105
batteries don't like to be completely discharged - even 1 or 2 times is bad - multiple times will destroy one. maybe borrow a good battery from a working car, test voltages as mentioned too. of course there are other possibilities, some older soobs had crank sensors that would fail when they warmed up, etc.
classifieds on the Forums - post a WTB (want to buy) someone may have some wheels laying around. (here, subaruoutback.org, NASIOC, etc.) you will need to confirm a few things for maximum possibility of problem-free driving - what size tire can you run with no rubbing or brake caliper interference, what wheel size that mounts to, can you find a good looking wheel that size that has the correct offset, is hub centric and is the right bolt pattern. I wish I knew specifics about a 97, but likely someone here will. there 'may' be a thread over at NASIOC called "what wheels fit my car" or similar. Also, tirerack.com and I think also Discount Tire , have online shopping systems that allow folks to load a picture of their car model, then 'try on' pictures of different rims. That might be fun.
yeah, kinda behaves like a non-oem t'stat. Is the car new to you? anyway, get a t'stsat from a dealer or the Stant Xacststat 48457 or w'ever it is. It matters. good time to install fresh fluid if needed, inspect the condition of the hoses and maybe a bottle of Subaru Coolant Conditioner. Also, that is an interference engine, do you know when the timing belt system was last serviced?
honestly I can't help a lot here - if there were other electrical problems, I'd suspect a common ground was involved. But some high-ish current devices have their own dedicated ground. A Factory Service manual with wiring diagrams may be required - sometimes you can find pdfs or scans online. someone may chime in here with the info or experience with the fan system.
look for oil in the spark plug tubes - might need valve cover gaskets. If the problem seems related to moisture/dew/rain, maybe plug wires.... both of those can throw misfire codes. also, our cars don't like most plugs other than NGK - maybe prev owner threw some cheap plugs in it. do you KNOW when it last got a timing service? Interference engine so, idlers and tensioner need to be in good condition. toothed idler often seizes or looses it's bearings and throws the belt off. $$$$!!! AT fluid must be checked while idling - only fluid that's like that. Might try a fluid change - best if really nasty would be 3 drain/fills with a drive around the block between each one - that gets you 80-85% new fluid.
most people get full kits from ebay or elsewhere - depending on a few different approaches and 'opinions' - you should at least consider; belt - Gates or Mitsuboshi or dealer (m'boshi may be OEM ?) NOTE! there are reports of a 'generic' belt that fails very early! IF you do the waterpump, I read that most people prefer OEM or Aisin GMB idlers seem to be OK, usually the toothed idler is the first to fail - not the belt. Tensioners - if re-used, should be compressed VERY slowly. over several minutes or the internal seal can rupture. cam./crank seals might be a good idea to replace - must be if leaking. confirm you understand all the marks - DO NOT use the arrow/triangle on the front of the crank sprocket - use the dashed line on the back tab. Find out the tooth count and triple check timing marks and tooth counts (crank the engine around twice with a wrench on the crank bolt) before and after pulling the tensioner pin. Crank the engine around twice again and check the marks and tooth count before starting. do not skimp on the TB service, if valves aren't already bent, they will be when the toothed idler fails (or one of the others. If the present belt isn't severely worn, you could check the tensioner and other parts, retime the engine and run it enough to decide if valves are bent - if they are, at 250K, probably better to get a lower miles engine from a wrech, throw a TB kit on it, and go from there. maybe others will chime in with suggestions. Tough spot you're in but, it's an interference engine and MAJOR damage will result if the TB service isn't done correctly.
it's been a long time since I read; http://www.subaruoutback.org/forums/110-gen-2-2000-2004/47896-sleeper-vdc.html but i THINK cardoc was running about 9lbs of boost. here's one of the graphs he got from his VDC 3.0 Outback; but, cardoc went 'dark' and there's really no way to know what the longevity of his engine is.
