lacking on top-end
well ive really noticed that my car really kind lacks on the top end, like once i hit 45mph it doesn't really pull hard, it will go on a flat part from 60 to 70 in like 5 seconds, but i dunno, hills are my worst enemy.
what could i do to help, help the engine breath better by better exhaust, 1 7/8's inch from the heads to a 2inch Y-pipe, to a cherrybomb to a 2 1/4inch tip. since my cat is rusted through badly i need exhaust anyways.
also port the intake, since i am rebuilding the hitachi soon also.
anything else you can think of??
THe timing not being advanced enough would cause a lack in top end.
timing was mentioned
vacum leak
weak coil
crappy wires
rusty cat? umm maybe plugged as well that will kill top end
plugged airfilter
the fact you are rebuilding the hicrappy i would think maybe its leaning out?
i dunno bout the hitachi's don't they have a secondary type thing? maybe its not opening?
timing is fine, its always been like this though,
i am running timing at about 18 to 20 advanced now and seems a little better.
and the cat is fine since i gutted it yesterday, no change since it was hallow.
When I saw the title of this thread, I thought maybe you were talking about some of my old girlfriends.:lol:
northguy, how old were your girlfriends? :grin: :grin: give them time! jk
scooby, I would do a larger exh, bottom end may be sacrificed a tad, but top end should benefit pretty well. A good intake is a must too...use mandrel bends wherever you can
Have you cut the bottom out of the airbox yet? it might help a bit.
And northguy, if she's under 18 its considered rape in many states :lol:
from the factory it came with a whole in the bottom of the airbox, sorry im bein an rump roast... its carb.
ya its just a low hp car. that glass pack will help, you can make a cold air intake with a mpfi snorkel, it clamps onto the top of the carb, then put a big rump roast cone filter on the end.
