105
if you don't KNOW the timing belt system was properly serviced, maybe a loose tensioner is letting the belt flap around too much. that's an interference engine, don't drive it without KNOWING the condition of the TB idler pulleys and other parts. should be serviced every 105K miles OR 105 MONTHS, w'ever comes first. The toothed idler can seize or puke its bearings - throws the belt off.
might be a switch at the clutch pedal - maybe mouse chewed wiring.... neutral safety switch problem of some type.
- 2 replies
- legacy
- engine code
(and 1 more)
Tagged with:
looking at a MSDS for that product - there's very little lube in it (1% - 5%); 3 - Composition/Information on Ingredients Ingredient CAS # Weight Percent US Hazcom 2012/ GHS Classification LVP Petroleum Solvent 64742-47-8 60-80 Aspiration Toxicity Category 1 Poly(dimethylsiloxane) 63148-62-9 1-5 Not Hazardous http://www.wd40specialist.com/pdf/WD40SpecialistSilicone Lubricant-MSDS(6-24-11).pdf http://www.wd40specialist.com/pdf/WD40SpecialistSilicone%20Lubricant-MSDS(6-24-11).pdf
how long since the timing belt system was serviced? were any warning lights on? any new ones come on? is the CEL on? if so, get the code(s) read and post them.
- 6 replies
- solenoid
- fuel filter
(and 4 more)
Tagged with:
2002 wrx
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
^^^ yep - or possibly a coupla resistors at the end of the harness. but, with ECU Flash or some other tuner software, you can 'un-check' the P0420 and other codes I think. -
??? um - was it a new tensioner? if you reused the old one, maybe you compressed it too fast and blew-out the seal? maybe post up some pics and one of the more experienced guys here will spot something. include 2-3 good pics of the tensioner from different angles too. no question you got the right belt/parts?
2002 wrx
he could consider running without a muffler and do a 'turn down' on the exhaust. -
well, it seems possible you were troubleshooting the wrong area of the car. Since the car is new to you but has had some known issues - you should also confirm the rear diff matches the final drive ratio of the transmission. the center differential (actually, a wet clutch pack in the auto trans) in the transmission is responsible for 'torque bind'. make certain all 4 tires are the same size/brand/model and 'near' each other in wear. If so, next experiment would be to try using the FWD fuse (I think 08s have them?) under the hood. The rear diff may be 'open' on your car, but, even if it's a LSD - it's a viscous coupled unit.
thin metal - probably heat shields, frequently rusted and loose. whining noise could be acc. belt tensioner or idler bearings, or air in the power steering. common issues (like the PS or the tensioner bearing) listed as 'stickies' at the top of this forum; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/
we have an 03, it gets very little time on freeways so, the suspension takes a beating. It had a bad strut at ~65K miles. Almost a guarantee a 2001 anything with original struts needs new ones. you might also have a broken spring. Sometimes those can actually be hard to spot - again, all that stuff needs careful inspection.
any number of things could be wrong with the car - perhaps 2-3 at the same time. try swapping tires in pairs fron tot back - check for change in vibration at speed. I think a full inspection of all the brake and suspension and axle parts would be good start. Also, all 4 tires MUST be; same brand, same size and same model. Also best if they all vary no more than about 3/32" in tread deppth. Proper inflation is good too. If you must run mixed sizes, use the FWD fuse in the fuse box under the hood until you get same size tires. Also, try using that fuse and test for vibration at speed as you mentioned. you may need a pro to find/list the problems for you - then decide what you can DIY. basically, ask the mech. ;"what needs immediate attention, what can I 'live with', and what should I save-up for?" post a request for a shop recommendation near your city in a new thread.
