90
Put a proper charger on the battery over night to get a full charge on it - then take the whole car in to be tested immediately. It is better to have it tested in the car than on the bench. I have had alts test fine on the bench, but prove faulty when tested in the car. Repeated battery drains WILL kill a battery much faster than "normal" usage does, so do not be surprised if the battery is shot. A bad battery will kill an alternator and a bad alternator will kill a battery. And yes, the aftermarket remans are junk for these cars. I had one for my 95 Legacy rebuilt at a local to me shop - it cost a bit more, but he used high quality parts, not the cheap stuff most remans get in them - and he guaranteed his work.
no need to buy something that is freely available in a couple of different places. the one ocei77 gave a link to is probably the most common source, but there are others as well. Check the sticky topic "New Gen Subaru FAQ", page 2, about 2/3rds of the way down the page... same poster as above, even.
possibly, yes Tires on these are a big factor. They all need to be within 1/4" circumference - preferably all the same brand, style, size and treadwear to prevent damage to the AWD system. Keeping air pressures regulated is also important. FWIW - if you have a flat and need to use the donut spare, you are supposed to put the donut spare on the back, and use the FWD fuse - that is what that fuse holder is for. Do Not use the donut spare on the front. Meaning if a front tire goes flat, you put the donut spare on a back axle, and move the good tire from back to front, use the FWD fuse and no damage will occur to the AWD system - this is the info you get in an owners manual.
yes, a 97 will be interference. A proper timing service means not just the belt, but all roller pulleys, tensioner and water pump as well, and ideally, cam and crank oil seals - especially at that mileage. the 2.2 is a very good engine and will give years & many miles of trouble free service IF it is properly taken care of, but neglect it and it will bite you. While test driving - as already mentioned - keep an eye on the temp gauge. It should sit steady at just under the halfway mark. if it is fluctuating, there is a reason for it.. and it is not usually good. make sure both the heat and AC work properly, and all other accessories are functional - wipers & washers (front & rear), radio, all lights, windows, power mirrors, etc. Tires should match all around, same brand, size & tread wear
you are quite welcome. sadly the early models (90-94) are not covered quite as comprehensively as the later ones, but there is enough there to figure things out, and this seems to be the case on many sites offering the FSMs.. For future reference, there is a sticky thread in this section that has compiled a list of the most frequently encountered stuff with links to the topics covered (New Gen Subaru FAQ sticky compilation) - on page 2 of that thread, there are several links for service manuals, including the one I gave you above.
wheel bearings have no set failure pattern.. sometimes you will get the grinding noises, other times you wont. sometimes you can get away with trying to go a bit further on one, other times they bite you in the backside - as this one did. We had a front wheel bearing on our Dodge pickup do something similar... I had taken the truck on a long trip, and just a few miles before I got home, I noticed it was starting to growl a little - not bad, but just enough to be noticed. Parts got ordered for it.. a couple of days later, we went to pickup a used motorcycle with it & the trailer - was maybe 40 miles round trip... got to where we picked up the bike, no problem, but about 2/3rds of the way home it failed completely - it totally locked up on us. Had to call a friend to come get the trailer, take it home, unload the bike, then come back with the trailer and put the truck on it & take that home. what a day!
i would replace the the hub, yes.. and that lower bit in your picture, I believe, is the sensor for the ABS (that reads the tone ring) been a while since I had one of these 1st gen Legacys... the upper bit in the picture is the pivot point for the brake shoes, so yeah.. that whole thing needs replacing. oh, and for Factory Service manuals, try here
yeah, the tone ring is for the ABS system, there is also a small sensor that reads the wheel speed via the little spaced blocks in the ring. you may want to try to get a spare one of those, too, if you can - I am betting the sensor for that wheel is trashed from the fallout of that mess. And my hat is off to you, sir, for taking care of that lady. The world could do with a whole lot more like you.
