June 30, 20196 yr My outback is saying misfire on cylinder 3 & 4. Shop says try unplugging MAF sensor while acting up, and that will tell me if that's the problem. Can't find it for the life of me. They sell MAF sensors for this year, but I see in various forums that there is no MAF sensor in this model. Please help. I've found the MAP sensor. I also replaced plugs and wires. Going to replace coil pack next.
July 1, 20196 yr what car do you have? My first guess would have been coil pack due to waste spark ignition - other possibilities are ; plugs, plug wires, oil on plug wire boots from leaking valve cover gaskets.
July 1, 20196 yr Author 162xxx, I've had it for a few months. Bought used. Unknown maintenance. Looks pretty well taken care of
July 1, 20196 yr well, you can try a coil pack I guess but, you should try to catch-up on any maintenance or repair items. Could be old plugs.....
July 1, 20196 yr so it does, my bad. NGK plugs?, OEM wires? no oil on the old boots? if so, I think the coil pack is a very likely source of the problem.
July 2, 20196 yr Don't diagnose with Visa. Check compression, injector pulse, and spark on all four cylinders. GD
July 2, 20196 yr NGK on the plugs/wires? Not sure if the '04 were as picky as the earlier models...but why tempt the fates. 2000-2004 Outback had NO MAF, so you're not blind. :-) It's an EJ251 vs EJ253 thing (kinda) Only the turbocharged models had a MAF in '04 - STI, WRX, FXT, Baja turbo...IIRC.
July 3, 20196 yr Author Well, got the cylinder 3&4 misfire gone. Cleaned the PCV valve. But now, flashing AT oil temp light. I had unplugged all the sensors around where I was told the MAF was, looking for it. Cleaned the connections with electrical connector cleaning spray and plugged back in. Now the flashing light that won’t quit. Flashes once per second. No CEL.
July 3, 20196 yr You've got a code stored in the TCM / TCU / AT computer. You'll need to search on here about how to read the TCM - AT computer - codes. May be under "secret handshake" . Yes, seriously. On the pre-'99 models it was a series of steps that would then cause the AT temp light to flash the stored code. Repeat - the flashing tells you there's a code(s) stored but not what the issue is. We can't help until you get the actual code. Or you find what needs reconnected?? Edited July 3, 20196 yr by wtdash
July 3, 20196 yr Author Yep, finally got the long, convoluted method to work. It’s 31, throttle sensor?
July 3, 20196 yr Author I did take that out and put back while looking for the MAF. Could I have done something wrong when putting it back?
