August 29, 201411 yr Author Made a receiver mount for a winch and added a receiver to the front bumper: Got a 24" piece of receiver tubing from Summit so I have plenty for adding to the Impreza. Used Anderson/forklift style electrical connections for the battery cables from HGM Forklift parts. They're rated for 350A. Also made a 15' extension cord so I can use it in the rear of the car: I don't plan to ever leave it on while driving so I'm not worried about the horrible approach and departure angles. This way I can keep it inside the car and put it on whichever end I want to go in the direction of when stuck.
September 18, 201411 yr Author Picture of the Outback loaded up will all sorts of spare parts, tools, fluids, food, etc. The cheap HF cargo net works surprisingly well. One of the last minute upgrades before the trip was mounting a $100 android tablet from ebay on the dash with a RAM mount. With built in GPS and preloaded maps, this made navigating while driving much faster. We also threw CBs in the cars at the last minute. They worked pretty well most of the time we were within sight of each other. Also, had the threads on another Subaru scissor jack start to gall, so I've given up on them. Got a cheap bottle jack that has just enough travel to lift the car.
September 19, 201411 yr Any plans for lifting that thing a little higher? Seems you could avoid some of the bashing with a little more clearance underneath. The metalwork looks great! With all the beefing up and ad-ons are you noticing weight being an issue? Again, less weight = less force to do damage. I'd imagine if I were at your point in the build I'd be doing some deletes and maybe swapping out some heavy leather/power seats for cloth slider etc. How much different is it to drive with the added steel and gear? Build looks really nice. Used to live in Beloit a couple years ago. Had the Impreza on a few good romps up in the Porkies. (Actually where my profile pic is from) My in laws still live in Loves Park.
September 20, 201411 yr Author Any plans for lifting that thing a little higher? Seems you could avoid some of the bashing with a little more clearance underneath. The metalwork looks great! With all the beefing up and ad-ons are you noticing weight being an issue? Again, less weight = less force to do damage. I'd imagine if I were at your point in the build I'd be doing some deletes and maybe swapping out some heavy leather/power seats for cloth slider etc. How much different is it to drive with the added steel and gear? Build looks really nice. Used to live in Beloit a couple years ago. Had the Impreza on a few good romps up in the Porkies. (Actually where my profile pic is from) My in laws still live in Loves Park. I'm more concerned with the suspension bottoming than rubbing the bottom of the car, but I've thought about lifting it more. More inclined to get more compression travel. Right now I think it has about 8" of total travel and maybe 2" of that is compression, so it's super easy to bottom out. Even just hitting potholes in town without much cargo. My Impreza and my friend's Forester don't bottom out nearly as easily. Probably the easiest fix for that would be raising the spring perches on the struts. All that said, a little more ground clearance would definitely help at times. Glad you like the fab work. Most of those projects were 1/16" wall tube, even the bumper is much lighter than it looks, but I suppose that's all added 100# or so. The biggest weight issue is all the crap in the back. After our last trip the whole car weighed 3900# and it was down to 3450# after we unloaded the tools, spare parts, fluids, etc. I can even tell the difference sometimes trying to get up a difficult hill with or without a passenger. The first thing would just be to bring less stuff along. The current seats are leather and heated but not power. Are the cloth seats that much lighter? I've thought about stripping some interior sound deadening, etc but that seems like a lot of work for minimal benefit. How else could I remove some dead weight? I do like the AC, cruise, etc since we have to drive hundreds of miles before we even start off roading. The steel wheels and mud tires are 17# heavier each than the alloys with street tires! The Porkies are cool but I haven't seen many off road opportunities near there.
