March 25, 201511 yr "I'm El_Freddo, and this is my Brumby Story:" Ok, time I "came clean" about the Redback Brumby. This is how I picked her up about two years ago. AFAIK I'm the third owner: The previous owner was a bit of a talker/player. I went out to check her out as a bit of a tease for me, it was local enough for the drive - I've always wanted a targa top since Sunnie the Brumby that we got for my mother inlaw. I would've loved a blue one but beggers can't be choosers. The owner said a fella was coming up from Melbourne that weekend so I bid him good luck, he was asking too much for my liking. 6 weeks later it was still there so I made an offer - he still played a hard card so I told him to offer it to the other guy at the price he mentioned and I let it be. Less than 5 mins later he called me back and said deal.As you can see from the pic above there's some front guard damage, pity, it's pretty straight otherwise! The engine wasn't working - reckoned it just stopped one day on the way to work and has been sitting like this for 6 months. I thought blown HGs straight up - empty radiator and creamy oil told the story. In the tub it had a rubber mat that concealed some foundation sand/packing sand (the orange stuff) that had held the moisture and rusted the middle of the tray. The main areas where rust shows up were pretty decent which I was happy about.After getting her home she moved around the yard a few times before making it into the shed for some work. Family photo: First up was pulling the engine - pretty easy in these things! I had to entertain dad as a decoy for his surprise 65th - he sat and watched for most of it :/ Once on the stand we drained the "oil": Second bucket: ~15 litres of water and oil in total. Now thinking major head gasket and a possible engine replacement. Continued stripping the engine before jumping to conclusions though.Heads removed, such a pretty sight (not!). Never seen this before: This was the culprit - and the previous owner's story checked out at this point: That's a Welch plug that dropped out, dumping the entire contents of the radiator into the engine, stopping things pretty quickly I'd imagine! After getting busy with work and other things (4wd trips etc) Dad came up and put the long block back together for me while I was at work - this saved me loads of time! Once the engine was all back together I got it running - it blew a lot of blue smoke and I shat bricks. It was also running as rough as guts. Turned out that I needed to adjust the valve clearances better than I did - it was running on two cylinders, just. Once all 4 were back online it blew more blue smoke. Not happy Jan! This finally cleared up and ran without any smoke. Very stoked. One of the things we had to do was remove rust from the bore. This was a cheap build for a daily cruiser - so instead of a rebuild or even a hone and new rings we hedged our bets and went this way. No1 cylinder had a couple of small pits at the very top of the cylinder so we left it this way and ran with it.Now it was time to look at other parts of the vehicle. Redback got her name when I was working on the rear end pulling drive shafts off that had probably never been removed before. While hammering away a redback dropped out from behind one of the rear wheels. Sorted that one quickly! It wasn't the last - I think there were five all up from memory, so a name was born for this beast. The rear bearings were an unknown and seemed rumbly and one of the rear brakes was leaking. So after a small investment in parts: This was done: Rear end being worked on: Rear diff was out as well, swapped in for one that leaked less instead of swapping seals! Home made tool for bearing retainer nutremoval: All coming back together well: "New" rear drums were sourced from one of the parts bombs, the originals had a decent 2-3mm groove dug into them! The new ones barely looked like they'd been used!Then it was off to a mate's place for some detailing - 4 hours of degreaser and pressure washing! Only got a phone pic of that, it's not been uploaded At some point, either in the transit there or back I managed to get a stone chip in the windscreen, just a small one but right in thedriver's view. Again, stole a windscreen from a parts bomb. This one cleaned up very well - I was stoked. This also gave me the opportunity to replace the old hard windscreen rubber and tackle the rust that I knew was under the front right corner: Putting the windscreen back in - always fun. Had to look it up on ausubi as to how I did it last time on Sunnie the Brumby. Oncethat was read the windscreen was in within 20 minutes: A new heater hose above the water pump was sourced - I use another unit from a Toyota Camry, just trim to size: A few other things along the way and it was time for a roadworthy inspection: ^ I didn't like the original rims, different offset and to me they didn't look that great on this brumby. I also had a set of black sunnies in the shed with my snow tyres on them which easily swayed my decision. I reckon they look way better even if they're only 13 inch and don't fill the guards. So she didn't pass first go. A few excited rookie mistakes: 1/ Didn't fill the wash bottle 2/ Didn't bolt down the passenger's windscreen wiper arm, so that didn't move! 3/ Apparently I