heartless Posted May 9, 2018 Share Posted May 9, 2018 so discovered today that my trusty 2002 Forester with nearly 240K on the clock has developed a coolant leak in the heater hose stub pipe that connects to the crossover... or at least I am about 98% sure that is where it is leaking... (see diagram for clarity - the circled bit) She has not been overheated (yet) and I would really like to prevent that from happening It does not appear that this piece can be purchased separately from the crossover pipe, and I don't need the whole damn thing.. (nor do I wish to remove the entire intake to replace the whole thing) - but it does appear to be bolted on to the crossover. there are two bolts - top & bottom - on a flange that appears to be a part of that pipe So - desperately seeking a replacement. Please - someone has to have one of these things around in decent condition? I am willing to pay for the part & shipping, just need one very soon! Link to comment Share on other sites More sharing options...
ocei77 Posted May 10, 2018 Share Posted May 10, 2018 It is swaged in there and I doubt you can remove one from a crossover wo destroying it. I think you're gonna have to bite the bullet and get a salvage unit, replace the o rings and do the work needed. O. Link to comment Share on other sites More sharing options...
heartless Posted May 10, 2018 Author Share Posted May 10, 2018 oofta - not what I was hoping to hear at all. I have made a temporary repair with a length of hose & several hose clamps, but yeah, gonna have to do something a bit more permanent soon. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 10, 2018 Share Posted May 10, 2018 (edited) Are you absolutely sure it's not the cross-over to block o-ring? I have never seen one of those pipes leak. Not a single one. As mentioned they are not something that can be easily replaced either. I think you should acquire a used cross-over and new o-rings and swap it. One of my tech's and I once swapped an intake manifold gasket in about 15 minutes after a startup failure. Intake pull really doesn't take long at all. GD Edited May 10, 2018 by GeneralDisorder Link to comment Share on other sites More sharing options...
heartless Posted May 10, 2018 Author Share Posted May 10, 2018 (edited) fairly certain it is that stub pipe for the heater hose - saw a small stream of coolant coming out.. and there is rust on it.. yeah, I live in the rust belt.. so what all is going to be needed to do this? Obviously the crossover pipe & o-rings, fresh coolant, and intake gaskets - what else should I be getting? Edited May 10, 2018 by heartless Link to comment Share on other sites More sharing options...
idosubaru Posted May 10, 2018 Share Posted May 10, 2018 (edited) 2 intake manifold gaskets and 2 orings is all the necessary parts I recall. I’ve scrapped a bunch, don’t have any crossover pipes. Edited May 10, 2018 by idosubaru 1 Link to comment Share on other sites More sharing options...
Mike104 Posted May 10, 2018 Share Posted May 10, 2018 (edited) Yeah, I tossed one a few weeks ago Best option would be a pull and pay yard Edited May 10, 2018 by Mike104 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 10, 2018 Share Posted May 10, 2018 (edited) It must come from a Forester. The angle of the radiator hose nipple is different. I might have one. I had a stack of about 50 of those cross-overs. I had one of the high school kids that hang around go through them and toss a bunch in the aluminium recycle. Post a picture of the angle you need and what ports it has for heater, TB hoses, and CTS, etc. I may be able to match it up. GD Edited May 10, 2018 by GeneralDisorder Link to comment Share on other sites More sharing options...
heartless Posted May 11, 2018 Author Share Posted May 11, 2018 Yeah, I tossed one a few weeks ago Best option would be a pull and pay yard No such creature in my area, sadly. And come to find out, the part number the "local" dealer (over an hour away) tried to sell me was not the correct part # for my car. I verified this through another dealership parts department. At any rate, with time being of the essence here, parts have been ordered - crossover, o-rings & intake gaskets - all from the same place. Screw it, if I have to go in there, I am doing it right & doing it one time and will be done with it for the rest of the car's life (hopefully). At nearly 240K I guess I shouldn't complain too much, LOL Appreciate the offers and advice, guys, but it is a done deal except for the waiting for the stuff to get here. Not really looking forward to the job, but so be it. 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 11, 2018 Share Posted May 11, 2018 With that much corrosion - be prepared for the cross-over bolts to snap off in the block. They are only M6 and even here where nothing rusts we occasionally have one snap off. Be ready with the left hand bits, and the heli-coil set. GD Link to comment Share on other sites More sharing options...
heartless Posted May 11, 2018 Author Share Posted May 11, 2018 With that much corrosion - be prepared for the cross-over bolts to snap off in the block. They are only M6 and even here where nothing rusts we occasionally have one snap off. Be ready with the left hand bits, and the heli-coil set. GD oh boy! you are such a ray of sunshine, GD - but thanks for the warning. 1 Link to comment Share on other sites More sharing options...
heartless Posted May 19, 2018 Author Share Posted May 19, 2018 well, parts arrived this evening, so as long as the weather stays decent, it will be all about tearing into things in the morning. hope for no broken bolts! 1 Link to comment Share on other sites More sharing options...