September 27, 201411 yr Author We've always wanted to drive across Michigan's Upper Peninsula off pavement, so a few weeks ago we flat towed my friend’s 01 Forester to the UP with my 99 OB.During the first morning of off roading I felt the brake pedal go soft while we were driving through the woods. We stopped at the next semi level clearing and discovered that a small stream of brake fluid would spray out of the LR brake line (where it goes into the hose) when you stepped on the pedal. Tried a few crimping techniques and eventually just left a small vice grips on the line zip tied to the subframe mount. I tried to avoid using the brakes the rest of the day and used very little brake fluid. I think it was also this day we decided to try a slightly swampy trail and immediately got the OB stuck. Put the winch on the back and winched it mainly out of the ruts, then pulled it out the rest of the way with the Forester. The duty cycle on the HF Badlands 5000# winch is only about 5% which makes progress very slow, but it did work. We also wound up using a snatchblock (pulley). If you plan to winch your Subaru a lot, I’d recommend going with a 9000# winch or at least something with a higher duty cycle. Considering we only used it twice during this whole trip, I'm glad I didn't spend any more money or bring something heavier. We also need a better tree strap to snatch block/winch cable attachment. Might have been able to get it out with the snatch strap and ramps, which would have been a lot faster, but we wanted to try the winch.We got to Escanaba and found an O Reillys open until 8PM. I pulled off the flare nut end of the line and got a piece of hard line, union, flare nut, and line cutting and flaring tools. Installed all that and bled the line in the parking lot and didn’t leak any more brake fluid the rest of the trip. We finished up while they were closing and one of the employees who had helped us came up and told us that he’d seen a bunch of lifted Subarus but had never seen one that’s obviously been off road.Wednesday morning we came across a tree that had fallen across the trail but pointed away from where we were. It was a bit too low to drive under. The trail was relatively wide and cleared out so we figured it went somewhere. We decided to attach the snatch block to a tree on the far side and pull the fallen tree away from us with the winch. As we were starting this process, two guys pulled up on an ATV and wanted us to get out of the way so they could get through because they thought it was supposed to rain soon. They were barely able to get the ATV under the fallen tree and both hopped back on it, the guy in the rear holding a couple of gallon jugs. Before we got the tree out of the way, maybe ten minutes later, they came back through. Shortly after that we sawed the top off the tree, which had gotten caught on other trees. Then we sawed partway through the tree maybe 1/3 of the way up. Then we resumed winching, which quickly broke the tree at our cut, and we were able to get through. That trail went on for miles with no side trails, driveways, shacks, etc. We eventually got to a stream where a bridge no longer existed to cross it. The remains of the bridge appeared to be downstream a bit and we didn’t see any good way to drive through/around and had to go all the way back. The guys on the ATV are probably still laughing at us for moving that tree out of the way to get to a dead end and we’re still wondering what was in those gallon jugs.It took us four days and 550 miles (about 90% off pavement) to get to the Mackinac Bridge. We went back on US2, which took about five hours and 300 miles on pavement. We each had a loose rear wheel bearing on the way home. The tablet GPS worked great and definitely seems like the cheap and effective way to go. I would definitely like to pack lighter in the future, but I'm not sure what to leave at home. For this trip we had a spare front strut w/ spring, both spare rear struts (no springs, I don't have any good ones or hats, and they're different left and right, correct?). Front spindle/bearing/hub assemblies which I'll probably leave home next time. Front control arms, tie rod (inner and outer), ball joints. Front and rear CV axles. I've had to replace a few fronts now (not on the trail). Radiator & fans. We've never had an issue on the trail but have heard it's a common problem and would hate to be in the middle of the woods with a bad one. Wheel & tire. Oil, air, and fuel filters, spark plugs & wires, fuel pump, fasteners. Any suggestions on what spare parts we should or shouldn't take? Edited September 27, 201411 yr by pontoontodd