had a front indicator that was blown - I didn't find it on my check so dunno where they got that from. and 4/ worn front uni joint on the tail shaft. I fixed the other easy little issues straight up, had to order in the uni joint so got two and did them both at the same time. I also smashed my thumb pretty good doing this - only now is the damaged nail almost grown out about 6 months after the event!Once those things were sorted the RWC was issued and I was off to rego. Vicroads now make it nearly impossible to get an appointment! I was pissed that I didn't get one before the weekend, but got one Monday and had to take some time off work to do it - just frustrating! The blessing was that my birthday/christmas/birthday pressie rocked up in the mail at M&D's (home base for important mail!) - so I was able to use them during the rego process, saving me some extra coin on not needing new plates: At Vicroads just after rego was granted: Back at home: Used her for driving to work, loved it! Didn't have to worry about rain (I'd been on the scooter prior to this!)And of course, hanging with the family members: Since this pic Dad borrowed Redback for a few months. I missed the old girl, the scooter's fun but there's just something about abrumby, plus it can do over 55kmp/h without trying hard. It's easier to speed in that Ruby Scoo IMO.While Dad had her M&D headed overseas and I had a conference close to their place, so my wife and I crashed there and I drove to the conference in Redback. The issue that came up after frying a few alternators (dad went through this issue) was a severe lack of performance - the exhaust would become blocked at certain levels of acceleration. This got worse until I was stuck on the way to the conference travelling at 60km/h, and that was before hills! Not fun! Pulled another Y pipe from the parts bomb and that sorted it. This wasn't an ideal fit due to some spacers on my EA81 for the ERG system that wasn't on the earlier year parts bomb, but it works and Redback goes very well for an EA81!I've also got to fix the choke - dunno what's wrong with it but it doesn't work properly. The carb could probably do a with a rebuild too, she runs too rich overall for my liking. I've solved the slop in the gear stick with the classic slot and bolt arrangement: The Welch plugs were sorted by Dad's idea - massive grub screws/threaded plugs: They've worked a treat! I've been hunting for a bullbar - found one in Talem Bend, South Australia, got a mate to pick it up for me. So I need to roadtrip to the city of churches to pick that up soon. I've since found an ideal bar that fits the bill for what I want. If all goes well the first one purchased might end up on Sunnie the Brumby if it's better than the one already on her. I've also been tossing up the idea of a lift kit, but it really comes down the right price at the right time - I don't want to go allout like Ruby Scoo lift/tyres.One thing I would love to do is make the engine run with the stock L series MPFI system. I'm a true believer in EFI over carb setups. I don't know if I can do this due to space constraints without converting the auxiliaries to the EA82 setup - not an easy task unless you've got the EA81 turbo brackets and crank pulley.Also an AWD gearbox would be great. Will have to build one up and fit it in at some point. EA casing an EJ gearbox can be done without issue over here with a dual range gearbox.Cruise and remote central locking would be sweet and I'd like to add a neat little tacho, oil pressure and coolant temp on the steering column in a manner that doesn't cover the other gauges. It's just a case of time and money for those things - after all this is meant to be a cheap build!CheersBennie
April 3, 201511 yr Author Yeah Dinky, yours looks good! No longer got it? I love mine, really can't drive it enough!! An update: I managed to get close to Redback this week as M&D are still borrowing her due to mum writing off her car with a roo. The only positive thing to come out of Mum's car being written off is that I got the after market cruise thrown my way for nix After a day of stuffing around with some new connectors, wrapping wiring, making brackets and getting confused with a wiring issue I now have sorted the cruise control. I've used the AP60 kit, usually retails for between $230 and $250, about the same price as the "base" level speeding fine in Vic so I'd rather put money towards a tool that can help reduce the chance of a fine. Here's a few pics of how things have been fitted for the cruise; first up is the actuator mounting position and the cable fitment: Speed sensor pickup - the mount took some time and stuffing around to get it right. I prefer to mount off the gearbox so the sensor moves with any drivetrain movement eliminating the sensor rubbing on the magnets: And the all important control pad which is also mounted on a tin plate that's been shaped to fit as best I could behind the little coin tray/storage bucket thing in the dash on the right hand side: Then I got my "mod hat" on and pulled this from the parts bomb the next day: Cleaned that up, put a new set of boots on and fitted it to Redback. To get the rack in you need to typically drill out the four spot welds that hold the jacking plate to the engine crossmember: The brake booster