Everything posted by Bobby_boucher
EA81 engine masters, I have Q's.
Bobby_boucher replied to soobme's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was also thinking about building up and ea81 but have no idea where to start or what to use. Qman has about 150 hp out of his ea81 he said somthing about building it to air plane engine specifiations. I have no idea where to get the specification for the airplane engine though. -
Official Lift Kit Group Buy
Bobby_boucher replied to Shadyirishmen's topic in Products for your Subaru
Shady i was just wondering was address you sent my kit to...because i dont remember wether i gave you the shop address or the house address. -
It just means its running and starting isnt.
these are called touring wagons....right??
Bobby_boucher replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
in the description they are calling the motor "inline" somone should kick there a$$ for that -
Did you get the timing belt figured out on suzie?
why is it so rich
Bobby_boucher replied to Scoobywagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Usually with age the carb will start puking into itself causing it to run rich. -
Good to hear, i was hoping we didnt go through all that work for nothing
For Oil you can T off the oil pressure sendre unit for the pressure side and the return side you need to tap into the oil pan and just run ther return line in there.
Well if you going to get ride of the lock cylinder all together i would make a new pannel for under the steering wheel and put the switches there, i have a push button start on my 1980 hatch for the rump roast. and on. i would trace wiring and just wire the push button in a hidden location but your still going to need the key for the doors.......unless you shave the handles:brow:
New Member +exhaust question
Bobby_boucher replied to depleted's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i always thought that was just the pipe cooling down and shrinking causing the heat sheilds to make noise?? -
http://www.tirerack.com/tires/Sizes.jsp?make=Kumho&model=Venture+MT These are cheap and they look alright.
key/ignition lubrication question
Bobby_boucher replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you can get the lock cylinder out and then use the graphite it would probably work alot better. -
As long as you can get to the moving parts it should work. -
check for a fried fusable link or fried ground wire.
Thats true ....wait i might be able to make that motor into a turbo motor as long as there is a hardware store open on saturday that has all the right plumming
Xoomer i was hoping to get the motor back in exchange for the tranny. But let me know what you want to do.
Well im going over to xoomers place on saturday and we are going to attempt to put a tranny in his wagon... i was just wondering if anyone else is going to be around that area and would like to come hang out and b.s.???? If you interested give me a call and i can give you some info. Andy @ 1-509-830-1751
Hey Jerry how much are you asking for the hatchbrat? My Girlfriend really wants a suby but she hasnt decided what she wants yet.
noob question about boxer sound
Bobby_boucher replied to nkx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Off the subject.....I was hoping to somday build a railer with a sube engine but have no base plans do you have any suggetions??? I alread have a VW front end for steering but am lost after that -
Great White smoke... Smells like oil
Bobby_boucher replied to xoomer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good to know, i think the only other car that had somthing like that was the old fords...but anyway.....yeah.....i feel stupid....... -
Head Gaskets, HC in Coolant test.
Bobby_boucher replied to Fuji Fellow's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've used the block tester 3 times and it has worked very well for me.