heartless Posted May 19, 2018 Author Share Posted May 19, 2018 The good news is we got the intake off & crossover unbolted without breaking any bolts! yay! the bad news is, i have discovered yet another leak in the system... boo! the bypass pipe has a small pinhole.. discovered when mopping up coolant... wiped off the stub that feeds the throttle body and it immediately became wet again.. so back to square one - more parts ordering. all open orifices have been covered with clean rags, intake has been set on top of those to keep them in place & keep critters out and now we wait for the new bypass pipe to come in - should be here wednesday. kind of bummed, but at least I wont have to do this job twice, lol. Better to find it now & fix it than have it become a problem down the road. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 20, 2018 Share Posted May 20, 2018 (edited) Glad you didn't have anything break. I would say you got off easy if you just need that bypass pipe. It's only $22 new. GD Edited May 20, 2018 by GeneralDisorder 1 Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 20, 2018 Share Posted May 20, 2018 I bypassed my bypass pipe Just ran hose directly from water pump to heater core. Then again, my climate doesn't require the throttle body heat. Link to comment Share on other sites More sharing options...
heartless Posted May 20, 2018 Author Share Posted May 20, 2018 Glad you didn't have anything break. I would say you got off easy if you just need that bypass pipe. It's only $22 new. GD Yeah, I was seriously concerned about those long skinny bolts after your earlier comment, but dosing everything with PB Blaster as soon as we could get to them and taking our time seems to have paid off. One looks nearly brand new, the other 3 have a little corrosion on them, but not too terrible. I bypassed my bypass pipe Just ran hose directly from water pump to heater core. Then again, my climate doesn't require the throttle body heat. Yeah, you can get away with that. Not so much up here in Wisconsin, where actual temps can drop into the -20s & occasionally -30s in the winter months. but yeah, the part was not expensive at all... the "local" dealer seems to have some serious markup tho - they list it at $34 & change (plus tax), but Advance Auto could get it for $27 (including taxes & a shipping charge) but would take a couple of days. Needless to say, it was ordered from Advance. One of the drawbacks to where I live is Subaru is not a real common vehicle (especially the older ones), so nobody really stocks parts for them. I am amazed when I need something (aside from oil filters & such) & it is actually in stock. LOL Link to comment Share on other sites More sharing options...
heartless Posted May 24, 2018 Author Share Posted May 24, 2018 bypass pipe came in today - picked it up after work (got done a little early today), came home and tore back into the Foz to get it swapped out and start putting things back together. I hate driving the Dodge Ram pickup! LOL but man, what a bit of a chore to get that pipe out of the car and thread the new one into place... had to unbolt the AC compressor and lift it up out of the way to get enough clearance to do the job. That & good dousing with antifreeze from the water pump when I disconnected the little bypass hose... made for a fun evening. but, bypass tube has been replaced, the new crossover pipe & new o-rings are in, the intake is back in place (with new gaskets), it is just a matter of reconnecting everything that was disconnected and refilling with fresh coolant now - oh yeah, and bolting the AC compressor back in place (kind of a pain getting to a couple of those bolts). Hoping to have it all wrapped up and ready to run by tomorrow evening (depending on how late I have to work). All in all, not doing too badly for an old broad with arthritic knees, hip and hands, LOL (I used to enjoy doing stuff like this, but it gets harder to do every year) 1 Link to comment Share on other sites More sharing options...
forester2002s Posted May 24, 2018 Share Posted May 24, 2018 Heartless, I'm also getting a bit 'long in the tooth'. I rely of a set of knee-pads when working in the shop (and in the garden too). They make a huge difference for me. Wouldn't be without them. Link to comment Share on other sites More sharing options...
Mike104 Posted May 24, 2018 Share Posted May 24, 2018 I generally take some over the counter pain medication BEFORE I start doing anything too strenuous these days Link to comment Share on other sites More sharing options...
heartless Posted May 24, 2018 Author Share Posted May 24, 2018 LOL - OTC pain meds are a MUST for me anymore... I generally use Aleve as it lasts longer than ibuprofen does... but even then.. some days are rougher than others 1 Link to comment Share on other sites More sharing options...
heartless Posted May 29, 2018 Author Share Posted May 29, 2018 Well, my trusty Forester is all back together again, runs, and no longer spews coolant all over the place! Yay! all I can say is this was definitely an adventure, lol. from discovering the 2nd hole - in the bypass tube, to getting doused with coolant when removing the small bypass hose at the bottom (was expecting it to come out, just not in the direction it did) to forgetting to plug a sensor back in during reassembly.. (car wont start without the crank sensor plugged in, lol) but I am glad it is done, and I can enjoy my Subaru again. just need to keep an eye on coolant level for a few days and we are hopefully good to go for what is shaping up to be a HOT summer. I am looking at this little adventure this way - it was about due for a coolant flush anyway, so it is all good. 1 Link to comment Share on other sites More sharing options...
ThosL Posted December 11, 2025 Share Posted December 11, 2025 (edited) I'm also getting a coolant leak out of the middle of the engine. I thought it might be the lower radiator hose, but that's not it. My mechanic said it is too cold to work, though he does have a garage, he's from SA and they do most of the work outside. Update on this: mechanic was back working yesterday, went over to have him check it out, turned out being the heater hose where he spliced out the leaking section. Edited December 13, 2025 by ThosL Link to comment Share on other sites More sharing options...