vacuum pick up gets in the way of the PS pump, so I relocated it to the other side of the manifold and extend the hose to fit. The bung from the other side is moved to plug this hole. I then had to shave it down to allow the pump to fit without rubbing on the bung or manifold: And a longer thermostat housing needs to be fitted to clear the rear of the power steering pump: Here's a dodgy pic of the power steering pump fitted in place - it's hidden pretty well by the air cleaner, the reservoir lid pokes up behind the air cleaner: This mod transforms the feel of the Brumby - it makes the vehicle feel much lighter than it actually is and now I can throw the vehicle around much easier than previously. The exact same experience I had after fitting PS to Sunnie the Brumby. Lastly, I checked out some seats from another vehicle to fit as I was pretty keen to swap the original seats out, even though they're not a bad example of MY seats. I came up with a bracket that adapts the Honda Integra (early 90's model I think) seats to the MY rails for a direct bolt in application. Pretty stoked and the seats are awesome, even though the ones I'm using are pretty worn out - I wanted to make sure they would fit and work before I really invested in this mod. Total cost for these seats to be fitted is $15 on 2m of two inch right angle steel. They fitted much better than I thought they would. Pics to come on that mod - I want a better set of seats for the pics! It's been a busy few days and an amazing change in some vital areas of a vehilce, you wouldn't think this is the same vehicle going by the feel of how it drives. I also took the time to track down a whistling sound that occurred since putting the bullbar on - turns out it's the mounts for the LED light bar... Now I can't wait to drive it for some time!!! Cheers Bennie
April 3, 201511 yr Bennie, I guess I used the wrong term there in the wrong sense. I do still have it, ABSOLUTELY LOVE TO DRIVE IT ALSO !!! I would like to add cruise to mine also, not sure about getting it completed. I got it started then wasn't able to finish then and there.
April 3, 201511 yr Author ^ Sweet!Get the cruise sorted I love it for long distance driving and not stressing about my speed in general - just keep an eye out for speed limit signs and set accordingly... you can't go wrong!CheersBennie
April 8, 201511 yr Author I scored about 300km or more of driving in Redback today. Awesome.The seat mod is great! The PS and cruise made things easy. I didn't find any decent seats at the parts yards, so no pics of that yet I've decided I just want more subi rumble out the back and I'll be a happy fella... Exactly like this: CheersBennie Edited April 8, 201511 yr by el_freddo
May 20, 20196 yr Author Some recent shots of Redback, new boots and some 14 inch scorpion rims (the originals) And after some rain, looking roughly east over the centre of Bendigo: looking roughly North: I added some square IPF driving lights. One spot, one flood. Awesome lights and suits the front of the brumby well! I’ve got a set of Integra DA9 front seats fitted. Very comfy! I’ll have to get a pic of this at some point to share. They look right at home in the brumby! A few things will be happening to ol’ Redback over the next month or two. I’ll have to remember to update this thread more often! I’ve also got a detonation issue I’m battling with. It’s got the factory spec carb on it, that’s not going in the bin, so no need to suggest a Weber... I need to test the compression as this could be a major issue causing the detonation - this happens: - under light load at proper running temp at highway speeds (then under load like a decent hill) - under load when the engine is headed towards the thermo cut in temp and you’re pulling away at the lights from a stand still. Frustrating! EJ conversion with AWD box is in the wings at some point! Cheers Bennie
August 1, 20196 yr Author This is happening Stock brumby dash up top. This is the ONLY factory available dashboard and instrument cluster for the brumby in Australia. The lower dashboard and six gauge analogue cluster is from some touring wagons (most are digital), Coupés and the GL sedan. And of course it’s all Lego So this will be in soon. EJ wiring loom is being laid out for future use too Cheers Bennie
August 4, 20196 yr Author Dashboard is in. I had a few little issues putting it in, namely around the air vent ducting clicking in properly. But for the most part it’s in and almost everything works. It looks good and I can’t wait to go for a drive. Much better to look at than the original speed, oil/fuel gauges and a clock that didn’t work - I set it to 5 o’clock I’m not sold on the green backlighting, time will tell about what happens here. After finalising this install I need to fit an alternator and an air filter, pay rego that’s overdue, then go for a long overdue drive! Cheers Bennie
August 6, 20196 yr That’s quite a task you got yourself into. Pulling and reinstalling a dash is probably the job I would least enjoy. well done! I peeled all the liitle dash bulbs of their blue ‘skin’ on the forester once, as I had to replace two fried bulbs and didn’t know about the blue tint on the existing ones until I pulled the dash apart. The green dials became a warm pale muddy colour. Not green any more.
