Everything posted by bratsrus1
Anybody want to go to WCSS10 from Colorado?
Hi Shawn This is Jerry, get a hold of DEMoss he is suppose to be comming to the show with the turbo car. As one Jerry to another i want to meet him. Thanks Jerry
carbs on a ej
Hi This is Jerry, that is the holley carb that i have on my 2.2 imperza engine. How dose it run well i will put it to you this way a raped ape can't run that fast. Thanks Jerry
coil wires
Hi This is Jerry, the 2 black wires go to the pluse side of the coil and the 2 yellow wires go to the negative side of the coil. Thanks Jerry
lily:now with pics!
Hi Brian This is Jerry, the mounts would already be at your house if i had your mailing address. PM me with your address so i can mail them to you. Thanks Jerry
Nor*Cal WCSS Attendance.
Hey Jibs This is Jerry, just like Brian said it will not be the same if your are not there. Besides you will want to see my new old hatchbrat i have a 96 impreza 2.2 with a 4 barrel on it wow a lot more horse power. See you at the show:burnout: Thanks Jerry
Debate: mpfi vs carbi in ej'ed older vehicles
Hi This is Jerry, i have a EJ2.2 impreza engine that i have a 4 barrel carb on it. The engine has no lag nor dose the gas pool up in the manifold. Want to see it well then come to the show WCSS10 it will be there. I have the engine on a test stand now and when i open up the gas that engine will pick up one side the stand it's going into my hatchbrat in about 3 weeks. come to the show and see it. Thanks Jerry
Iam new to this board
Hi Everybody This is Jerry, i hope all of you know who i am well baja1 is my wife. Yes Ed Rach you were right on this call. The reason she posted here is because i look at this part of the board every day and she wanted to see if i would notice the post. Thanks Jerry
Radiator
Hi Shawn This is Jerry, ok thats good with me let me know how much to send you. My address is Jerry Schmierer 755 Hexon Rd.Selah Washington 98942 also pm me with your address. Thanks Jerry
Radiator
Hi This is Jerry, i have a question for the people that have done the swap EA81 to the 2.2 engine. The radiator will the EA81 keep the 2.2 engine cool even in the hot summer? I know i need to get the inlet and outlet change to larger ports but will it keep that big block engine cool or do i need to install the EJ radiator. Please let me know Thanks Jerry
It's all about timing
Hi This is Jerry,well some of you know that i am converting a 2.2 to a carb. I got a 96 2.2 imperza engine that i needed to replace the timing belt on and i have a 92 legacy factory manual so i put all the marks in the right place it shot gas about 2 feet in the air. I thought bent valves so i got all new valves it did the same thing. The next thing was to bring my other 2.2 legacy to the shop and check the timing on it.The timing was set different so i reset the timing on my imperza engine it runs now, i think my book has a misprint. I am a happy camper:clap: Thanks Jerry
fuel pump for 86 brat? what r my options???
Hey Nick This is Jerry, i have a stock fuel pump for your brat used but with all the brackets. Make me an offer Thanks Jerry
EA81 and EA82 Trans Swap
Hey Scooter This is Jerry, give me a call 1-509-952-2855 i make a kit for that 5 speed swap over. Thanks Jerry
Shifter Knob threads
Hi This is Jerry, i have a B&M Tee shift knob on my hatch and the thread pitch is 1/2 by fine it is real close to the 12mm x 1.25 i use a bunch of loctite on the threads let set over night. I hope i can get it off when i need to. Thanks Jerry
You and your Hitachi. A sordid tale of love, hate, and vacuum valves.
Hey GD This is Jerry, i just removed that junk a week ago on my 86 hatch. I had a bad vacume leak found it, your parts look good compaired to what i took off of my hatch. My mileage is better now back up to 31 miles per gallon again. Thanks Jerry
Hi This is Jerry, they are the same size as the lug nuts are and that is 12 mm x 1.25. Thanks Jerry
Restoration project question
Hi Shawn This is Jerry, only 3 things to do #1 install a 5 speed dual range tranny and use the 5 speed kit you know you use to own my old brat with the 5 speed in it #2 rear disc brakes #3 wheels. Super cool ride:headbang: Thanks Jerry
save this suby
Hi Everybody This is Jerry, well the car is in my yard now it's not going to be parted out but put back together. Hey Paul here is your new ride. Thanks Jerry
new project lifted EA82 with EJ22 and no computer
Hey Guys This is Jerry, have you look on the Aussie board on mini jet boat racing. They use the 2.2 with the carb to get more power because with the fuel injection you can only go so big well with the carb you can go bigger larger jets larger carb more ponies. Like Scott is talking about old school simple and away we go. Thanks Jerry
Weird noise from rear end, thunk thunk thunk
Hi This is Jerry, your noise is a loose lug nut. It happen to me please check them. Thanks Jerry
My Swap. EA82 5sd DR Trans into BRAT done.
Hey 94 This is Jerry, with the kit that i build it alows you to keep everything stock inside of your brat stock shifters and consel. Next week i am going to build another kit after i get it biult i will get some pictures and post them. As far as i know everybody that has this set up in there EA81 car they like it i know i really like it. Thanks Jerry
so here's waht happened
Hi This is Jerry, i just look but i don't have a head but i do have a good oil pan offer me something for it. Thanks Jerry
ea81 spfi w/pwr str in ea82?
Hey Lumpycam This is Jerry, i have a complete set up from a EA81T power steering pump and brackets. I also have the water pump and the crank pully and belt driven fan all of them have double grove pully set up. make me an offer let me know. Thanks Jerry
Bad news Good news
Hi This is Jerry, well i went to my work place today and got my 2.2 with the carb all put back together oh crap i forgot the gas can. So i go back home on the way my hatch mis 1 time thats odd less than 1 mile later it dies. So i coast to the side and start checking things yes getting gas so check the spark zip no spark. Whats the odds of having another dissy in your car thats the good news i had one. Yes i pulled the dissy and put the other one in timing must be real close fired up and away i went. I love these little EA81 cars some people call them tinker toy cars because they are so simple. Thanks Jerry:banana:
Crazy high oil pressure
Hi This is Jerry, if it's not the wire then your oil pump bypass is stuck. Pull the pump there is a spring with a steel ball in it, if the spring is broke or something is in there not letting the ball to move not good. BTW get a oil pump reseal kit before you remove the pump. Thanks Jerry
Strut Despair
Hi This is Jerry, i sent you a PM Thanks Jerry