September 28, 201411 yr Stop doing SPOT WELDS.While it is true that a good proper weld looks like a stack of dimes they are also very strong.Your welds only serve to look nice without actually being strong. Earlier in the thread you posted some pics of booger welds,and while the "stack of tack welds" looks nicer it is not as strong as a proper weld and maybe even slightly weaker than the bird crap welds. Look up online the proper technique for welding and practice. While I will admit that even my own welds arn't perfect they are still improving, but it is really hard to get decent welds in rusty/painted metal or in out of position welding.However,my welds on clean, prepped steel where I can be comfortable look good and are strong. Remember there are several stages of welds: (1) bad looking/no penetration,(2) bad looking/good penetration, (3) good looking/moderate penetration, and finally (4) good looking AND good penetration. On your average day my average welds are somewhere in category 2 and 3. As for spare to bring and spare parts to leave: *Brace up your struts and you shouldn't blow them as much.So they arn't needed. *Spindles/hubs/bearings-no unless your doing 1000+ mile expedition trips,otherwise its alot of extra weight. *Under normal use I would say that bringing extra control arms,tie rods,and ball joints are overkill,because In my years of wheeling I have only bent one control arm.I also don't drive through the forest like a mad man and expect my ECONOMY CAR to handle like a trophy truck.So in your case if you continue to keep breaking control arms even after you beefed them up than keep bringing them as spares. *AXLES are a given because I blow a ton of axles. *I have never punctured my radiator in such a way that would prevent me from getting home.I have also never destroyed an electric fan to the point of failure offroad.I have had to top off my radiator every once in a while from a stick that got jammed in it. *Spare tire(s) are a given especially when running over rocks at low pressure. *I haven't had to replace an oil or air filter offroad, same with spark plugs and wires.I have had a fuel pump fail as well as a fuel filter plug up on an old subaru with a metal tank. that was my recommendation on what not to bring,when I go wheeling I bring: *At least 1 front and 1 rear axle,preferably more. *My junkyard/offroad toolkit.Enough tools to fix most anything wrong with the car *electrical wire and fuses. *spare tire *jack *engine oil *radiator water *potable water *duct tape and zip ties *shovel *chain/recovery strap *couple spare lug/nuts *possible fuel pump if old one is questionable My spare parts list is more designed to get me home after a failure of some kind rather than continue to play.For instance if need my spare tire I start heading home afterwards,same if I blow my last axle..While I could bring 5-6 axles and a couple spare tire its alot of extra weight.I'm not running the baja 1000, I'm just out wheeling for a day/weekend.. Edited September 28, 201411 yr by Uberoo
October 6, 201411 yr Don't listen to Uberoo about welds. Even the worst of the welds I see in this thread look strong.....espescially impressed with the underside trailing arm mount reniforcements, and the winch mount. And definately DO bring an extra oil filter.......I've had one punctured on the trail when the edge of my skidplate took a rock and bent up into it.
October 6, 201411 yr Fixed it for you! Well.......IDK.....I like Robert and he's definately a Subie wheelin' SOB.......I just choose to disagree sometimes with EVERYONE.
October 6, 201411 yr He does know his pre-EJ stuff. Looking forward to when he finally has a car of his own put together.
October 15, 201411 yr He does know his pre-EJ stuff. Looking forward to when he finally has a car of his own put together. Me too!Gotta go glue in some metal panels to fix the holes in the floor... yes the welds do "look" good right up until you see the little crater left in the center from stopping the weld. But my point about the "stack of tacks" welding style still stands.Its much stronger to run 1 continuous bead that hundreds of tacks.With one continuous bead the metal is fused with full penetration even between the ridges of the weld.With the "stack o tacks" you have no penetration other than at the middle of the weld puddle. Edited October 15, 201411 yr by Uberoo
October 15, 201411 yr Made a receiver mount for a winch and added a receiver to the front bumper: Look at the welds closely.Notice the crater at the center of each "weld"?There are clear areas where it is readily apparent that there is no penetration ( look between the craters).The strongest weld would be one continuous bead running the length of the weld while moving the gun in a "C" or "e" shape. Edited October 15, 201411 yr by Uberoo
October 15, 201411 yr Metal panels?! How bout some Lexan so you can see out the bottom. Edited October 15, 201411 yr by NorthCoast
October 15, 201411 yr Metal panels?! How bout some Lexan so you can see out the bottom. It would be fun to try but the lexan would get scratched and dirty so fast you wouldn't be able to see out of it anyway.A buddy of mine tried that with a piece of lexan above the transmission,by the end of the first wheeling trip the lexan was permanently opaque.Besides area that needs to get patched also has some structural members that rusted though.
