC system?
Legacy777 replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd start with a coolant temp sensor. They can slowly degrade with time and cause cold starting issues. Does the car start fine when the engine is warmed up...even if the ambient temps are cold?
Legacy777 replied to krazymatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe inhibitor switch really doesn't do anything to keep the car from starting. All it does is tell the electronics what gear the transmission is in. The other systems are what keep the car from starting. The shift lock system is what gets the information from the inhibitor switch and then says yes or no you can start the engine.
4x4 wont engage
Legacy777 replied to highpowerd2003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust for my clarification.....are you driving around with a fuse installed in the FWD fuse holder.....yes or no?
Legacy777 replied to krazymatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe conversation has been on topic. Your AT does not have a neutral safety switch. It has an inhibitor switch, which is located inside the transmission. You also have a shift lock system which won't let the car start unless the gear selector is in park or neutral. So I would lean towards that if you're absolutely positive there's no clicking sound. You can check out these scans which talk about it. http://www.surrealmirage.com/subaru/files/swap/3-3_shift_lock_sys1.jpg http://www.surrealmirage.com/subaru/files/swap/3-3_shift_lock_sys2.jpg http://www.surrealmirage.com/subaru/files/swap/6-3_at_shift_lock.jpg
4EAT - Beginning of the End?
Legacy777 replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou sure you don't mean 3rd gear is 1:1? In the first gen legacies 4th gear is 0.694
Legacy777 replied to krazymatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStarter solenoid contacts.
Legacy777 replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 4EAT does not specifically have an OD. It's fourth gear is overdriven....but it does not have a typical OD.
can I swap 97 or 98 2.2 into a 99 2.2?
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe engine harness thing doesn't mean squat. Just swap the engine harness. It's cake. You just have to remove the intake manifold, pull the existing harness, and put your old one in.
Do 2.5L parts fit 2.2L ?
Legacy777 replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre both motors coming out of the same type of transmission based car? The starter depends mainly on the transmission, not the engine. Coil pack & alternator I don't see why they wouldn't fit. The timing belt....probably not....is the 2.5 DOHC?
Initial high idle and slow return--codes pulled
Legacy777 replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replied to your PM. Replace the canister purge solenoid with a known good one, and then try to clear the codes again.
clutch specs
Legacy777 replied to ganjagti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll need to give us a little more info about your car before we can provide any further information.
'06 Impreza Sport
Legacy777 replied to LyncStar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaru.com/shop/model_consideration.jsp?model=IMPREZA
Legacy777 replied to krazymatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAT or MT? Were you having this problem with it not starting before you replaced the starter? Have you stuck your head out the window when it doesn't start and listened for a click? You might want to try that next time it won't start. See if you hear a click when you turn the key to the Start position. Either have someone stick their head in the engine bay, and/or stick your head out the window so you can hear things better.
Legacy777 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing's impossible. Did he give reasons for saying it was impossible. Since I'm not overly familiar with the new 2.2, my best suggestion is to check out the online subaru dealers and see if they have a parts catalogue and blow up diagrams. Look to see if there is an EGR valve. Or give them a call. Even if there isn't, you can still swap the intake manifold from the 99 onto either the 97 or 98.
Starting problem '91 legacy 2.0 SOCH 4EAT
Legacy777 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat level was the fuel in your tank? I suppose if you were low you could have an issue of the pump not picking up fuel. I'd definitely recommend replacing the fuel filter.
Duty Solenoid C code - Help
Legacy777 replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you inserted a fuse in the FWD fuse holder? If so, does the problem not occur? Due to the sporadic nature of the issues, I would wonder if your electrical harness has a short or area where the wire is breaking down.
WHEN did Subaru start installing LATCH Systems?
Legacy777 replied to Sconnyite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust out of curiosity, since I really haven't seen them, what exactly is the LATCH system?
"Interesting" brake noise on 04 Forester XT
Legacy777 replied to Lispisgone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't recommend turning the rotors again. At that point, just buy new ones.
Newbie questions (Code + speedo)
Legacy777 replied to subjfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe two are tied together. Unless it's the cable, you're going to have to replace both the speedo and odometer as a single unit.
Legacy777 replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe transmission is specifically designed not to shift into 4th gear until the transmission is warmed up to a certain temp. This operation is normal.
