My '94 Loyale: Subaru Utility Wagon
changed the oil, engine runs smoother and better, not saying this fixed the hesitation...
after resetting the ecu i got 2 codes
11- Crank Angel Sensor (no idea where this is loacted)
34 - EGR solenoid or circuit
  • Replies 131
  • Views 22.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I do harnesses and have ej adapter plates nice wagon! Looks clean!
  • Jawn, I'm located pretty close to you and I have a pair of Mill Supply rocker panels NIB for a Loyale that I have no use for currently. It looks like you could use them and I could definitely be persu
  • here are some new higher quality pictures of my loyale with bigger wheels. i forked over some dough forthis new Camera.   and some good News, my 2" lift Kit is on the way ! from Anderson Design &am
Posted Images
in the process of replacing the head gaskets on my loyale..
is there anything i can do (while its out) to increase HP ?
also i plan on chagning the clutch to an XT6 clutch, from what i understand i need the xt6 flywheel and then the xt6 clutch will fit ?
Yes, while it's out throw it away and put an EJ in its spot, voila, more hp!
Just kidding, but changing to an XT6 clutch won't make a difference without the XT6 flywheel, because the flywheel is where you are going to get better throttle response as it is lighter. Obviously change any leaking gasket or seal while you've got the engine out, you already knew that though I'm sure!
i wish i had everything to throw in an ej22 ! i so would love it..
i know the xt6 is stiffer, as i drive one way stiffer than loyale..
i hope the xt6 flywheel (being lighter) would help me climb hills... 90hp sucks climbing hills
yeah i knew about changing gaskets
i got this kit.
http://www.ebay.com/itm/220699367298?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Nice! Good gasket set for sure. The only other thing I've done is hollow out the cat and I've even built my own Y pipe header before and had just a cherry bomb after the Y then straight out the back and that seemed to help alot, I don't know if you have to pass smog where you live though.
no we dont have emissions tests here, i do have a glasspack on at the end of the stock exhaust system.
as formaking own Y pipe i dont have the skill nor do i have pipe bending tool.
i might knock out the small converter to make it louder..
EDIT:
and its out, saoking in kerosene to clean up all that grease, grime and well you know wha else...lol
Kerosene soaked
well gonna install XT6 clutch, and maybe shave the heads for more power...
what are your guy's thought on shaving the heads?
Edited by SubaruJawn
put a 2.2 in it. obdII will give ya 135 hp. put stainless header and if you don't have smog, take out the cat.
i'd love to install an ej22 but costs so much to make it all work i dont have that kind of money yet, i plan on ej swapping but it will take a long time..
i already have a stainless uel header that i have atleast...lol
Pulled the heads and well...
Crack between the valves, on 3 sylinders
...Crack between the valves, on 3 sylinders
Cracks between the Valves are somehow considered "Normal"
for the EA82 heads, as far as they doesn't go too deep...
its alright to reinstall them ?
i was just gonna do the gaskets till i seen the crack...
as long as its okto reinstall them, i suppose i could..
Normal for sure, get her back togeather! The worst that could happen is you blow it up and in the mean time you get ready for a Ej swap ;)
That crack is normal only if it doesn't go to the coolant passage or to the exhaust passage as one pair od my heads do.
  • Cleaned off the Cylinders, had lots of carbon Build up..
took me awhile to clean them up this good.
more work done..
New HeadGaskets (50lb Tq)
Engine Bay Cleaned up, and engine clean up
Engine:
Bay Before:
Bay After:
Engine re installed, no overheating (knock on wood)
XT6 Flywheel Clutch & Pressure plate installed.. (flywheel is about 10lbs lighter)
clutch is much stiffer (makes me very happy :D )
Great Job you've done to your Subaru, engine bay looks Clean!
... clutch is much stiffer (makes me very happy :D )
I'm glad that you live far away from the horrid Traffic Jams and Steep hills we have in my Country,
Otherwise your Knee would not be that happy...
Kind Regards.
  • 1 month later...
Updates i havent posted..
Pressure washed the carpet, turned out good, to bad driver's floor has hole in it
Chrome Lug Nuts installed
new hood prop cable
fun fun fun! nice ride.
i just recieved my adapter plate for the 2.2 swap from PWA101. it came fast , was priced fair , and it looks purdy:)
putting the 2.2 into the dual range 88 wagon. cant freakin wait!
  • 3 weeks later...
some more work done to scubie
New Blue Headlight bulbs 8000K Extreme Blue
as you can see the passenger is thenew blue bulb, driver is stock halogen.
here is a close up of the extreme blue
night pictures of the headlights (extreme Blue)
New Brake Line hoses, later found the real problem
Some New Hatch supports
works great now :)
stay tuned for more repairs and mods on Scubie
...New Blue Headlight bulbs 8000K Extreme Blue
Appreciated SubaruJawn,
Very respectfully let me tell you this, despite that I know that you will not like my advise: Try to avoid driving on Rainy nights with those Blueish lights, the deep blue accent of the light is somehow "Swallowed" by humidity, making to drive on wet pavement with such "illumination" to be pretty Dangerous. Such kind of bulbs are used more for the Looks they give to the car, but they really provides much worser illumination.
Kind Regards.
  • 2 weeks later...
i want to install bigger rimson my loyale, but i do not want to go with a heavy rim..
16"s or 17"s how wide can i go for a lightweight rim ? 6x5.5 lug
  • 1 month later...
new problem with my loale
very odd idle
have a listen in this video