November 2, 201411 yr Author Stop doing SPOT WELDS.While it is true that a good proper weld looks like a stack of dimes they are also very strong.Your welds only serve to look nice without actually being strong. Earlier in the thread you posted some pics of booger welds,and while the "stack of tack welds" looks nicer it is not as strong as a proper weld and maybe even slightly weaker than the bird crap welds. Look up online the proper technique for welding and practice. While I will admit that even my own welds arn't perfect they are still improving, but it is really hard to get decent welds in rusty/painted metal or in out of position welding.However,my welds on clean, prepped steel where I can be comfortable look good and are strong. Remember there are several stages of welds: (1) bad looking/no penetration,(2) bad looking/good penetration, (3) good looking/moderate penetration, and finally (4) good looking AND good penetration. On your average day my average welds are somewhere in category 2 and 3. As for spare to bring and spare parts to leave: *Brace up your struts and you shouldn't blow them as much.So they arn't needed. *Spindles/hubs/bearings-no unless your doing 1000+ mile expedition trips,otherwise its alot of extra weight. *Under normal use I would say that bringing extra control arms,tie rods,and ball joints are overkill,because In my years of wheeling I have only bent one control arm.I also don't drive through the forest like a mad man and expect my ECONOMY CAR to handle like a trophy truck.So in your case if you continue to keep breaking control arms even after you beefed them up than keep bringing them as spares. *AXLES are a given because I blow a ton of axles. *I have never punctured my radiator in such a way that would prevent me from getting home.I have also never destroyed an electric fan to the point of failure offroad.I have had to top off my radiator every once in a while from a stick that got jammed in it. *Spare tire(s) are a given especially when running over rocks at low pressure. *I haven't had to replace an oil or air filter offroad, same with spark plugs and wires.I have had a fuel pump fail as well as a fuel filter plug up on an old subaru with a metal tank. that was my recommendation on what not to bring,when I go wheeling I bring: *At least 1 front and 1 rear axle,preferably more. *My junkyard/offroad toolkit.Enough tools to fix most anything wrong with the car *electrical wire and fuses. *spare tire *jack *engine oil *radiator water *potable water *duct tape and zip ties *shovel *chain/recovery strap *couple spare lug/nuts *possible fuel pump if old one is questionable My spare parts list is more designed to get me home after a failure of some kind rather than continue to play.For instance if need my spare tire I start heading home afterwards,same if I blow my last axle..While I could bring 5-6 axles and a couple spare tire its alot of extra weight.I'm not running the baja 1000, I'm just out wheeling for a day/weekend.. Welding - yes the welds on the strut towers look terrible but they're probably at least as strong as the original spot welds and adhesive from the factory. Normally I MIG weld thin wall steel tubing. If you try to do that with a continuous bead you either blow holes in it or have a cold start for the first 1/4" or so with no penetration. Hence the trigger welding or whatever you want to call it. Yes, on some of these parts, especially the winch mount, I could have run continuous beads and gotten better penetration. Spares - many of our trips are well over 1000 miles if you include highway mileage getting there and back. 500 miles off pavement a few times. That said we're not exactly in BFE with no other means of survival or escape. We have never broken an axle, had a few with torn boots and making noise but never had to replace one on the trail. Only one bent control arm so far. I like the rest of your list, most of those things we've packed, recently got some extra lug nuts and fuel pump. Thanks for the suggestions. Edited November 2, 201411 yr by pontoontodd
November 2, 201411 yr Author I've done a bunch of minor things to the car since our last trip. Cleaned the car, swapped the city wheels/tires and bumper covers back on. The headlight adjusters were corroded to the point where they couldn't be turned so I put in some other headlights from a parts car. Replaced a bulb in the third brake light. Changed the oil and filter. Changed the air filter - it was extremely dusty. Also replaced the right rear wheel bearing which was a PITA. Quite a bit more involved than the fronts with the parking brake, drum hardware, the long bolt that cannot be removed, etc. Any suggestions on swapping out an outer door handle/lock cylinder on the driver's door? The bolt right above the lock cylinder is nearly impossible to get at with the window mechanism in place.
