February 9, 200422 yr Here's some pictures... I'll answer questions as they arise... these are each atleast a thousand words a piece :-p Discuss :-D
February 9, 200422 yr Well that box of cams explains why it appeared there was no cams in the cam housings So when are you gonna dyno it?
February 9, 200422 yr I was just thinking, to avoid the intercooler to turbo hose from contacting the engine stuff, why not just align the turbo differently? Just a thought, however a custom hose may be necessary...
February 9, 200422 yr Author Housing can't be rotated on the turbo because of the wastegate. Its not a custom hose... its a stock WRX aftermarket piece. I got that for $45 shipped.
February 9, 200422 yr I meant if the turbo could be rotated, then a custom hose might be needed. what exactly about the wastegate makes the turbo not able to be rotated?
February 9, 200422 yr Author The intake housing would have to be rotated, not the exhaust housing. The wastegate mounts to the intake housing, and there isn't any other places to bolt it to.
February 9, 200422 yr I know the Intake housing would have to be rotated, but it would also make the setup mor reliable. I say rotate it and use a homemade custom mount for the wastegate.
February 9, 200422 yr Dang it tex, you beat me to it! That reminds me, I need another set of Delta cams... I cant wait to see how you get all that stuff plumbed in and see some dyno results!
February 9, 200422 yr Author I got the milder of the 2 cams Delta had... which did you get WJM? Would have gone with the others, but Delta said some modification was required... and this being my first engine buildup i was leary of trying to take on too much. As is, i have my work cutout for me.
February 9, 200422 yr Hey Tex did you mock up a wrx intercooler, i wanted to know if it will fit the samco hose and throttle body??? looks like you welded and adapter on your up-pipe?? Do you plan to run stock injectors? If i was you i would make a fuel rail for bosche style top feeds. You can find dsm ~400cc injectors cheap on ebay. What style MAF does your car have??
February 10, 200422 yr Author I currently run a WRX intercooler in the RX. It sits farther back away from the engine though. I'm going to try to hook it directly to the throttle body and the samco hose, however I have a feeling the throttle cable/bracket might be in the way. If that is the case.. I will use a straight runner to set the intercooler back from the TB a bit (probally 2-3") and will cut the samco hose just after the 90 turn for the turbo to extend the y-pipe. Yes, the stock wrx uppipe flange was cutoff, and welded directly ontop of the stock flange. This helped to simplify the process. I was worried about keeping the turbo level, and throwing off the downpipe geometry. I will be running stock injectors. However I am making fuel rails for the engine. They will have a barb for the top feed hoses on the stock injectors. I've seen some other injectors of this same style. The whole reason to make the fuel rails was spurred on by getting an adjustable rising rate fuel pressure regulator. So hopefully with increased pressure I'll be able get more fuel into the engine. My car has the hot wire MAF. For tuning I'm using an apexi SAFC to modify the MAF signal (as we have no MAP sensor). I will be putting in a HKS FCD to prevent the fuel cut inbetween the SAFC and the stock ECU.
February 10, 200422 yr I havent seen the hot wire mafs for the ea82 but if its like the newer ones the "guts" can be removed and placed in a larger tube. This will allow you to run a larger injector and will raise the factory fuel cut. Have a pic?? Its probably very possible to run a newer legacy hot wire maf too with the SAFC.
February 10, 200422 yr Hey Subarutex, What is the duration and lift of those delta cams? The specs that were posted on another thread on the meassage board said that they were .42 inch lift and 260 duration for the mild torque grind. But when I called delta cams a couple of days ago for some more info, they told me that they were .386 inch lift with 260 duration. They said that they don't make a cam with .42 inch lift for the EA82T. So if you can let me know what the lift is, that would help me settle this confusion. Thanks. Curious...are you running Cu HG?
February 10, 200422 yr Author Good thought Steve... I'll have a look. From memory it seems to be one piece though... Legacy MAF could work i spose... I'm modifing the signal anyways right? Makes sense... Marck... I believe they offer 2 grinds for the EA82T. a 386/260 and a 430/260... Mine are the milder ones, so the 386/260 I think. Same ones WJM has. The 430/260's require modification to something (i imagine because the lift is larger...) I have decided against the CU HG's at this time. There is no solid evidence that they are any better than stock for our engines. The only reason I would see using CU HG would be to go thicker to get a lower CR. But our CR is already in the basement at 7.7?:1. I will however looking into using copper gasket sealant with the stock gaskets.
February 10, 200422 yr Nice buildup. Almost exactly what I plan to do. I have the manifold, the turbo, and Im getting ready to buy cams. Still need an intercooler. I need to rebuild my bottom end first. It started knocking two weeks ago. I read on another board somewhere that you can clock the turbo and bolt on the wastegate acuator with one bolt. On my td04 I drilled the turbo to bolt onto the factory flange. Looks like it will work fine but I haven't tried it yet. Hope it turns out good.
February 10, 200422 yr Author I don't see why the FCD wouldn't work. Its just a voltage clamp. The fuel cut is activated by the MAF signal being over a certain set voltage. If we can clamp the signal right before that voltage, we should never hit fuel cut. The FCD is adjustable. So you just start with a really high voltage... and keep turning it lower and lower till the fuel cut goes away.
February 10, 200422 yr Thats good. Let us know when you get that hooked up. if i recal there not to pricey either.
February 24, 200422 yr Originally posted by Subarutex My car has the hot wire MAF. For tuning I'm using an apexi SAFC to modify the MAF signal (as we have no MAP sensor). I will be putting in a HKS FCD to prevent the fuel cut inbetween the SAFC and the stock ECU. Hey SubaruTex, I've been following your project for a bit and I asked a question a while back but you may have forgotten to post about it or didnt' have time to look. Do you know what your Sensor Calc and Sensor Number setting is on your SAFC for your setup? Thanks!
February 24, 200422 yr Author I don't recall off the top of my head. After I get the battery back in the car I'll find out and let you know.
