D/FW meet info
If I'm a transplant, it's only from Arlington to Ft.Worth and back again - maybe yah got me confused with some other inhospitable southerner?
Exciting premium fuel mileage
1 Lucky Texan replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf a '90 model Honda had a knock sensor (anyone?) the above tests should've had the ECU reset before switching to the higher octane. I dunno
D/FW meet info
Meh I'm just going because; a. Its the steal - er - dealership I got my WRX from and the one lilely to work on my soobs and ,b. Maybe free stuff! were you gonna give me free stuff in Grapevine? I think NOT! hah!
D/FW meet info
I have never met these guys but will likely go. Just FYI http://forums.nasioc.com/forums/showthread.php?p=12156246#post12156246
question about defrost buttons...
1 Lucky Texan replied to wscheuer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook carefully for a sticker somewhere (mine is in the glove box - but don't neglect any manuals/paperwork and the toolkit - maybe you could contact the original owner somehow?) that will give you a code to order a socket. Likely Mcgard or something is the name. carry some Fix-a-Flat and cross your fingers till the replacement arrives. Otherwise - take nippers advice immediately.
Kick Down Slam
1 Lucky Texan replied to pprotopapa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems like a pressure test is in order - though I admit some of that is way above my head. good post carl
Kick Down Slam
1 Lucky Texan replied to pprotopapa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have that only at high speeds in my '03 OBW . Kinda scary when you're doing 75-80 and it slams into low gear! I'm gonna have a different dealer look at it in a week or 2 - I'll try to repost after that. I may have to take a tech for an interesting test drive!
Brake job on Forester???
This seems very odd to me. I assume you are the original owner and the fronst have not been changed in the pst? maybe there is a problem with the master cylinder/brake proportioning valve or something? I dunno
Gurgling Water Noise
1 Lucky Texan replied to ltk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVERY important to check the above, but a low refrigerant condition can sound a little like water 'whooshing' and the A/C compressor would likely be engaged for defrosting. Try testing the air conditioner with and without the A/C compressor and give a listen. (I'm actually overdue for taking my '03 OBW in for low refrig. - too many family 'emergencies' right now for my wife to give up her car - grrrr!)
Centre diff lock on AWD auto
1 Lucky Texan replied to Fatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think this would be a good mod for re-wiring that parking light switch on top of the steering column. Much more useful and no need for a new hole in the dash.
A little smoke
1 Lucky Texan replied to J_Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree generally with the idea of a fluid dripping or blowing onto the exhaust but wonder if it might be power steeri ng fluid? Might be worth checking the level.
Another head gasket question
1 Lucky Texan replied to Grover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with the above, tell the steal - uh - dealership you want to talk to the zone rep about covering this in good faith as a drivetrain warranty issue. Then if that goes no where, ask him how HE would feel in your position and if he would get a 'third party' involved. I'd bet you could at least get FHI to comp the labor and you pay for parts. I dunno
Torque Bind, TPS? VSS? Air Susp?...
1 Lucky Texan replied to Mike W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDang - that's a shame. If you could park it overnight in a large area, with the wheels cut hard to the lock, I wonder if you would feel the torque bind immediately doing a slow 'donut' after starting? I dunno what to think if the answer is; 'Its OK till you do 17 circles' - but it is weird the way its behaving. What about testing for the weird feeling with the rear shaft removed? Could it be a front diff problem (what?). I dunno.
Sylvania sliverstar wow!!!!
Are they 'safe' for wiring/connectors on newer soobs?
1 Lucky Texan replied to Mike W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK - I'm risking this question, How do you know its torque bind and not some other issue? Nipper often points out the possibilty some off feeling in the drivetrain can be a U joint or carrier bearing.
got my rotors in the mail and there is something unusual
I used my handbrake if I needed to come to a complete stop during the bedding in procedure. It pays to pick the spot for doing this carefully so you minimize the risk of NEEDING to stop - kinda tricky. Don't be surprised to see some smoke/vapor. I have no experience with ceramic pads - but likely they are bonded on the backing plate and that material might 'outgas' at high temps. Let us know what you think about the pads later on OK?
I dunno about cryo-ing them, but here's a link with some (possibly controversial) info on pad/rotor failure modes and wear, etc. http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
Flat tire question
1 Lucky Texan replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf we're talking about the manual tranny, the ECU is outta the picture. But ,yeah, the auto senses wheel slip and then starts to allow the clutch pack to engage more, transfering the power to the rear axle.
Washer nozzles not adjustable?
1 Lucky Texan replied to adwolf1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOT question. Tell me about Rust Check because I bought some splash gurads for my car that likely will require some drilling but the thought of exposing the metal is a little frightening. I had considered using some silicone or other sealant to help prevent moisture from getting to the area - but a substance that is applied to the holes to deter rust appeals to me. I guess it is common knowledge to some folks. is it readily availabel? tia
Does this sound like cracked heads or block
1 Lucky Texan replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess that goes back to what ya'll have been sayin' about the NOx, etc. I wonder if it's significant which END of the cat is the hottest? Like the upstream end could indicate a lean condition whlie the downstreeam section might be hot in a rich condition? I dunno.
Over heating problem, 98' Forester
1 Lucky Texan replied to tahoecush's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dunno why the o'flow tank is dry, unless as mentioned the leak is other than a bad cap - but have you considered you may have a stuck or partly stuck thermostat? Here especially, I've read you DO NOT want an aftermarket part. Subaru thermostats only please. Also, it may be worth checking the spark plugs. If one looks distinctly different from the others, you might be blowing the coolant out the tail pipe.
1 Lucky Texan replied to adwolf1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet one of those IV thingies at the hospital. Do you feel OK? You don't look good. ;^)
Flat tire question
1 Lucky Texan replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn all fairness, the 'junk' (leaves, gravel,etc.) in the gutter may HELP keep a soob's drivetrain from binding. I dunno. Do your brakes also wear unevenly? I heard a letter carrier ask Click and Clack once if it were OK to change just the pads on the left side! They finally said 'go ahead' . I think it MAY be overemphasised, usually these things are a compromise between engineering, marketing, sales, legal, etc. But it is an expensive part. The manual says change the oil at 7500 miles too. Likely that is a compromise too. But I doubt folks would just dismiss it as overkill and start telling people 12,000 is OK. Plus, a ONE TIME miss of an oil change that goes to 12,000 miles probably would not destroy the engine. BUT a ONE TIME period of 3 weeks driving a donut spare COULD mean a new tranny. Once you educate yourself, you can assume whatever risk level you're comfortable with. Curiously, those very folks who may not be able to afford a set of tires , will have an EXTREMELY difficult time buying a transmission! ymmv
1 Lucky Texan replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXS0, how would I know what type lambda sensor my soobs have? Or is one type exceedingly rare....
1 Lucky Texan replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot a bad beginning explanation. also, from that site, check out this!; http://www.picotech.com/auto/lambda_sensor.html VERY detailed O2 sensor stuff with diagnostic hints, etc. particularly interesting for some of us, how easily the sensors can be damaged by coolant in the exhaust or by an ohmmeter!
