Sawnawnaw Posted October 31, 2019 Share Posted October 31, 2019 Can someone please tell me which knuckle will interchange with my legacy outback wagon I have a 2000 legacy wagon but they don't look the same or at least the brakes and stuff are different. Also the 2000 is non abs and the 99 lobw has abs. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted October 31, 2019 Share Posted October 31, 2019 So you want to swap between a ‘99 and a 2000 model. Is the ‘99 double overhead cam or same as the 2000 model as a single overhead cam? I’d pull the two off and physically measure them. Same length and you’re good to go. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 31, 2019 Share Posted October 31, 2019 (edited) 1 hour ago, Sawnawnaw said: Can someone please tell me which knuckle will interchange with my legacy outback wagon I have a 2000 legacy wagon but they don't look the same or at least the brakes and stuff are different. Also the 2000 is non abs and the 99 lobw has abs. You should tell us what you’re trying to do - exactly what year/model knuckle you’re trying to put on what car. Generally all 95-99 legacy and outback ABS are interchanageable. all 2000-2004 legacy/outback ABS are interchangeable. Nonabs can use just about anything 1. If the car has ABS and you want the ABS to work: 99 needs 95-99 outback or legacy knuckles with ABS. 2. If the car doesn’t have ABS or you don’t need abs to work then you can use any 1995-2004 legacy or outback or Forster or Impreza knuckle. You can install the 2000 knuckle on the 99 but the abs just wont work. Pull the fuse to disable it You can install ABS knuckles on non-abs cars, the sensor can just be ignored (cut the wire to the sensor) and ignore the tone ring. Forster and Impreza knuckles work on legacy/outbacks but the abs is sometimes different depending on year. Edited October 31, 2019 by idosubaru Quote Link to comment Share on other sites More sharing options...
el_freddo Posted November 1, 2019 Share Posted November 1, 2019 Ahhh... the ABS thing makes sense now. I was thinking of the steering knuckle/extension and couldn’t work out why the ABS would be an issue! I should get more sleep! All the best with it! Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Mike104 Posted November 1, 2019 Share Posted November 1, 2019 (edited) If you need a knuckle for a 95-99 Outback Drivers side I have a refurbished one with new bearing, new hub, new seals and new ball joint. $100 shipped to anywhere in 48 US states. It won't fit your 2000 Outback though Edited November 1, 2019 by Mike104 1 Quote Link to comment Share on other sites More sharing options...
John647 Posted April 29, 2020 Share Posted April 29, 2020 On 10/31/2019 at 9:32 PM, Mike104 said: If you need a knuckle for a 95-99 Outback Drivers side I have a refurbished one with new bearing, new hub, new seals and new ball joint. $100 shipped to anywhere in 48 US states. It won't fit your 2000 Outback though Do you still happen to have this? Quote Link to comment Share on other sites More sharing options...
Mike104 Posted April 29, 2020 Share Posted April 29, 2020 Yes I still have it Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 1, 2020 Share Posted May 1, 2020 Sweet deal for someone. Quote Link to comment Share on other sites More sharing options...
KenKaniff Posted February 9, 2022 Share Posted February 9, 2022 You happen to have this knuckle still? Quote Link to comment Share on other sites More sharing options...
KenKaniff Posted February 9, 2022 Share Posted February 9, 2022 If you do, message me....I want it Quote Link to comment Share on other sites More sharing options...
