January 22, 201115 yr so I was wondering wich of subaru engines are interfirance I know that all EJ turbo are but want to know for na engines heard thet EJ22 from year 1996 are allready interfirance
January 22, 201115 yr are you in a foreign location, those might be different than the US which is what most of us are familiar with? wiki-pedia has some information on EJ engines that might help with even some comments about other markets. in the US: EJ25's are all interference. EJ22's 1997+ are interference. EJ18 are not.
January 22, 201115 yr The engines are all the same in all countries, not sure about the 2.0. www.cars101.com will tell you about the engines, but it is safe to assume after 1995 they all are (even if they arent) I thikn the 2.2 was starting 1996. I think the early 1995 plus were built in the US using engines and transmissions from Japan. I don't know if they still do, but that is why they are all the same.
January 22, 201115 yr small correction: The phase I EJ22 of early '97 is not interference. The phase I's have the Subaru logo in valve cover and the spark plugs are just above the VC. All later are O.
January 22, 201115 yr small correction:The phase I EJ22 of early '97 is not interference. The phase I's have the Subaru logo in valve cover and the spark plugs are just above the VC. All later are O. where did you hear that? EJ22's have spark plugs above the VC up until 1999 so that description doesn't seem to distinguish anything or i'm missing something?
January 23, 201115 yr Author do youhave any pics off differences in hose walve covers If you have please post them thanks
January 23, 201115 yr do youhave any pics off differences in hose walve covers scroll down this page to see early style EJ22 valve covers: http://www.vortechonline.com/engines/ here's Subaru's website with a valve cover picture that shows the spark plug holes going through the top of the valve cover gaskets of the later PHase II 1999-2001 EJ22's: http://opposedforces.com/parts/impreza/us_g10/type_76/engine/rocker_cover/illustration_2/ that's your two different EJ22's and their valve covers.
January 23, 201115 yr small correction:The phase I EJ22 of early '97 is not interference. The phase I's have the Subaru logo in valve cover and the spark plugs are just above the VC. All later are O. In 97 the phase1 ej22 changed to a solid valvetrain from the HLA valvetrain. (I have one sitting in my garage.) And yes, it has the old style heads where the plugs don't go through the valve covers. And I've been told by numerous members on here that it's an interference engine because a piston change or something like that. I'm not sure why, just that I've been told it is.
January 23, 201115 yr Right out of the EJ engine Technicians Reference Manual: The 2.2 liter (SOHC) (Phase 1) has been enhanced starting with 1997 model year. The single overhead camshaft engines have had internal and external changes that yield an approximately 10 % increase in power and 3% increase in fuel economy. Accomplishing this involves many factors, one of which is engine friction reduction. The piston, a major source of engine friction has been coated with a friction reducing agent called Molybendum. This thin coating not only allows a smoother travel through the cylinder but also reduces cylinder wall scuffing. This coating will wear off over time and is not an indication of a problem. The skirt of the piston has been reshaped and the overall weight has reduced by approximately 100 grams. Compression ratio has been increased to 9.7 to 1 by reshaping the crown of the piston. This eliminates the clearance that was available between the piston at TDC and a fully opened valve. Piston pin offset has been changed to 0.5 mm. Piston to cylinder wall clearance has been reduced by increasing the piston diameter. Another source of high engine friction is the valve train. Hydraulic lash adjusters are always in contact with the camshaft or valve rockers. The hydraulic pressure of the lash adjuster must be overcome during operation and the most critical time of engine start. To overcome this situation and to contribute to the total reduction of friction loss the SOHC engines will have solid valve adjusters. The scheduled service of these valve trains is set at 100,000 miles and is not required during the PDI. The SOHC engine uses an adjustment screw and locknut. The intake manifold has been reshaped to increase the air flow mass and speed, contributing to improved low and mid engine speed operation. Components located on the intake manifold have been relocated as compared to the 1996 models. EGR Solenoid, Purge Control Solenoid, etc... Edited January 23, 201115 yr by ferret
January 23, 201115 yr so I was wondering wich of subaru engines are interfiranceI know that all EJ turbo are but want to know for na engines heard thet EJ22 from year 1996 are allready interfirance -NO. That is not even correct. Turbo ea81, turbo ea82, and for sure the 91-94ej22t turbo were non-interference.
January 23, 201115 yr The "looking at valve cover design" was discussed recently, and my understanding is that it is not reliable. Please see this (especially post#6): http://www.ultimatesubaru.org/forum/showthread.php?t=119303
January 23, 201115 yr It's very simple - you pull a valve cover and check the rocker assembly. If you have solid lifters it's an interferance engine. If you have hydro it is not. There is only a single questionable year with regard to this - '96 had the hydro valves and single port heads. So a '96 looks identical to a '97/'98 from outward appearance, but will have hydro lifters AND they changed the pistons in '97 resulting in it being interferance. As far as I know there was NEVER an EJ22 made with hydro lifters AND interferance pistons. Those are mutually exclusive from the factory. As far as I know removing a valve cover and checking the rocker assembly style is the only reliable way to tell. If course the solid lifter/roller rocker assembly fits on the older engines (even the dual port heads) so if someone went to the trouble of putting solid lifters on the engine.... you are screwed because there's no way to tell on a single-port engine like the '96. All these parts can be mixed/matched so if the thing has been heavily modified.... there's no rules that apply. GD
January 23, 201115 yr There is only a single questionable year with regard to this - '96 had the hydro valves and single port heads. So a '96 looks identical to a '97/'98 from outward appearance, but will have hydro lifters AND they changed the pistons in '97 resulting in it being interferance. As far as I know there was NEVER an EJ22 made with hydro lifters AND interferance pistons. Those are mutually exclusive from the factory. GD I can confirm this, I have a MY96 that lost it's timing belt cruising 85 on the highway, and it lives to tell the tale.
January 24, 201115 yr Author I was not tolking abouth EA81t and EA82t becaus I know they are not interfirance but nuewer subaru turbo engines we have are all interfirance we got EJ20g in legacy and early imprezas and so on
January 24, 201115 yr I was not tolking abouth EA81t and EA82t becaus I know they are not interfirancebut nuewer subaru turbo engines we have are all interfirance we got EJ20g in legacy and early imprezas and so on Since you're saying the 20g is an interference engine, the 22t may be the only non-interference ej turbo.
January 24, 201115 yr It's very simple - you pull a valve cover and check the rocker assembly. If you have solid lifters it's an interferance engine. If you have hydro it is not. There is only a single questionable year with regard to this - '96 had the hydro valves and single port heads. So a '96 looks identical to a '97/'98 from outward appearance, but will have hydro lifters AND they changed the pistons in '97 resulting in it being interferance. As far as I know there was NEVER an EJ22 made with hydro lifters AND interferance pistons. Those are mutually exclusive from the factory. As far as I know removing a valve cover and checking the rocker assembly style is the only reliable way to tell. If course the solid lifter/roller rocker assembly fits on the older engines (even the dual port heads) so if someone went to the trouble of putting solid lifters on the engine.... you are screwed because there's no way to tell on a single-port engine like the '96. All these parts can be mixed/matched so if the thing has been heavily modified.... there's no rules that apply. GD This right here. HLA's and interference do not mix. So, check the valvetrain and that will tell you your answer (provided that it's the stock valvetrain).
January 24, 201115 yr Just for the note for those that may not be familiar, this is what a solid adjuster valvetrain looks like. HLA valvetrain will have flat tops instead of the flathead screw head with lock nuts.