August 8, 20196 yr Author @Mitchy - there is a bit of effort involved with a swap like this. But it’s nothing compared to a dashboard swap or removal of an EJ dashboard - a common occurrence went people “drop” and EJ turbo into their non turbo Subaru. This is my second dash install and my fifth removal in the MY platform. It’s very similar to the L series dash removal and install process, as I’m sure it is for the EJ dashboard. I’ve worked out the indicator issue - it was the plug to the indicator stalk cluster. The plug on my indicator wiring had one pin that’s been hot enough to melt the plastic of the plug, changing the pin’s position slightly. With a small tweak with a pair of pliers I was able to seat the plug properly with its mate and I had indicators again. I also located the plug for the intermittent wiper relay canister to live on. It was tucked right up behind the instrument cluster. For now I’ll place the single looped wire plug on there so my wipers will at least self return. Then I’ll go hunting for my intermittent relay canister to fit for my wipers to work with the four position switch - off, intermittent, low, high. Such high level of luxury! The windscreen was fitted yesterday. So now I can focus on getting the rest of the interior back together and sort out the rust in the tray - clean it up and seal the metal. Cheers Bennie
August 8, 20196 yr Good work , sir! I once owned a ‘classic’ 1969 morris 1100 which had dash-mounted rocker switch operated wipers. That was a pain.
October 14, 20196 yr Author And Redback is back in action as of yesterday (second time since last post!)! And in good time too, it was raining this morning and that’s never fun on a bike! New front drive shafts and bearings this time around, plus painted hubs (knuckle). If you ever pain hubs just make sure the paint doesn’t build up where bolts etc go. Not fun sorting that out, especially in threaded sections. So I’ve finally lost my steering wheel wobble under all conditions, plus the clacking noises from the front left and the steering wheel shudder under brakes that was the initial issue ages ago. It’s bliss! And I forgot how much I enjoy driving this little beast! Now that everything is smooth up front, I reckon I’ve got a niggle up the back now. I’ll look into that in time as I’ve got a few other things to do first. Cheers Bennie
April 28, 20241 yr Author Wow I can’t believe it’s been over four years since I updated this thread!! A lot happened, moved house again and now drive further into work. Drove to Sydney twice last year - that’s about an 11hr drive one way. Redback didn’t miss a beat on either trip. First trip was to catch up with my mate from Perth who was in Sydney to work with some fellas that I ended up helping too, some of you may know them. Very surreal and awesome too. The fellas are dead-set legends! I grabbed this pic while I was there: The second trip was to attend Subinats in Sydney with the same mate. Epic trip. Marty is a legend too, he sorted me out with an I Love Bilpin sticker. Those in the know, know. He also did some tig welding on a part for my conversion among some pretty epic other stuff. At Subinats: ^ good from a far bit far from good! At least I had the best bullbar there! Hanging out at the gymkhana - three of the four Brumby’s in attendance for the show and shine: Both of the other Brumby’s are EJ turbo converted. The blue one took out the best brumby because it’s got a WRX interior including the dashboard. Very tidy work by Alex. Both Brumby’s are from the other end of the continent, Queensland. A big highlight on the trip over was being in the blue mountains. Epic country out here! Next big thing to happen was a carb rebuild as I couldn’t drive it at cruise/constant speed - it was jolting around like spark was cut intermittently. I’m glad this didn’t happen on the Sydney trips! The rebuild wasn’t much fun because carby but it sorted out the issue. And today we headed out to collect some wood. Mrs El_Freddo doesn’t like trailers in general and since her family bus was towing one we swapped vehicles to get into where the wood was. As a result I managed to snap this photo of Redback brumby in its natural environment and moving. There’s something about a vehicle in motion in pics, not that you’d know this was a moving vehicle: Not much going on for Redback at the moment other than needing the water pump replaced as the current one is leaking and it’s slowly getting worse. I’ve got one ready to go, it’s just a case of putting it in now. Cheers Bennie
