'99 Legacy Outback ABS trouble
1 Lucky Texan replied to OB99W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have read of metallic road debris causing some kinda problem between the rotor and the sensor. maybe a good wire brushing? let us know what you find out OK?
1 Lucky Texan replied to OB99W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood luck with that - I've tried a few times, the emails never get through. meh - maybe my server is blocked but....... fyi
Total Engine Failure at 107k?
1 Lucky Texan replied to snaffle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah good luck. I did feel a little guilty at encouraging you to spend MORE money just to satisfy my curiosity. As for fixing an old car, I've always felt that the majority of problems can usually be fixed for the equivalent of 1 to a 'few' car payments. Yeah, its a bummer to have a major failure - and worse to have 2-3 in one year, but its also a bummer to be paying $300 a month for a car payment. And remember, its a used car the instant you take delivery. Its really only a new car when its on the dealer's lot! If it serves your purpose and can be reasonably reliable - just fix it!
*#&@*$! ***holes
1 Lucky Texan replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust fill it with bondo ;^)
How many Subaru's on your block?
1 Lucky Texan replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI might have the only soobs in my zip code!
Knock sensor deterioration
1 Lucky Texan replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year did they change? I'm reading into the remarks that the grey version is inferior.
odometer and parking light sensors
1 Lucky Texan replied to Radian08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXParking lights - probably the switch on top of the steering column. MANY people do not know what it's for, and it gets pushed accidently when cleaning/whatever. I'm not clear on what your other complaint is. have you put on different sized tires? That will ceretainly affect the speedometer's reading. Or do you have an intermittent ground wire or something? I dunno
Misfire 1&3 Cold weather.
1 Lucky Texan replied to Hentai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXput down the 'tentacle porn' and go fix your car! (I keed, I keed lol!) what they said. Plus, you could exchage the coils for each other I think, move the cables and plug wires and trade them off. Then see if the problem follows the coil. They CAN have cracks/carbon tracks that you might see or hear at night - or misting them may induce failure like dew/condensation could in the morning. I wouldn't rule out front O2 sensor - but coil is more likely IMHO. Carl 1 Lucky Texan
EJ22T Carbon in Turbo
1 Lucky Texan replied to vick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possible to have an oil seal leak in the turbo?
Need advice on tires
1 Lucky Texan replied to tjfaenza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow nipper! somebody better snap you up - your too smart not to be working! good luck (sorry for the OT comment) Carl
subie security light flashing now????????
1 Lucky Texan replied to kleggo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou are a genius no - just a widely read nerd with a slight case of Asperger's Syndrome thank you you're welcome! glad you got it fixed!
Looking for a good intake
lighter wheels
1 Lucky Texan replied to snaffle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think a simple compression test, inspection of the cam timing and maybe dropping the pan could narrow down the problem a lot without being TOO expensive.
tool for rear differential
1 Lucky Texan replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I haven't done a diff. but I've read some of them have magnetized plugs - so, be sure to wipe off any metal particles.
1 Lucky Texan replied to tjfaenza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the Tripletreads had some kinda center section with sand/pumice in the rubber specifically for ice? maybe I'm thinking of a different tire. On my WRX I recently swapped wheels and the Kumhos i got are a LOT noisier than the B'stone RE92s that were on there. That can be a characteristic that you only discover in a review of a tire.
1 Lucky Texan replied to tjfaenza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might see how they're rated over at http://www.tirerack.com or maybe they're listed at http://www.subarureview.com .
Fan Temp Switch
1 Lucky Texan replied to Larry97116's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould these fans have a ground location in common? maybe its corroded. I dunno
1 Lucky Texan replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dunno about opening it - I would make sure it isn't just some 'blowback' from an oil leak up front somewhere. I've read here that most folks just use a 1/2" square drive breaker bar to take out the plug. You will likely need a 'cheater' bar too.
Wheel Weight alloy vs steel
1 Lucky Texan replied to kindablue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt isn't clear however if he wants to purchase stock take-offs or aftermarket. Plus, ultra light wheels might be OK for the street or strip but not auto or rallyX. I dunno
1 Lucky Texan replied to kleggo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossibly it is in 'valet mode'. Re-check your manual or try looking up some of the model specific alarm info at http://www.cars101.com . Of course, someone here may chime in that has the same vehicle as you and experienced the same issue.
Common causes for EJ22T running rich?
1 Lucky Texan replied to vick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool deal! way to stick with it. Carl
1 Lucky Texan replied to kindablue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are aftermarket wheels that fit soobs all the way down to under 9 lbs. IIRC. Stock wheel weights can sometimes be figured out by weighing the tire/wheel set and subtracting the tire's weight as listed by the manufacturer. For instance, my '06 WRX wheel/tires weigh about 43.5lbs according to the freight scale at work. The listed weight (at tirerack.com ) of the stock 215/45/17 RE-92s is 23 lbs leaving a wheel weight of approx. 20.5 lbs. I suspect that could be plus/minus 5% easily. What are you trying to accomplish?
1 Lucky Texan replied to vick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI read that he changed it out - but that would've been my first guess. It IS possible to get a bad new sensors I suppose. Did the OP change the GAUGE sensor or the Engine Temp Sensor? I dunno
1 Lucky Texan replied to vick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe an injector is stuck open? Do you have smoke out the tailpipe or a lot of soot in the tailpipe? Do all 4 plugs look the same? I hope you have a leak - otherwise your cat conv is probably toast!
2002 Outback overheating at idle
I'd contact jamie (aka subiegal) who works at http://www.subarugenuineparts.com . she'll know. There are other discount dealers on line as well - or maybe someone over on the Marketplace forum has a used one.