November 12, 201411 yr Author Exhaust manifold appeared to be leaking so I welded up the edge, ground it flat, and replaced the gaskets on both sides.
November 17, 201411 yr Author Painted and swapped on the front fender and doors from a parts car onto the driver's side. It looked like this, mainly from misjudging one tree this summer: The most difficult part was removing the door lock cylinder. I finally figured out that if you unbolt this part of the window mechanism: Then jog the power window up and down while pulling up on the glass, you can open up a gap like this: And get to the bolt (green circle) with a 1/4" drive ratchet. I did a lot of wet sanding, priming, etc on the doors and front fender. Used Krylon which I'd heard was the best aerosol on the market, not real happy with how those turned out. Not quite the glossy appearance of stock. Wound up using Rustoleum on the rear fender which matched much better. Also used Duplicolor Champagne Pearl to respray the side moldings, one of which was black. That was a decent color match. Decided to just paint over the pinstriping and arches around the wheel wells for simplicity. Turned out OK, still have to pop the dent out of the rear fender somehow.
November 17, 201411 yr Author Went up to Michigan over the weekend, didn't do any off roading but got this picture of a deer standing behind the car: The perspective makes it look tiny, it's just far away. About halfway home, we stopped for gas and when we got back on the highway the engine ran very rough between half and 3/4 throttle. At idle and light cruise, it was fine, and seemed to run well and make decent power at full throttle. This is sort of what it used to do when it got wet, which doesn't seem to be a problem anymore with the silicone around the plug wires. In the past when this happened, such as one time this summer after stopping on the highway to fill up with gas, you can just shut the car off for a few seconds, start it back up, and it will run great. Not this time. I tried coasting with the engine off several times and restarting the car after 10-20 seconds and it still ran poorly. After a half hour of just driving around the problem it gradually got better and ran fine the rest of the way home. I should also mention this thing has been getting terrible gas mileage, around 20 on the highway. I am going to check trouble codes and the resistance on the TPS, any other ideas?
November 18, 201411 yr Author The TPS reading to the ECU seems good, gradually goes up and down with the gas pedal. I have the following trouble codes: P0136 O2 sensor circuit (rear?) P0183 fuel temp sensor A circuit high P0301-304 cyl 1-4 misfire P0440 evaporative emission system P0453 evaporative emission system pressure sensor switch high P1507 idle control system malfunction I did replace the rear O2 sensor a few months ago and may not have cleared the codes afterwards.
November 18, 201411 yr Went up to Michigan over the weekend, didn't do any off roading but got this picture of a deer standing behind the car: I should also mention this thing has been getting terrible gas mileage, around 20 on the highway. 20 MPG from a 2.5 on winter blend gas is decent. Maybe a hair low but not "terrible" 14 mpg would be terrible.
December 1, 201411 yr Author Swapped out the rack from one out of a parts car. The one in my Outback had some slop in the driver's side bushing since I bought it. I also noticed after taking it out that there was some gear lash. The one I put in has no slop either place. The most difficult part was disconnecting the lines. I ended up cutting the lines on the old rack and removing the flare nuts with a socket. Does anyone know what this thing under the rack is for? Maybe some kind of tuned mass damper? I left it out when I put everything back together. Edited December 1, 201411 yr by pontoontodd
December 2, 201411 yr that deer pic does look odd! perspective and all. i've never seen a wheel bearing be fine and then catastrophically fail without warning....they get louder and louder over a relatively long period of time. i'd leave those at home too. how often do Subaru axles fail on non-lifted rigs? they're rather robust and i used to run them for 50,000 miles with broken boots and clicking and never had an OEM Subaru axle fail. i wouldn't take axles...guess i might if i were doing something harsher.
December 4, 201411 yr oops, didnt see all the fabrication that went into this rig, so I deleted my comment. Wheel on! Edited December 4, 201411 yr by impoutback 97