August 18, 20241 yr Author Well the water pump was replaced. The bolts are not fully torqued up as I didn’t trust the threads in the block! No leaks. From that point on she was driven as needed - mainly on longer runs on the weekend or when carting stuff. I’m now in the middle of prepping for Subinats ‘24 in Sydney again. This is the ten year anniversary and my second, I’m hoping to do three in a row with the next one having the Brumby EJ powered (changed direction from the earlier discussion about the EJ conversion plans). I’ve sent my rims in for powder coating, going with the pearl white. This image is very accurate in how I saw the colours in the shop: These rims will look awesome once I get them back, the wheel nuts will look pretty average now though, I’ll have to try to buff them up for a better appearance. And I need to find my centre caps for these, I’ve got them but never run with them fitted. Tyres will be fitted with the outside edge on the inside so I’ll have the worn edges tucked under the car and the good edges easily visible to those looking at the Brumby. I finally got around to installing a UHF radio, several bits need to be sorted to complete that setup - it’s mounted on the roof, basically the same as how I mounted the unit in Ruby Scoo. And I got a basic head unit to get some tunes back into the Brumby without having to use a portable speaker. Since I was running the speaker wires I figured I’d finally install the central locking I purchased a number of years ago. It quickly got out of hand after this decision today. This is how I left it at dinner time: Got some work to do there and two weekends to get it sorted before we’re off to the event on the 14th of Sept. Also should say the grommets for the door jamb from a HQ/HJ/HX/HZ Holden for power windows and mirrors work a treat on the Brumby! I got the idea from Marty when he sourced them for the MCM Brumby build last year (this Brumby should be at Subinats as well 🤞). I also want to give the five poster a lick of paint, not a show quality finish, just something that ends up all being one colour! This is holding up the install of the UHF aerial that will be mounted on the left side of it too, so I need to get this sorted - next weekend all going well! I’d like to paint the front calipers and rear drums a bright green. If I had my game sorted, several weeks ago I would’ve grabbed a set of rear discs I’ve got at my old’s place and slapped them on the brumby - with the calipers painted. Still got the usual stuff to sort out - oil and filter changes, clean the interior out and pack for the trip. Then we cruise! Can’t but can wait. Cheers Bennie Edited August 18, 20241 yr by el_freddo Fixed image links
September 6, 20241 yr Author Big update. My Brumby sits like this at the moment and was like this for more than the last two weeks: It’s late Friday night as I write this, and I intend to leave for Skidney on Monday after work - and Redback Brumby still sits how you see her in the pic above. It’s getting close and I’m cutting it fine. One of the reasons for the above Jack stand action was this (as previously mentioned) - and they look mint in person with tyres mounted: The last week and a half was hectic prepping items for painting between work commitments. As usual for freshly painted things they look awesome but I wonder about their longevity. The biggest item was the bullbar that got a full scrub back, rust treatment, rubbed back again and then primed and painted from there. Here’s a much quicker picture summary of what was done: After the “final” spray of the bullbar had cured I found four sections I missed so had to get another can to finish it off. I think this extra can of paint got a great texture finish and a much more even coverage. I believe it’s still fully curing as it dulls easily when gently rubbed with your hands. Looks great though! The brakes and hubs got some paint too. It all took time but it came together well I think: Now to get it all back together this weekend - including replacing a split CV boot up front (outer too!), wiring in the stez (now mounted!), central locking, UHF radio (ceiling mounted - finished the console for it today so can’t wait to see if fitted) then put the interior back together! And I need to replace the rocker cover gaskets too, the current ones are a bit leaky… All in two days. We’ll see how we go. Cheers Bennie
September 11, 20241 yr Author Finally, after LOADS of work then tidy up and packing we’re off to Subinats in Sydney on Saturday. Left earlier to do some other stuff while up here but left almost two days later than planned. If you ever come to Australia and want to experience a wild time, come in October and do the Deni Ute Muster! It’s a loose weekend that’s for sure. This is one of the landmarks of the host town of Deniliquin - the ute on a pole (because why not?): Redback Brumby is loving the cruise so far. I’m sure she’ll keep the same attitude all the way home too. Cheers Bennie Edited September 11, 20241 yr by el_freddo
September 17, 20241 yr Wow! Talk about crunch time but I'll tell ya what; the truck looks a f-in treat, mate, hats off to you! Real good! Get home safe, sounds like a radical time 👍🏻
September 17, 20241 yr Nice picture ! Report ? How’s it rolling along now ? Edited September 17, 20241 yr by moosens
September 18, 20241 yr Author We’re back already! Redback Brumby took it all in her stride. I haven’t tallied it up yet, my estimate is we did about 2200km in five days. After crusing over our infamous coat hanger we managed to pull up on the harbour and snap a few pics. This is the best one: Subinats was awesome! Met many other brumby and MY sedan owners which was awesome. More to come on that later. I’m waiting on a phone to return from being repaired as I busted the screen the day we were leaving - it’s got all the build pics on it! More on that later, the work list is quite extensive once I list it out - which will come in the build post later Cheers Bennie
