October 20, 201213 yr Does anyone know what this is, if I can pull it off for the time being and is it easy to replace? Thanks.
October 20, 201213 yr Sway bar linkage. The link that connects the sway bar to lower control arm. Just get another at the junk yard. Oh. And it is easy to replace.
October 20, 201213 yr It's a sway bar endlink. You just remove the bolt that is still in the sway bar, and bolt in a good endlink!
October 20, 201213 yr Author Thanks. I hope it won't cause excessive tire wear between now and when I get another one.
October 20, 201213 yr Thanks. I hope it won't cause excessive tire wear between now and when I get another one. It won't cause too much tire wear, but it won't help either. It's a cheap and very easy fix though.
October 20, 201213 yr Shouldn't cause any wear at all. Sway bar has no effect on alignment. You may notice the car leaning a bit more in curves though. I'd just take the broken section off of the control arm so it doesn't get snagged on anything.
October 20, 201213 yr That's a weird way for it to fail, and it looks like it already has been dragging on the ground. Yea, it won't cause tire wear, it'll just cause it to handle like crap. I'd buy a new endlink online, they're under $20 on rock auto.
October 20, 201213 yr That's exactly how the one I had broke. And my guess is over a long period of time, it would effect tire wear if one side is connected, and the other isn't. The weight of the vehicle is dispersed differently on each side when you go around any corners when only one side is attached. But I'm sure it would take a while before that would happen.
October 20, 201213 yr you could also consider getting alloy ones from Kartboy or Whiteline, etc. but that's more $$$
October 20, 201213 yr I run Kartboy myself. They are great, and very strong. They run $100 for a pair. So $200 for front and back.
October 20, 201213 yr I want to say at my local independent parts place I paid 40-50 for one of these years ago. So I started keeping a few when I parted cars. It isn't a common failure. But you may be surprised at the price of a new local replacement.
October 21, 201213 yr That's exactly how the one I had broke. And my guess is over a long period of time, it would effect tire wear if one side is connected, and the other isn't. The weight of the vehicle is dispersed differently on each side when you go around any corners when only one side is attached. But I'm sure it would take a while before that would happen. The sway bar is only supported by the frame. When attached on only one side it is free to rotate as the suspension moves without any resistance. Disconnect both ends and you can move it easily by hand.
October 21, 201213 yr The sway bar is only supported by the frame. When attached on only one side it is free to rotate as the suspension moves without any resistance. Disconnect both ends and you can move it easily by hand. This I know.
October 21, 201213 yr Right on, endlink, biggest difference would probably be during emergency maneuvers. I used Whiteline when I replaced mine,
October 21, 201213 yr If your going the scrapyard route (which is fine for this part) replace both of them. It is easy to do. But i do agree is that it looks sort of weird the way it broke.
