96 impreza question
heartless replied to Bassboy81's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you checked FSM for the info? you can find one here: http://jdmfsm.info/Auto/Japan/Subaru/
1995 Legacy LS AWD tire size
heartless replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfor just tire size comparisons, i like this one better... https://tiresize.com/comparison/ looks like nearly a half inch more in sidewall height... do you have enough space between current tires and the spring perch to add that much?
Opinions on 2003 Legacy sedan?
heartless replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it makes you feel any better, I too was afraid of the EJ25 series, but I gave in... I lucked into an 02 Forester - EJ251 - that I bought with 214K on the clock (pd $1400, private sale).. carfax type report said headgaskets were done around the 80-85K mark (forget the exact mileage) - it currently has just about 260K on it and running great. No signs of a 2nd failure, no major issues at all. And guys, he is in Dallas/Fort Worth area - pretty much rust free zone, so values are gonna be a bit higher than they would be up here in the rust belt. However, I would agree on checking values on comparable vehicles for the area
The fifth identifier EJ20?
heartless replied to Step-a-toe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 02 Forester has an EJ251 and is definitely NOT a turbo - so that little bit of info is way off.
04 outback seems down on power
heartless replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXknock sensor does not always throw a code.
Will this Transmission Work?
heartless replied to bratboy1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXideally, you find a tranny with the same final drive ratio as what you already have. short of that, yeah, grab the matching rear diff from the donor
Engine swap question
heartless replied to 1197sts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot curious and went looking at FSM info here: http://jdmfsm.info/Auto/Japan/Subaru/ looks like the 2001 had 2 different crank sprockets - one for auto, one for manual.. where the 2003 only used one version for both.. so it would appear that for a manual, you need the crank sprocket with many small teeth
Coolant leak when system is pressurized
heartless replied to mrfixiter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes the DOHC have an oil cooler?? never had one so i have no idea.. but the oil coolers are a known source of coolant leaks.
Help - Tire Size Selection
heartless replied to TimothyFinn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, this is how radial tire sizing works 1st number is the tread width in millimeters 2nd number is the ratio of the sidewall to the tread width (basically a percentage) - so a 225/50 has a sidewall height that is approximately 50% of the tread width last number refers to wheel diameter. so, if you want more sidewall (to fill the opening), you want that 2nd number to be higher. there are other factors to take into consideration here as well.. how far from stock size you drift will have an affect on your speedometer readings.. faster or slower depending on whether the tire is smaller or larger than stock a useful comparison tool is this one.. https://tiresize.com/comparison/
Whine at right front wheel area
heartless replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhuh, both of the ones i had go bad got warm.. one got REAL warm.. but both were warmer than the other 3 axles after driving for about 20-30mins
heartless replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcant always count on "looseness" unless it is really far gone. temp will tell you faster than if it is loose or not. Just be sure the brakes are in good working order and not dragging (that will cause things to heat up as well) If brakes are good, and it still gets hot, it is the bearing
259,000 ... and counting...
heartless replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow.. that is a lot of miles. even if it is on the 2nd round so far mine is still on its first round (original engine & tranny), and going strong.. engine had the headgaskets done long before I got it (somewhere around 108K from the carfax report), and so far, so good.. knock on wood.
heartless replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjack up the car and try spinning the tire while putting your hand on the spring.. bad bearings can often transmit vibrations that can be felt thru the spring temperature difference after driving a bit can also prove/disprove a bearing going. the corner that is going will usually be hotter than the others - use caution when checking, dont want you to get burned..
heartless replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmost likely wheel bearing
heartless replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas have i.. the old 89 GL (Brumhilda) was at 265K when retired due to subframe rot the 90 Legacy (Cherry) was around 275-something when retired. the 95 Legacy was only at 230K when I sold it on Hoping to get at least 300K out of this one before it has to be retired due to rust
so I actually took this pic on 3/17/20 .. went to get lunch and then back to work.. happened to glance down at the odometer after parking and this is what i see...
Replacing Wheel Bearings with Hub Tamer
heartless replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsomething from 14 years ago, I would imagine so..
2005 Impreza OBS- source of oil leak
heartless replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa wider angle view of the area might help us pinpoint the issue..
What is this? It’s leaking
heartless replied to Clueless99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat is too funny!
2006 Forester Headlight H1 - LED?
heartless replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot sure on an 06 model, but on my 02, disabling the DRLs was as simple as unplugging a small "thing"* under the hood, behind the passenger side strut tower. (* apparently called a dropping resistor) i typically just turn my lights on & leave them on, but there are occasions I want them off - completely off - and on the 02 if the car was running, the DRLs were on - regardless of being parked or moving. might check the wiring diagrams for that part & its location
rebuilding ej22
heartless replied to 91leglift's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlike i said, search outside your area. use the contact info to reach out to them..
rebuilding ej22
heartless replied to 91leglift's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuse car-part.com to search for potential engines in your area. or where ever you like really.. junkyards can probably get you whatever you need, and most have contact info included in the listings.
Tire size
heartless replied to Junebug2014's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, your speedo will be off. https://tiresize.com/comparison/
heartless replied to Clueless99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen did they start mounting the oil filter like that?? holy cats, that is a dumb idea. Sure, it might be easier to get to, but the orientation is all wrong.
96 impreza 2.2 water pump replacement help
heartless replied to Bigsky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, so orientation depends on the style of tensioner.. I am most used to the old style, so.. yeah.. point taken.