September 21, 20241 yr Author Ok, finally! Here are the rest of the build pics - in collage! ^ L series interior light “mod” - it’s a HUGE upgrade over the stock unit (mine didn’t want to work but when it did, it wasn’t worth the effort!); now I can see stuff in the cab - and I haven’t installed an LED unit in there yet either! The L series interior light is also responsible for holding up the new roof mounted UHF radio. I’m very stoked how this turned out! No new holes or screws added to the brumby for this one. Inspired by my roof mounted UHF radio setup in Ruby Scoo. Everything is reversible back to stock quite easily. The other two pics are a before and after of some wiring tidy up under the dashboard. I forgot to photograph the front brake transformation so I did it with the rear instead - where I also forgot to take a pic of the drum fitted, anyway, you get the idea! Much better setup over the drums. Also new braided lines fitted everywhere. Brakes are AMAZING now! Scorpions fitted with their sticker, completing the look they’re known for (and this owner was seriously missing the little black sticker!). Top pics - the faded decals. Bottom pics - painted up decals using a set of paint pens from office works. I’m not set on the red colour that the pen came out with but it looks far better than what it was before anything was done to the mud flaps. The front ones were painted in white over the Subaru logo. They look mint too! No pics of those though… With the bullbar paint up, fitted and the front mounted chopped sticker refitted; side badges and mud flaps painted up, Redback Brumby is looking awesome. It’s amazing what a couple of small details can do to distract from other bodywork “features”! And we were finally off, second stop (after a servo) was the Deniliquin Ute on a Pole. We made it to Barmedman to camp the night near their mineral springs pool. Neat little spot. Got rained on during the night, we were mostly dry, but got 95% of our stuff fully dried out before we left. Then it was continuing on our way. Parked up brumby in Cowra, a couple of laps of Bathurst/Mt Panorama - worth the effort, I’ve got a new found respect for the race and the drivers (Australian Touring Car Championship)! And a Bunnings (hardware store chain over here - also the inspiration for Hammerbarn in Bluey) that’s retrofitted into an old building in Lithgow - something I didn’t know they did, I found it interesting! We had to swing by Shield’s Orchard this time since we had time to find it! At this time of year they’re closed because it’s not Apple season, but we snapped a pic out the front of their place with their main sign. Then on to camp at Mt Wilson, pretty good camp ground, but felt like we could’ve been anywhere really - we were hoping for a real vibe of being in the Blue Mountains - really we could’ve been camping on Mt Macedon (Central Vic, same elevation). Next day we were off to Boxer Beauty to pick up some stickers - particularly the scorpion rim stickers to finish them off. Then off to cut a lap over the Sydney Harbour Bridge - aka our nation’s big coat hanger. Following this we buzzed around the Sydney CBD followed by parking at the harbour to snap a few pics like this one from earlier in the thread: Ripper! Then the big day. I won’t flood this thread with pics from the day, I’ll drop the link to that later. I will share these poser pics though! On the Sunday we legged it home from the hotel same as last year. We headed up over the mountains and took a longer than anticipated detour to Evan’s Lookout. Well worth the effort! We changed a bit of our route and went through Young and Urana rather than Grenfell and Narrandera. Good drive and possibly less hills but unsure about this. Bottom corner pic below is one of the pubs in Young. I can’t get over how big the pubs are in NSW! We spied a brumby in Deni so grabbed some pics with that on our way past, then continued home. We arrived a bit after 9pm. My navigator held on but lost out 40mins before we made it home. I’ve roughly worked out we did 2300km in the five days we took to do the trip! Awesome trip! Brumby ran mint the whole time. Issues we had: - driving light wiring at the cab switch came off the back of the switch, sorted that by pulling the wiring and joining them together. - pencil beam driving light, blown globe. Was working prior to paint work done on the rear covers. - rear wheel nuts on the right decided they’d try to take a holiday on our way down the Sydney side of the Blue Mountains. I thought it was a rear wheel bearing issue. Easy fix, not an issue since (and I checked all nuts). - no other issues I can remember, the brumby just ran like clockwork! The plan now is to get the EJ turbo conversion sorted for next year’s Subinats25 That’s it for now! Cheers Bennie
